Question about Sony Playstation 3 (PS3) Console
Playstation turns on at red light when I press the on button it goes green then Goes off and flashes red and continues to flash red nothing else happens can not get it to work
  • 277 Answers
Again, people assume because it is blinking red that it is the "YLOD", better known as a hardware failure.
"When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly over heated. This may be caused by poor ventilation or the vents may be blocked."
"If this happens:
• Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
• If the PS3 system is in an enclosed area like a bookshelf or entertainment center, move it to a more open area.
• Leave the PS3 system off for 30 minutes to let it cool down.
• If you continue to have issues, you will have to send the system in for service."
You can also try the steps below. Its from PlayStation Forum:
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System
If the above steps still does not solve the problem, then I think will have to update your Ps3.
Update your PS3 (in the settings menu the 1st option).
Go on the internet browser on the PS3 then go on the menu press triangle then on one of them there are delete cookies and the delete the others as
well as cookies.
You could also try this as well: put the PS3 on then press the eject button (with no disc in) then hold it and switch the PS3 off at the back with
your finger on the eject button still holding it, then put it back on and the fan test should be working this may cool it down. It might be over heating.
But if your problem is not still solved, then maybe you should call sony for further assistance.
Take care.
Posted on Aug 20, 2010
Turn ps3 on light goes green then flashes blue then back to red
PS3 turn on goes green then flashing red is not a new issue. Please read this post and you can find the solution :
PS3 Red Light Blinking Fix
Feb 09, 2011 | Sony Playstation 3 (PS3) Console
Red light, turn on, goes green, flashes yellow then flashes green
connection problems or power surge connect to surge protecter
May 01, 2010 | Sony Playstation 3 (PS3) Console
My playstation has the light trun green yellow flashing red light
With your PS3 turned off, press and hold the Power button on the front of the PS3 for about 10 seconds (the system will beep as normal as it starts up but after 7-10 seconds it will beep again). The video settings should now be reverted. Doing this will also reset any theme settings. try this? seems to fix alot of issues.
Jan 22, 2010 | Sony PlayStation® 3 (80GB) Console
PS3 wont start up has a flashing red light
That happend to me and i gave it a rest for a couple of days and it worked again
Jan 01, 2010 | Sony Playstation 3 (PS3) Console
My ps3 it goes green beeps twice then goes red and flashes on/off
you might be holding the power on button to long. you hold the power on button until it beeps to reset the video output. try turning it on by using your controller. just press the ps3 button and if the red light is on then it should come on.
Oct 14, 2009 | Sony Playstation 3 (PS3) Console
PS3 won't turn on
hi Torgsrus.
PS3 Light sequence
The following pictures illustrate the CECHX0X model, however the light sequence is applicable to all PlayStation 3 models.
No lights are on:
When no lights are on, this means that the main power switch on the back of the ps3 is off or the PS3 is unplugged. When the main power switch is off (the '0' is pressed) and you will not be able to access any features of the PS3 system. To turn on the PS3 system, make sure the main power switch is on (the 'I' side is pressed down).
If the PS3 does not turn on:
· Make sure the power cord is not frayed or damaged
· Try using another power cord, if available
· Make sure the main power switch on the back of the PS3 system is turned on
· If you continue to have issues contact our Technical support.
Solid Red:
When the power status light is solid red, this means that the PS3 system is off (or in standby mode).
Standby, mode means the PlayStation 3 system is off, but is ready to be turned on by pressing the power button.
If the ps3 system will not turn on when you press the power button, this is an issue with the PS3 system and you will need to send your system in for service.
Solid Green:
When the power status light is solid green, this means that the PS3 is turned on.
You should be able to navigate the XMB, play games, access the Playstation store,etc.
To turn of the PS3, simply press and hold the power button for two or more seconds.
If the power status light is green ,and you are experiencing problems- have a look on our forums for troubleshooting.
Flashing Red:
When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly overheated.
If this happens:
· Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
· If the PS3 system is in an enclosed area like an entertainment area, move it to a more open area.
· Leave the ps3 system off for 30 minutes to let it cool down.
· If you continue to have issue, you may need to send the console in for service.
Flashing Green:
When the power status light flashed green, it means that the PS3 system is turning off. Please wait while the system turns off.
If the PS3 system does not shut down immediately, it may be trying to finish save data to the Hard Drive. If it is, do not turn the main power switch on the back off as it may cause data on your hard drive to be corrupted.
If the green light continues to flash green, the ps3 system maybe trying to write to the hard drive, shutting down or running programs. It may take longer to shut down depending on when you pressed the power button. If the green power light flashed for a very long time, you can try holding the power button down for 5 seconds, the console will beep and should turn off. Then try to restart the PS3 system.
Flashing Green, Yellow and Red:
When the power status light goes from green, to yellow, to green, then to a flashing red, this means that they may be an issue with an internal part with in the PS3 system. This may be caused by a variety of reasons and would need to be diagnosed by our support line.
When the PS3 power light flashes in this order, you can contact our Support Line for further assistance.
Solid Blue:
When the disk status light is remaining a solid blue, it means the disc is inside the PS3 system. If you wish to eject the disc, hold down the eject button for 2 seconds and the blue disc status light will flash indicating the PS3 system is attempting to eject the disc . (NB: the power indicator light will always be a solid green).
If the disc is inserted into the ps3 system, but does not show up on the xmb or will not play, this may indicate an issue with the reader- check our guide Discs are not loading in my PlayStation 3? for further troubleshooting.
Flashing Blue:
When the disc status light is flashing blue, it means a disc was just inserted into the ps3 system or a disc is trying to eject from the ps3 system. Depending on when you pressed the eject button, it may take longer for the disc to eject. (NB: the power light will always be a solid green)
If the light constantly flashes blue, it may be an issue with the disk being stuck in the system. If this happens there is no way to remove the disc yourself if you are using an orginal 60GB PlayStation.
Dec 02, 2017 | Sony Playstation 3 (PS3) Console
Won't come on
hy i got a toshiba 42" LCD tv ,when i press the power boton
iget the red light,& it stay that way ontil i pressthe power back off
thanks for any help
Jun 26, 2008 | Toshiba 62HM95 62" HDTV
Sony Playstation 3 (PS3) Console Logo
61 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
