Question about Ricoh Office Equipment & Supplies
Toner wont load - Ricoh Office Equipment & Supplies
  • Ricoh Expert
  • 155 Answers
Need to know what model we are talking about. Cloud be bad toner pump/ toner motor/ pcu assy need more info
Posted on Nov 30, 2014
Toner will not loan
Either toner transport pipe cloged or toner pump gone. Only new pump will solve it, but first I would check the rubber pipe that transports the toner. That is most likely
Apr 18, 2014 | Ricoh AFICIO MPC3500 1-SD YLD BLACK TONER...
Toner wont load
there are only a few things you can try, and it sounds like you've done most of them. If the steps in the document linked below didn't help, then you could do a physical printhead cleaning. Bob_Headrick gave the steps for doing that in the post linked below. If none of that is working, you can either replace the printhead by contacting HP tech support, or you will need to replace the printer. HP Printer Support
Jan 18, 2014 | Ricoh Aficio Type R1 3228c / 3235c / 3245c...
Aficio mp 2550 wont' load toner
Hello, my name is Steve. Lizz, when was the last time it was Serviced ? Sounds like there may be a dirty Sensor in the compartment that makes contact with the toner container. They must make good contact when removing and installing. Vestiges of toner particles tend to be problem. Since toner is made op of color,Polymers, and metal , these create a problem. I would start with a cleaning and a Quote from a Qualified Service person. Steve
Jan 10, 2014 | Office Equipment & Supplies
I have a Ricoh aficio 2018D problem is SC390 Code i reples PCU Unit Lower unit/Drum & Developer but sc390 code problem not solw. Please help Me.
The TD sensor is reading an abnormal value, this could happen if no toner is getting into the developer unit or it could be a bad TD connection or TD failure. Would suggest checking to see if the toner supply path is working first.
Check that the toner bottle is empty and most of the toner in the development unit is depleted.Add a new bottle of toner, run a forced toner until it looks good, then run td initialization.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 03, 2011 | Ricoh Office Equipment & Supplies
On my Ricoh aficio super G3 the toner wont load after replacing, the cartridge rotates but wont load
FYI "super G3" is the type of fax that is in your copier, not the Model of the Ricoh. Did you remove the steip after you put the toner in?
Aug 20, 2010 | Ricoh Office Equipment & Supplies
My Ricoh CL7000 keeps asking to replace the yellow toner, which I have done and it goes through the motions of loading the toner then the error message comes back again - asking to replace the yellow...
The toner cartridges for the CL7000 have microchips embedded in them, so the machine knows if it's not a new cartridge. Was the cartridge you put in brand new? (And was it a genuine Ricoh cartridge?)
On those printers, the toner is pumped into a developer system and mixed with the developer before making the image. In the developer unit, the density is checked, so if it's not seeing the right mix there, one of three common problems could be causing this.
The more likely solution is to replace the yellow developer unit, which comes as a whole unit and just slides right in. That will reset your density levels and should correct the "load toner" error.
There is a spring and cushion mechanism that the toner cartridge sits on -- this mechanism can easily be popped out of place and cause problems loading the toner. Take out the yellow toner as well as one of the other colors, and see if the little black circular piece is sitting the same way for both colors. If not, just pop it back into place, using the second color as a guide.
The other likely possibility is that the yellow toner supply tube is clogged, but that doesn't happen very often. To test if it's clogged, take out the yellow toner cartridge and the yellow developer unit and turn the copier off. Use a vacuum to provide suction at one end of the tube (the toner end will be easier) and put your finger on the other end (the developer end) and see if you feel the vacuum's suction. If not, there is probably a clog somewhere in the line.
If there is no clog and you can feel the suction, you may have a bad toner supply motor.
As a side note, if you find the problem and fix it, you might still have to put a new yellow toner cartridge in to get the machine running because it will think the cartridge you already tried is empty.
Hope that helps!
Jun 11, 2010 | Ricoh Aficio 1035 Copier
Wont load paper
without taking it apart its hard to tell whats wrong. But you can remove the toner cartridge and un plug it. Pick it up and gentley shake it to see if there is some debre in it. Steven
Jan 21, 2010 | HP LASERJET P1006 Printer
Does not load toner
make sure the cap is not stuck in ther machine from the old toner. very common problem. not the hard black plastic on you unscrew but the clear plastic one the hanlde removes as you close the hopper or handle. also the toner motors do burn up and willnot load toner. you will need a tech. also the dv fears go bad and make it look like a toner problem but you may need a pcu as the toner sensor is in the pcu. good luck
Oct 27, 2009 | Ricoh Office Equipment & Supplies
Brother HL 5250 red light flashing
I found this solution on the web-- Hope it helps.
The HL-2070N gets stuck in a toner end-of-life error condition. Perform the following to clear :
With paper loaded, new toner in,
Open front door
Turn off printer
While holding down the GO button, turn printer back on
When all four LEDs light up release GO button. All LEDs will turn off
Press the GO button 2 times. The 3 LEDs (toner, drum, paper) will light up solid
Press the GO button 5 times
Paper light will be blinking
At this point the toner end-of-life condition has been reset. Close front door.
BTW, I got this from Brother Support. Also, just a reminder, timing is important here so don't pause between button presses.
Jan 28, 2009 | Brother HL-2070N Laser Printer
Problem with aficio 1035
The developer should probably be changed in it. the cartridge should be inspected as well. Was there any toner spills?
Jun 21, 2008 | Ricoh Aficio 1035 Copier
122 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
