Question about Astoria Argenta AEP-2 Coffee Maker, Espresso Machine
Astoria sae 2n machine tank is full but not heating, any ideas
    President:
  • 1,618 Answers
Check to see if your machine has a reset thermostat on the left side of the boiler, on new models it is located on the top, second some machines have a 2 position switch make sure it is on 2.
Posted on Aug 26, 2010
Astoria Divina SAE/2N 2 heads. What would make the spout in between the heads be only cold water and the water level gauge shows all the way at the top of the glass?
If by spout you mean tea valve, it could be that the economizer mixing solenoid valve is set to deliver more cold water when mixing. As for the level the silver probe on boiler.
Oct 08, 2015 | Astoria Coffee Makers & Espresso Machines
Model number is SAE/2XL and I need a owners operating manual. we bought a used machine but they don't have a manual so,we want to know how the machine works and how to clean the machine. thank you if...
Could you please post the full model number and if you happen to have the serial number as well of your Astoria Argenta SAE-2 Espresso Machine? Thank you I await your reply
Rick
Oct 28, 2011 | Astoria Argenta SAE-2 Espresso Machine
We have an astoria model SAE.2 for some reasen the machine has gone very quiet and appears to be strugling when re charging after each use
It sounds like the water pump is not doing its thing or the machine cannot get water, either blocked filter or water line.
Jan 03, 2011 | Astoria Divina SAE-1 Espresso Machine
I have bought a used Astoria sae Espresso Machine and I need to know how to clean it - can you help?
You'll want to back flush the machine with espresso machine cleaning powder:
http://www.kaldi.com/cafe_supplies.htm and regenerate the water softener regularly.
May 21, 2010 | Astoria Argenta SAE-2 Espresso Machine
Overflowing from valve on top of boiler on astoria sae junior also one button on control panel working intermitantly
On the top of the boiler is also the boiler water lever which might be dirty or full of scale. you nee to remove it clean it with a brush. the button migh iit becoming wet from water from above problem so ceaning the lever you can solve both. The button might already damge if you have work the machine for along time with button wet.
Nov 19, 2009 | Astoria Argenta SAE-2 "Big Gulp"
Boiler has quit working
Check to make sure that there is water in the boiler by either checking the sight glass then rocking the machine to see if the water level bobs up and down, then check the thermal reset switch on the left side of the machine above the element. Make sure there is water in the boiler before pressing reset and turning machine to number 2. After machine heats up make sure pressure does not go past 1.5 bars on the gauge. If it does then the p.stat needs to be replaced.
Nov 01, 2009 | Astoria Argenta SAE-2 Espresso Machine
Need manual/schematics for espresso machine.
Your coffee supplier will be able to provide you with one.
www.kaldi.com
May 28, 2009 | Astoria Argenta SAE/JUN Espresso Machine
Astoria Argenta AEP-2 Coffee Maker, Espresso Machine Logo
240 people viewed this question
Top Astoria Coffee Makers & Espresso Machines Experts
Charles T Nevin
Charles T Nevin
obsteiner
NOEL
NOEL
Are you an Astoria Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
