Question about Frigidaire FAX052P7 Compact Room Air Conditioner
I have a 5,000 btu frigidaire a/c and the compressor won't kick in
  • Frigidaire Master
  • 17,130 Answers
Could be the starter contactor, the capacitor or the compressor by itself . You can see the condition of the starter and maybe clean or if it looks bad , must be replaced. The same goes for the capacitor if the compressor is humming. But if the compressor motor is not starting up , please check for starting current with a clamp tester, if it goes higher and stalls then the compressor/motor is faulty.
Might need help to do an overhauling.
I hope this advice helps.
Posted on Aug 20, 2010
Ffu20fc4cwo won't freeze food
Check power to and from the thermostat first
Sep 13, 2012 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Compressor won't kick on 12,000BTU Frigidaire window A/C After cleaning
Is everything dry? Do you hear any noises like the compressor running it is just not cooling?
Aug 04, 2012 | Frigidaire FAH106N1 Wall/Window Air...
I have a Fedders A6X08F2A-B Service # and Serial # MP 178550 and I would like to have the specs on it eg: how many BTU's, model # etc
Hi, The numbers you have given tell me, this unit is a 8,000 btu unit.!2, 000 btu's equal a ton of cooling, so you are just under a ton. This is about all I can tell you. There should be a data plate that will give you amps, volts, compressor amps ect.
Shastalaker7
A/C, Contractor
Jun 10, 2011 | Fedders X Chassis A6X08F2A Air Conditioner
Frigidaire fac127p1a 12000 btu compressor
The compressor is probably going out on either a pressure related or heat related overload. Both are a result of low refrigerant. There may be a low pressure safety swich that protects the compressor. Otherwise it may be an internal thermal overload that is tripping. It resets itself and comes back on. The thermal overload heats up and shuts off the compressor to protect it from too much heat which is gernerated by not enough refrigerant in the system to keep the compressor cool. It may be cheaper to replace the unit than have someone try and fix it. It is pretty time consuming and you cannot try it yourself unless you have an EPA Certificate to buy the refrigerant. Check with your local appliance repair man to see if he will tackle it.
Jun 04, 2010 | Frigidaire 12,000 BTU Compact II Room Air...
Frigidaire r134a compressor.how can i know the horse power
It depends the model number, 452 BTU are 1/6 HP, R134a 776 BTU are 1/5 HP.
Dec 20, 2009 | Matsushita DD73C14GAU6 1/4 HP R134...
Compressor
Just have a local refrigeration store to match the numbers on the top of the compressor. It will go by BTU more than HP. Standard refrigerator uses 800 BTU's while side by sides use 1000 to 1200 BTU's..Sea Breeze
Jun 22, 2009 | Frigidaire FRS-26DR7D Side by Side...
FRT18L4FW3 Frigidaire Compressor Kicking Off Prematurely
Sounds like it is either low on gas or it is tripping the internal overload which would mean you need a new comp. Check on warranty
Dec 29, 2008 | Frigidaire FRT18S6AW Top Freezer...
Ac compressor not working
This unit is a 220 volt ac unit. 12-2 wiring is usually for 120 violt circuits?
  • Amps: 22.2 / 20.0
  • Watts (Heat): 4900 / 4000
  • Watts (Cool): 1650 / 1625
  • Amps (Cool): 7.7 / 8.3
  • Voltage Rating: 230V / 208V 60Hz
  • Power Cord Length: 5' (6')
  • Horsepower (Cool): 2.49
  • Plug Type: LCDI 6-30P
  • http://www.frigidaire.com/Home-Comfort/Air-Conditioning/Window-Mounted-AC/FFRH1822R2
    hope this helps?
    Jun 05, 2017 | Frigidaire Heating & Cooling
    Frigidaire FAX052P7 Compact Room Air Conditioner Logo
    180 people viewed this question
    Top Frigidaire Heating & Cooling Experts
    Dan Webster
    Dan Webster
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    Bill Long
    Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
