Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
I recently replaced the motor belt on my DC07 and now there is a very loud noice coming out of it when in use. What could be the problem?
  • 78 Answers
Hi there SmartAlec here. I am guessing that since you said you replaced the belt on your vacuum that it was actually really stretched or broken before. Assuming this is right I would say that either the clutch roller is actually faulty or there is a problem in the bearings of your brush roller. I have made a video to show you how to look for these problems. If you need parts for your Dyson DC07 check out vacuumspot or nelsonvacuums they both have a good range of dyson spares for purchase online. If this guide was helpful please take the time to leave a review of give it a thumbs up!.
Posted on Nov 25, 2010
Dyson DC07 belt change has resulted in very noisy vacuum!
Hi I agree with the first 2 solutions above but not the 3rd one.
If you have suction coming through the hose when the machine is in upright position then the u bend has nothing to do with this problem.
Right so ... The belt snapped.
The answer to you question is "why did the belt snap" its true that it could just be old age but its more likely to have been caused by a foreign object being sooked up.
How the belt/brushbar/motor interact
Your belt simply connects the motor to the brushbar know as Direct Drive. If an object get inside the space between the motor and the brushbar or if it can jam the brushbar then this will cause the rubber to burn. The motor will keep spinning and the belt wont be able to so will snap.
So its easy to see that the belt has snapped and people just think "'oh the belt has snapped"
You might wonder where im coming from here.
Anyway because the brushbar got jammed it may also have been buckled slighty either as a result of the foreign object causing it to stop suddenly from spinning at high speed or/and the result of the heat build up.
The rattling noise you now find your Dyson making is more than likely because your brushbar is buckled and when it spins the bristles are hitting the housing unit.
Your belt will snap again unless you replace the brushbar
Apr 10, 2013 | Dyson DC07 Bagless Upright Cyclonic Vacuum
DC07 grinding noise
I had the same problem with mine, I took it to a repair shop. The problem is where the belt passes through from the brush and goes inside the machine. Move the belt over a bit and you will see that a plastic guide has been bent over and is pressing onto the brush, which causes the noise. Just bend it straight again and it stops.
Apr 21, 2012 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson makes loud noise
Could be damage to Fan within motor or shaft on motor..Remove brush roll and run with nothing connected to motor ,if noise still appparent then sounds like one or the other if ok then check for damage to the brush roller.../Housing..good luck
Mar 31, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
How do I cange the belt on a DC07 ???? Not sure
You need to know which model of DC07 you've got. Some have a clutch (and two belts - motor to clutch, and clutch to brush roller) while others don't. Changing the belt on a clutchless model is simplicity itself. On a clutched model, you've got a challenge: the belts are an integral part of the clutch assembly, and normally the whole thing must be replaced. For excellent illustrated step-by-step guidance go to www.dysonmedic.com and good luck!
Dec 24, 2009 | Vacuums
Older Dyson 07 Animal, loud ratcheting noise on carpet setting
That is an indication that the belts are worn, stretched or broken. You simply need to replace the belt. Here is a link to the belt(s) you need and a manual you can view:
Dyson DC07 Belts and Manual
Dec 04, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Trouble picking up particles yet no blockage
If the belt is stretched, worn or broken then it will not pick up well. Here is a link for the instructions on how to change the belt and a link for the belt you need:
DC07 Belt Changing Instructions
Replacement belts for DC07
Nov 23, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson dc07 motor sparks
Hi.
I think you are looking at replacing the motor with a new one.
http://dysonmanuals.llc.nu/
Chris..
Dec 30, 2007 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
242 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
