Question about Sport & Outdoor - Others
I have an early 80's electric golf cart made by AMF/Harley Davidson. When I press the accelerator, it goes fine in the low range, but when I push it into the high range, it starts to arc across the contacts and stops moving. I checked the batteries and they seem to have the correct voltage required. I cleaned the contacts and they look like they are making contact. What am I missing? Thanks........
  • Sport & Outd... Master
  • 19,396 Answers
Hi.
Arcing is caused from problems with cables or connections, wrongly wired cables, short circuits or broken resistor coils. If arching is big, check near to resistor coil.
Posted on Aug 20, 2010
Need new or used forward reverse switch for gas Harley Davidson golf cart
I would check with vintagegolfcarts website, they all kinds of hard to find parts.
May 26, 2017 | Harley Davidson Golf
How to fix accelerator that doesn't come back off. When you push on it you have to pull it back off. On cub car golf cart.
Probably a broken return spring or just corrosion. You would have to get under the cart to see if this is the DS model. If it's the precedent model, It is one unit in the floorboard.
Mar 18, 2017 | Golf
What year is my Harley Davidson golf cart serial number 3B15885H7
Hi, Paul that number goes to a Certified Remanufactured 1977 Harley Davidson Columbia Par Car gas powered 246cc two cycle three wheeled two seater Golf Cart for more information about your issue and valuable "FREE" downloads that you will need please click on the links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have a nice day.
http://www.buggiesgonewild.com/columbia-parcars/Manuals-HD-Service/HD_Manual_Service_1963_1980_GS.pdf
http://www.vintagegolfcartparts.com/Category/harley_davidson
VintageGolfCartParts com
Harley Davidson Columbia Par Car History Company Name
Oct 16, 2016 | Golf
I have a 1979 Harley Davidson Golf cart that I can't start, any ideas?
Hi Dennis, worked on Harley's for 32 years, Harley motorcycles, Harley snowmobiles, Harley pedal pushers, Harley trikes, Harley flat trackers, Harley sidecars, even a Harley streamliner for Bonneville, but never put a fingerprint on a Harley golf cart. But hey it's just a glorified lawnmower engine right? Let's assume the engine was running before it was stored, you need 4 things for an internal combustion engine to run:
1. Spark, make sure you have the correct spark plug NGK BP5ES
and is gapped at .025" and when the threads are grounded against a clean unpainted part of the engine it sparks when turning over the engine. You might want to install a new one or clean the old new one as it could be gas or oil fouled.
2. Fuel, with proper mixture of 2 stroke oil, keep in mind the carburetor jets and air passages could be gummed up from old dead fuel, or not, mmmmmm not sure about 2 stroke fuel maybe the oil mix prevents varnish, If you have not gone through the carburetor I would recommend dropping the float bowl and dumping whatever mysterious substance or contamination you find.
3. Compression, stick your middle finger over the spark plug hole, turn the engine over and if get's properly blown off, then you probably have enough to fire.
4. Timing, make sure your points are clean, and gapped at .023" and will spark when opened and closed with the spark plug installed and hooked up.
I would also recommend purchasing a service manual, OEM part number 99496-80 for $40 You might be able to order one through Harley Davidson or visit the website below.
Finally, if all the above check out ok, try spraying some starting fluid/eather into the air cleaner or carburetor throat while trying to start the engine. If it still won't fire you can contact me at xlch@mail.com for plan "B" Good luck and have nice day. VintageGolfCartParts com
Jul 26, 2015 | Harley Davidson Motorcycles
1970 AMF Harley Davidson golf cart modeld gas replace Cell annoyed starter alternator and still wont turn over
Hi Anonymous, you might want to visit your local golf course and speak with some one in maintenace. 6-packs in a brown paper bag are great conversation starters. Good luck
Apr 16, 2015 | Harley Davidson Motorcycles
I really need a wirring diagram for a 1974 gas powered amf harley davidson golf cart. thanks for your help!
If you'l Google 'H-D golf carts", you'll get lots dealers that sell the manuals and the schematics are in those. The manuals aren't that expensive and contain all the info you need to fix anything that goes wrong with your cart. Believe me when I tell you that the manual will pay for itself. The reason I say this is because there is NOT ONE THAT WILL WORK ON ONE OF THESE CARTS as far as I know of. The H-D dealers won't even look at one. Since parts are sometimes hard to get, the other cart dealers won't mess with them either. So, you're relegated to doing you own work. You need the manual.
Good luck
Steve
Oct 21, 2010 | Harley Davidson XLS 1000 Motorcycles
What is the proper way to stat a gas 3 wheel Harley golf cart?
This is pretty normal if this is an old AMF cart...just have to make sure that your battery is is top shape
Mar 09, 2008 | Harley Davidson Road Tech HA90 MP3 Player
Sport & Outdoor - Others Logo
44 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
