Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Lid will not lock when you press start, so washer will not turn on. Everything seems fine otherwise but washer will not start if lid not secured
    President:
  • 2,559 Answers
You have a bad lid safety switch or bad lock, one or both will need to be replaced to restore it to working condition.
Posted on Aug 20, 2010
Lid will not lock, Washer will not start: I press
There might be the issue of the lock as the control board tries to send signal to close the lock but it can not. This is common issue with the lock more than the control board.
Oct 11, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
Lid is not locking properly, washer sensor is overfilling, and the washer wont spin
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Pl click if helped.
Apr 28, 2013 | Whirlpool WTW4950XW Washer
The lid lock light won't stop blinking.
LID LOCK FAULT
Fault is displayed if Lid Lock has not moved into locked position or motor cannot be powered.
Lid is not closed completely due to interference.
Check for lock interference with lock striker.
Wash media buildup (detergent, lint, etc.) is preventing the lock mechanism from sliding.
Main control detects open lid switch when attempting to lock.
Main control cannot determine if lid lock is in a locked state.
Perform the following checks if the washer does not lock (or unlock).
1. Perform the Lid Lock test under Manual Test Mode on page 9. The following steps assume that this step was unsuccessful.
2. Check lid lock mechanism for obstruction or binding. Repair as necessary.
Oct 20, 2012 | Whirlpool LSB6200KQ Top Load Washer
Neptune TL locked lid light stays lit
foxste
I will give you a few things to try that are non technical and let’s see if the Control Board will let you in Service Mode. If so we will try lock and unlock the washer in Service Mode.
The Service Manual for reference. Sears Parts Direct for reference.
Let enter Service Mode;
Enter the Service Mode by pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
Board Output Test
While in Service Mode, pressing the Delicates key will begin the Board Output Test. This test turns on a
specified output after a key press. (Pressing the Delicates key again cancels the test.) All outputs
will be turned off after five (5) minutes.
Now Press the Colors / Jeans key this should lock the Left and Right Lid Locks….. did it?
If the lid locked now press the Extra Rinse Key and this should Unlock the Left and Right Lid Locks….. did it?
Let me know and we will go from there. I’m trying to get a feel for what Control Board functionality you have……Rich
Apr 29, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Frigidaire Galleria Front Load Washer.
Could be anything from lid switch to pc board to belt tensioner. Start with the cheapest and easier first with lid switch and belt tensioner.
Aug 30, 2009 | Frigidaire ATF6000ES Front Load Washer
My washer starts and stops a few seconds later with a FL code
Hello donaldwoulla,
I’m an owner of a FAV6800AWW not a GURU, this forum automated rating system is way too generous, I will try to help. Do you feel OK to try some troubleshooting? The following troubleshooting assumes you want try a possible DIY fix.
“FL” code is Failed to lock, we will try a few troubleshooting steps. The following test will be done by selecting the Spin Only cycle. First test will be done in service mode.
1. This is from SM; Press Enviro Plus and Spin Only keys for 3 seconds to activate Service Mode. Access Board Output Test by pressing the Delicates key. Display shows “ot” and the lid locks should actuate locking the lid. Does this happen, do you take the “FL” fail code in this process? Hit OFF button to cancel this test.
2. I want to make sure you signal an “OP” alarm to the display. Can you select Spin Only cycle with the lid open press start. Do you signal the “OP” alarm, lid open to the display? If it does close the lid and the “OP” alarm should clear, does it? I’m checking that the lid magnet is in place and the signaling connections are working thru the left lid lock back to the control board.
3. With spin only cycle selected and the lid closed press the Start Button do both lid locks try to close and lock the lid? From your initial post I believe you throw a “FL” to the display very quickly, that is the left and right lid locks do not actuate several times before the control board displays the “FL” fail code. Is that correct?
4. This step requires you to raise the top off the washer you will need to the move the washer out several inches and you should have a helper available to hold the lid up for you. Unplug the washer from the 120VAC outlet. Use this info and the FAV6800A/9800A Service Manual to assist you. To raise the top of the machine, insert a flat blade putty knife approximately 2.5” from the left and right sides of the washer top, depress the spring tabs securing machine top to the washer base. See page 33 of the SM for putty knife insertion point. We are going to reseat the Left Lid Lock plug a couple of times into the Left Lid Lock. We are checking to see if there might be some corrosion on the plug contacts. Take a look at page 34 of the SM. Top right of the page Lid Lock/Reed Switch Removal where the persons thumb is. This is the plug we want to remove and reseat a few times. It may be difficult to do remove so be careful. Mine was very difficult to remove the first time. This lid lock is near the bleach dispenser and other owners have had corrosion issues with this left lock causing issues. After doing this and you have reseated the plug into the left lid lock a few times power up the washer and give it a try.
Just to let you know don’t worry about the right lid lock, it’s signaling and control functions are in parallel with the left lid lock. I’ve had mine disconnected since mid Dec. The left lid lock is the important lid lock. It has the dual functions of signaling the control board that the lid is open/closed by the magnetic reed relay in that lid lock and the lid is locked by contact closure back to the control board in that lid lock. If this doesn’t help resolve the issue we will try removing the left lid lock to inspect if you feel OK to continue. Good luck. Rich
Mar 19, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Does not agitate or spin - fills and drains - checked belt & pulleys seems fine
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
The washer is equipped with a lid switch failure detector. If the lid switch
should malfunction, the detector will stop operations for your safety.
Read below
First,turn the control dial to proper cycle and pull dial out to start the washer. If
equipped with buttons, be sure they are fully depressed.
Close lid and pull dial out to start the washer. For your safety, washer will
not agitate or spin unless the lid is closed.
should malfunction, the detector will stop operations for your safety. Call for
service.
Pauses are normal. Wait and see if the washer will start again.
Please remember to leave a rating before you go!
Thank you
Sep 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Ariston washer
is this a new washer. if so remove shiping bolts from bottom or back.
Feb 15, 2008 | Washing Machines
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
448 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
