Question about Panasonic Palmcorder PV-DV203 Mini DV Digital Camcorder
My mini dv panasonic has a dew detectived - Panasonic Palmcorder PV-DV203 Mini DV Digital Camcorder
Thank you so much for that information. I tried the hair dryer thing but that did nothing. I have had the camera for over 3 years and was only able to use it for the first 4 months. Even after spending such a long period of time stored away, it still said that dew was detected.
All that I did was remove the bottom panel. I played a tape at that point and it worked fine. So if you are planning on disconnecting something, try powering up the camera before you get to that point. It may save you time and possible damage (especially if you lack electronic knowledge like me).
Good luck to anyone who is experiencing the same problems and I hope that this thread helps you as much as it did for me.
~Adam Gotsens
Posted on Jan 02, 2009
I took my old PV-DV203D out of the closet after 3 years, the "dew detected" issue remained. I tried your solution of removing the lower cover and disconnected the small blue circuit ribbon in the middle and re-inserted. The issue is gone. Thanks for the suggestion.
Posted on Sep 04, 2008
I have the same experience of this "dew detected" problem, try to remove the lower cover (the one where we connect the tripod screws) then look for any loose flat printed circuit pattern, or better disconnect then re insert again.
this solved my problem, hope it can help you
Posted on May 25, 2008
Manual dew instrucciones
Use a hair dryer to blow warm air into the unit. Do not heat the unit but allow only warm air to circulate so as to remove any dew formation within the unit that must allow the unit to reset the error.
Jan 09, 2012 | Panasonic NV-DS65 Mini DV Digital...
I have a Panasonic NV-GS 35 digiatl video camera. 'Dew Indicator' error is coming . How can I remove this problem??
hi,dew means you got humidity level to high inside the camera
,press eject,removed the battery and try to use an air dryer an blow air inside the mechanism
thats where the dew sensor is located , for few minutes the let it cool down in a dry place
thats should reset the sensor system, if its not work that mean you will have to
replace the dew sensor.
hope that will help you,thats all i can do from here.
regards Alan.
Dec 25, 2010 | Panasonic NV-GS35 Mini DV Digital...
Dew detected eject tape
como puedo solucionar el problema (how can I solve the problem)
Dec 19, 2008 | Panasonic PV-DV103 Mini DV Digital...
Exact location of dew sensor for panasonic NV-DS29B
You can easily locate it pasted on the mechanism , either on the motor driving the mechanism or nearby capstan motor.
Sep 04, 2008 | Panasonic NV-DS29B Mini DV Digital...
Dew warning on Panasonic NV-DS29B Mini DV
I had the same problem, and solved it by having the heads cleaned.
Aug 27, 2008 | Panasonic NV-DS29B Mini DV Digital...
Dew problem
it is on the mechanical section and have two connection,use a 1k resistor to convert it..
Aug 23, 2008 | Panasonic NV-DS29B Mini DV Digital...
Fix Dew Detect for Panasonic 700X
Dew has condensed in the camera. Eject the cassette but leave the cassette door open.remove the battery . Borrow a hair drier . set it to optimum temperature(not vey hot but but hot enough to cause discomfort when blown on fingers). direct the hot air through the cassette compartment door for about five minutes. reattach the battery and reinsert the tape.
Good Luck,
Luwangula
May 15, 2008 | Panasonic PV-GS300 Mini DV Digital...
Warning Dew Detected
Where are you keeping that camera? I would return this camera if it keeps happening (before warranty expire).
May 14, 2008 | Panasonic Proline AG-DVC7 Mini DV Digital...
Dew Detected
dew detect comes from moist that gets on your dew detect sensor. This prevents any moist from damaging the tape or mech. if moist gets on your tape it will stick inside your mech. if you have not been in a moist area then the sensor could be faulty or your main pcb could be faulty.
Feb 24, 2008 | Panasonic PV-GS39 Mini DV Digital...
Panasonic DV-PV203
Read the solutions here
http://www.fixya.com/support/t196433-dew_detected_dv_203
Jun 12, 2007 | Panasonic Palmcorder PV-DV203 Mini DV...
Panasonic Palmcorder PV-DV203 Mini DV Digital Camcorder Logo
174 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
