Question about Amana ABD2533DEW / ABD2533DEB / ABD2533DEQ Bottom Freezer French Door Refrigerator
The food in the refrigerator is freezing. I have had several calls to the repair guy. He changed the control panel but that doesn't seem to help. Now the water dispenser will not work. Any ideas?
  • Amana Master
  • 909 Answers
This fridge unit isnt well known to me but most follow suit in design. I would say having an electronic board normally refers that there is an auger motor controlling the fridge temperature. As the demand for temp. is needed the electronic sensor will instruct the new board to open and close the auger motor flap accordingly. Possibly the motor is stuck or faulty or the sensor faulty. My bet is to check the auger motor. Call him in again and ask him to check it with you. (Normally mechanical control works with a thermostat whereas an electronic control works with an auger.
Posted on Aug 20, 2010
PSC23NSTESS FREEZING VEGTABLES
Side by Side ModelsIf foods, such as fruits and vegetables, in the refrigerator are freezing, it can be caused by several things. First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenheit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • If food in the bottom of the refrigerator is freezing, this could be caused by a refrigerator not having enough food to absorb the cold air.
  • If food in the door is freezing, move the door bins up or down so they are one notch away from freezer vents (Side by Side models only).
  • The fresh food control should be at the normal setting of 5.
Freezer on Top Models
First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenehit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • Since the cold air coming into the fresh food section originates in the freezer above, the rear of the top shelf will be the coldest spot in the fresh food area. Avoid placing delicate items that freeze easily on the back half of this shelf.
  • If food is freezing in the produce (fruits and vegetables) or meat pan, it may be that the temperature controls are not set high enough. Since cold air naturally falls, the pans can get too cold if the refrigerator is not running long enough to maintain good air circulation. Adjust both controls up one notch.
Nov 01, 2012 | GE CustomStyle PSC23NSTSS Stainless Steel...
Whirlpool 6wmv43ns/02 Fridge Too Cold & Freezing Food
I would first try replacing the control in the fridge. If that doesn't remedy the situation, I would try replacing the thermostat next.
May 14, 2012 | Whirlpool Refrigerators
It has been freezing food in some places in the refrigerator and defrosting some places in the freezer, for several days. This morning it sounded something like a machine running without oil, a very loud...
FREEZER FAN MOTOR MAY NEED REPLACED. THE EASIEST WAY IS TO TAKE OFF THE BACK PANEL IN FREEZER AND REMOVE THE FAN
MOTOR, TAKE IT TO THE NEAREST APPLIANCE PARTS STORE WITH YOUR MODEL NO.
EASY JOB.
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If
you need more help go here:
http://www.applianceaid.com/procedures.html
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Sep 12, 2011 | Frigidaire FRT21H7AS Top Freezer...
The automatic defrost cycle is not working in freezer. Can this just be low on freon and making it freeze up? I can defrost and refrigerator will work fine till it freezes up again.
Most times on your model it is the ADC or adaptive defrost control. Part number 13 in photo here=> MSD2756GEW Maytag Refrigerator Control Panel This is behind your controls inside your fresh food compartment.
61005988 Adaptive Defrost Assembly
When the fresh food compartment begins to get too cold is usually when the part #8 in that photo goes bad and that is called the auto air damper
61005971 Damper Control Assembly
More on that part next time. I believe you will be fine once the ADC is changed, Thanks, Sea Breeze
Mar 19, 2011 | Maytag MSD2756G Side by Side Refrigerator
Refrigerator freezes food regardless of dial setting. Control board?
Thank you. The part number you need is 240383703 at $146.18 thru Sears and is the control for the refrigerator not the freezer. The refrigerator control operates the opening and closing of the damper door which lets air pass from the freezer to the fresh food. The control is keeping the door open longer than it should. Hope this helps. Worth the repair and has been one of the most common problems with this model.
Feb 04, 2010 | Kenmore 52642 / 52644 / 52649 Side by Side...
Everything is freezing. Local repairman says the
Hi, what he is talking about is panel in the vent from the freezer to the fridge. Basically when you want the fridge colder a little panel (damper) inside the vent opens and allows more cold air in the fridge. When you want it warner the damper closes and allows less cold air into the fridge. This damper is controlled by the fridge control. What your repair guy is saying is the door is stuck in the open position which is allowing too much cold air into the fridge and freezing the food. if you have any other questions please feel free to comment. Mike
Dec 20, 2009 | GE PSS29NHNWW Side by Side Refrigerator
Fridge is freezing liquids and food
the thermostat is almost allways behind the control panel that was the dials,take your time not to braek the new one and you can do it yourself-mike
Oct 31, 2008 | Refrigerators
Amana ABD2533DEW / ABD2533DEB / ABD2533DEQ Bottom Freezer French Door Refrigerator Logo
66 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
