Question about Amana ACS7270AS Electric Kitchen Range
My amana oven wont come on and show f1 - Amana ACS7270AS Electric Kitchen Range
  • 15,935 Answers
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
!@#W
Posted on Oct 01, 2010
MY AMANA DROP IN OVEN IS SHOWING A F1 CODE ON THE KEYPAD. IT KEEPS ON BEEPING AT ME. WHAT DO I NEED TO CHANGE??
F1 code means a shorted keypad. Replace the membrane or control, depending how it's available
Jul 14, 2011 | Amana Ovens
AOCS 3040WW convection oven
F1 Error code for Amana indicates a failed electronic range control (ERC)... that's the main computer behind the keypad. Post back with the exact model number and I'll assist with part number and replacement procedures.
Aug 29, 2007 | Amana AEW3530DD Electric Single Oven
Im getting F1 in my Amana Big plus oven
he "F1" fault code indicates an error in the electronic oven control circuitry. The failure is most likely the electronic oven control board and a slight possibility of a faulty oven temperature sensor probe.
Jan 26, 2011 | Ovens
Amana convection. Showing a F1 code on the panel. Model ARTSC8650WW
Hi
Thanks for using FixYa. F1 error indicates that the control board (ERC) has gone bad and the electronic range control (ERC) should be replaced to resolve the issue. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 15, 2010 | Amana Ovens
Amana oven AGDS902SS started beeping and showing a F1 error.
F1=Electronic range control failure
It is telling you may have a fauilty control...need to replace control or EOC.
If you are an novice working over the control board. please do take the help of an authorised technician doing that.
Mar 02, 2010 | Amana AGDS902 Gas Kitchen Range
My daughter's Amana gas oven ARGS765OSS turns off.
The F1 code is a faulty electronic control board EOC(clock).
Go to repairclinic. com and put in your model number for a good price.
Jan 03, 2010 | Ovens
Temp stays at pre-bake 170 degrees oven does not ignite
We are Amana factory authorized service and parts supplies. We have all the parts that you need for you oven.
You may contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service and we will give you all the information as well as get the correct part out to you asap.
We look forward to getting you up and cooking again.
Thanks, Ella
Nov 10, 2009 | Amana AOGD2750 Gas Double Oven
When burners are turned on Code F1 shows up and starts beeping
Hello, an F1 error code for an Amana refers to a failed watchdog circuit or ERC (Electronic range control) and need to be replaced. This can be located inside the control panel and is normally accessed from the back of the range. If you have any other questions please feel free to comment again. Mike
Oct 01, 2009 | Amana AOCS3040 Electric Single Oven
F1 service code
The owner's manaual states that F1 means Control Malfunction.
The manual recommends the following:
Press Oven cancel pad or disconnecting power supply may eliminate F code. If failure continues contact an authorised dealer.
Aug 02, 2008 | Amana ACF3325AS Dual Fuel (Electric and...
F1 error on SS Amana Convection wall oven
Jun 03, 2008 | Amana AOCS3040 Electric Single Oven
Amana ACS7270AS Electric Kitchen Range Logo
346 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
