Question about SanDisk 2GB microSD Memory Card
My memory card doesn't open how can it open now
  • 724 Answers
It may need to be formated or a compatable card reader upgrade
Posted on Aug 20, 2010
I got a sd 8gb memory card free with MTS USB modem and it just doesn't seem to work! i am able to transfer the files but unable to open. my phone is compatible with 32gb expandable memory and i al
I believe the phone will need to card to be FAT32 format and the card may be formatted as NTFS. Insert the SD card into a computer. In "Computer" note the drive letter. Lets use E: as an example. Open a command prompt and type format E: /FS:FAT32
That will format it to fat32. Now try in the phone.
Dec 27, 2012 | SanDisk 8GB microSDHC Memory Card with...
Camera doesn't seem to be loaded in computer
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Nov 12, 2012 | Sanyo Cameras
I using MMC card in my mobile. when it is opened, it doesn't work. it wants to be formated. but doesn't format. so please help me.
Format it on a PC and then use it on your phone...
Get EASEUS Partition Manager. It's totally FREE and an awesome Program for formatting and manipulating hard drives. It's very easy to use.
You can get it here: www.partition-tool.com/
Jul 10, 2012 | SanDisk 2GB microSD Memory Card
Memorey card is not work in a phone
Hello, welcome to Fixya!
The fault is either from the phone or the phone's memory card slot.
Test the memory card on another phone or any other device that uses memory card. If the memor card doesn't work, then it means the memory card is not good. But if the memory card works, it means fault is from the phone.
Get a phone screw driver, disassemble the phone, clean the memory car slot with a tooth brush. This will clear off all particles that maybe preventing the memory card from contacting the phone properly.
The cleaning the memory card slot doesn't help, it means the memory card slot of the phone is defective. It takes only a repairman to fix this fault for you.
I hope the above information is celar.
Regards.
Walesarumi
Dec 14, 2011 | Samsung Lands Phones
It's doesn't reset and it doesn't open
It is possible that the hang up because there are error in the software.So to reset,remove the battery and the memory card from the phone.Using your PC, scan the memory card for any corrupt files or media files.It is possible when they are downloaded from unsafe sites.After that remove or format the card.Copy only valid files to the card and do scan before it is replaced.Now replaced the card and the battery and switch on the phone.If the phone hangs up or is to slow when it i switch on then it is confirmed that the software ha error and will need a re- installation.
Sep 25, 2011 | Nokia 3110 Cellular Phone
I formatted my nokia 6300. thereafter i am unable to open my memory card. it is asking for pin number. when i formatted my mobile, the memory card was taken out. can you offer a solution?
You must provide your pin or code to activate your memory card. If not you must format your memory card. "That means it'll lost everything which is inside or under your Memory card " Formatting your hand-set doesn't relate to your memory card
Thanks for using FixYa All the Best!
Aug 05, 2011 | Nokia 6300 Cellular Phone
Memory card not recognized, lense won't retract, menu doesn't work
I put in sd card and it says processing and does nothing wont even go off you have to open the battery place but it will take pic with no sd card in it on the internal memory
Jul 17, 2011 | Kodak EasyShare Z1015 IS Digital Camera
How to format my memory card using pc?when i press the data storage mode,it starts formatting the memory card in mobile & the mobile as usb doesn't show up in pc.so how can i format it in pc?
You just need to remove you are memory card from you are mobile and place you are memory card in card reader slot.After that connect that data card to you are pc.Then open my computer there you will find as removable disk right click on it.Then there will be number of option in that select formatting after that select quick formatting then a new window will open telling that all information will be erased.Then give ok then it will format.Thanks for your question.
Jun 20, 2011 | Nokia Cell Phones
My new 4g memory card will not let me use it, say memory error
Hi there!
Since this is a new memory card, the first thing that you can do is to format the memory card through the camera menu.
If that doesn't work, try another memory card. If that card doesn't show the error then your new memory card is the problem.
Hope this helps.
May 14, 2011 | Cameras
My camera doesn`t read memory card.I tried with 2
On most cameras, once you start to use the internal memory, the camera doesn't want to read a memory card. You need to go into the menu and "reset" the camera. Then, with no card in the camera, go into the menu and "format" the internal memory. Then, insert the card and "format" it. This will erase it so download any pics first.
Mar 01, 2010 | Pentax Optio M20 Digital Camera
SanDisk 2GB microSD Memory Card Logo
56 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Carlos Calvo
Level 1 Expert
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
