Question about Daewoo Heating & Cooling
Freezing of low pressure pipe 24 BTU - Daewoo Heating & Cooling
    Novelist:
    Champion:
  • 266 Answers
A line or coil freezing is a sign of restricted air flow or low on freon. Make sure the fan that circulates the cold air is working and the filter and coil at the filter are clean. A dirty coil can be cleaned with coil cleaner and a water hose. You will need to remove the unit and take it outside. (window units only) You can buy a bottle of coil cleaner at any hardware store. Follow the instructions on the bottle but basically you spray the coil until soaked wait 5 minutes and flush it clean with water from a hose. Repeat if necessary. Try not to get water and cleaner on the controls. Be careful water will be trapped in the unit you may want to tip it toword the back for 10 minutes or so and if possible let it set outside to dry. Reinstall the unit and put a clean filter on it and give it a try. If ice forms again it is low on freon and will require a repairman to fix it. Freon is a restricted item and you have to have a license to buy it. good luck..
Posted on Aug 20, 2010
My gree ac 12000 btu after 2 hour running ******* pipe is frosting .and slow slow indoor unit being fully frost .what to do?
get in a technician to check gas pressures as it may be low on gas
the frosting pipe will be the ******* line where the liquid turns to gas and a dirty evaporator fins
Jun 20, 2016 | Miscellaneous
Water leaking from unit
possible low pressure of refrigerant and freeze coil indoor unit, check filter maybe it's dirty
Jul 07, 2015 | YMGI R410A Ductless Mini Split 16 SEER DC...
My wall split a/c 24000 btu work about 1 hours or more after no cooling and u can see frost in the indoor coil and on the coppers on out door unit and i have low pressure 40
Low pressure and frost on your indoor coil with the copper pipe to your outdoor unit is almost guaranteed a low refrigerant charge. It can also be a bad metering device. You will need to check you high and low side pressures to be sure and make sure you let the frost thaw before checking pressures.
Nov 16, 2013 | Heating & Cooling
Low pressure fault
check filters if clean check pressure switch see if 24 volts both sides if not not enough pressure or bad switch
May 10, 2013 | Jandy Ae2500t 115,000 Btu Heat Pump
Low ref pressure
check filteres if clean check pressure switch voltage both sides should be 24 volts
May 18, 2012 | Jandy Ae2500t 115,000 Btu Heat Pump
Heat pump low ref pressure
ee if filters are clean then check pressure switch to see if voltage on both sides should be 24 volts ac if not pressure switch bad or copper line plugged
Apr 02, 2012 | Jandy Ae2500t 115,000 Btu Heat Pump
Pool heater says low pressure
if filters are clean check pressure switch if 24 volts on both sides ok if not check copper tube for blockage you can jump just to check
May 28, 2011 | Jandy Laars LX Pool Heater / 400,000 BTU /...
What size gas line for 400,000 btu water heater
Thank you for posting your question here on Fixya.com.
Is it Natural gas or LP gas?
What pressure does your gas provider supply it with? (It will usually be low pressure, ~14"WC if NG)
How far from the access point you will get gas from to the heater?
Once you have answers for these three questions use the installation guide found on pages 13-14 of this manual to determine the proper gas line size. Be sure if you use a different material pipe, like CSST, you adjust the pipe size based on manufacturer's recommendations. 1" copper and 1" CSST are NOT equivalent!
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
Feb 12, 2011 | Pentair MASTER TEMP HEATER 400 000 BTU NG...
Freezing up TD-64-24 beverage cooler
Some of this TRUE don't have service valves, but you can put a tapping valve (A1) in the appendix (small piece of pipe comming out of the compresor and seal on the other end).To check the pressure you need to know what type of refrigerant is in the system .If is 134a the low side should be about 24psi and the high around 160 it could vary depends how hot is inside the place and the fridge but not much more than 200.If you working with R22 pressures be around 60 low and 250 high side.
May 01, 2009 | True TD-65-24 Commercial Refrigerator
Mustang 2007 air conditioning is freezing pipes
Check the freon level, too low of pressure in the low side can cause freezing
Feb 28, 2009 | 2007 Ford GT
Heating & Cooling Logo
101 people viewed this question
Top Daewoo Heating & Cooling Experts
Tim Whalen
armandog07
armandog07
Steve
Are you a Daewoo Heating and Cooling Expert? Answer questions, earn points and help others
