Question about Car Audio & Video
Purchased my son a second hand Mazda 626. Its fitted with a Philips Logic Control radio Philips No CW077A or Fujitsu Ten No CE-3434TY1. I obtained all the owners manuals with the vehicle but unfortunately no security code for the radio. Are you able to provide details of what the code might be. I have been advised it may be four numbers from the vehicle vin number but I have no idea which four numbers. I would greatly appreciate any help you could provide. Many thanks Norm Walford
  • 50 Answers
Unless changed cby the owner it should be the last 4 digits of the VIN number which can be read from the label on the driver's door panel. If it has been changed, I'm afraid there is no way to retrieve it unless you can contact the previous owner.
Posted on Sep 22, 2009
I am looking for a 12valve cylinder head.
To fit what engine,year,cc, etc, need more info to be able to help you.
Jun 04, 2014 | 1991 Mazda 626
Where is the backup switch located on a 1998 mazda 626
It is part of the range control switch on the oustside of the transmission case where the transmission cable hooks up, it fits over the post that sticks out of the ******.. See picture below, part is about $100.00
Oct 05, 2012 | 1998 Mazda 626
Mazda 626 1992 clutch change.
Its a few hour job pulling transmission. Buy a new clutch , pressure plate and throw out bearing or your just looking for doing it again quickly.
Apr 22, 2010 | 1992 Mazda 626
My new 94 mazda 626 2.0 is very hard starting
tap on the gas a couple of times then try to start it.
Apr 28, 2009 | 1994 Mazda 626
Car hesitating & rpm reving up & down
Most likely, if it's anything like my old Mazda MX-3, the Mazda engines are VERY sensitive to airflow on the intake side. There is possibly a crack in the airbox or intake plenum (sometimes hard to spot if they are in a "bellows" portion), or not latched in place properly or improper airfilter. Give those a look, looking is free, fixing can be pricey, Mazda wants a lot for a little bit of formed plastic, just to warn you.
Apr 15, 2009 | 2000 Mazda 626
Car audio player won't fit in my model??
It will fit fine. You need to buy a dash kit.
If you don't want to order it online you can go to best buy and buy one.
Mar 23, 2009 | Sony 52W x 4 Satellite Radio/Apple iPod...
I need the wiring harness for my fujitsu ten stereo
What is the model # of the Fujitsu Ten Car Stereo. Do you still play cassettes? This would seem to be the reason for wanting to restore the unit - that and nostalgia. Once you have the model number you must do a search like;
Fujitsu Ten A230 harness plug. Also try Best Buy because they do a lot of car stereo installations. I just put my own unit in my Hyundai Tucson and bought my wiring kit from them; however you're going back to the 90's. I have another answer too, so let me know if this works.
Nov 20, 2017 | Car Audio & Video
91 mazda 626 erractic idle surge when engine is cold
My '91 626 did the same thing. I tested the throttle position sensor, and it was good so that wasn't it. The other likely culprit is the Idle Speed Control valve, or Idle Air Control valve, which is a $500 part new (more than I paid for the whole car). I pulled one off a 626 at the salvage yard and got it for 3 bucks, put it on (it's an easy DIY, just 4 philips screws holding it to the intake manifold), however I can't be sure that solved the problem, since I haven't run the car much since then. It would seem the most likely cause, tho, and a cheap fix if you go used. Other possibilities: O2 sensor or Mass Air Flow sensor?
Feb 16, 2009 | 1991 Mazda 626
Mazda 626
Hi Janieanip01,
Again we need more imfo....Is the vehicle injection?....If it is you'll have to wait until the fuel rail is re-pressurised before it will start....Crank it for about ten seconds at a time so as not to burn out the starter motor....It may be that the vehicle didn't run out of fuel but instead the pump may have given in....and when did you last replace the fuel fiter?
Regards Johngee10
Aug 10, 2008 | 2000 Mazda 626
Car Audio & Video Logo
121 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
