Question about Xerox XG-91D 19" LCD Monitor
My xerox monitor will not start up without turning it on and of a number of times
  • 11,361 Answers
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Aug 23, 2010
Xerox lcd modle number 900p Power supply fault plz send pics of supply 1 ic burst i never know number
How-to Fix KDS K917s Model 900P LCD Computer Monitor ...
? 9:59
https://www.youtube.com/watch?v=rkYJS2KhnTc
Jul 5, 2010 - Uploaded by X2YeZCAMCNC
How-to Fix KDS K917s Model 900P LCD Computer MonitorRepair Screen .... This screen has the exact ...
Amazon.com: Ac Dc Adapter Charger for Xerox Model 900 ...
www.amazon.com > ... > Monitors
Amazon.com, Inc.... Model 900 Xl592ds Xg-90d Xl370b Xl-370b Lcd Monitor,xerox Xg-70d 17" Lcd ...Power Supply FOR Xerox model 900 XL592DS XG-90D XG-70D XG-71D ...
Nov 23, 2015 | Xerox Computers & Internet
Reset to factory settings xerox phaser 3250
Reset to factory settings xerox phaser 3250 - Fixya
www.fixya.com/.../t12176778-reset_factory_settings_xerox_phaser_325...
Mar 26, 2012 - A hardware module is used to reset Xerox Phaser 3100 which work as permanent solution. After that you can refill unlimited number of times without ...
Mar 26, 2012 | Xerox Office Equipment & Supplies
Vga lead will not fit tower
Try turning it around. If it still doesn't fit, you may need a DVI to VGA adapter.
Aug 05, 2009 | Xerox Computers & Internet
Multifunction restarts repetedly
That is usually a bad main board. You can try removing the memory and reinstalling it...that fixes the problem sometimes. Also unplug your network cable and turn it on...data present when turning on some xerox models will cause problems.
Main Board is part number 140N63141
Jan 15, 2009 | Xerox WorkCentre 4150p - Multifunction -...
When I switch on computer monitor fails to stay on .
change capacitors c10 and c11 on inverter board
Dec 15, 2008 | Xerox XA7-192i 19" LCD Monitor
Xerox XA7
ccfl tube is destroyed or fuse on inverter board
Sep 01, 2008 | Xerox XA7-192i 19" LCD Monitor
Xerox XG-91D 19 in. Flat... Problem
If you look on the back of the monitor it has the name of the manufacturer - which I googled and found this warranty information: http://www.sylvania-displays.com/Support/warranty.html
If you already know that your monitor is out of warranty but want to try to figure out what's wrong with it, these are the contact numbers:
California:
PTI
7373 Hunt Avenue
Garden Grove, Ca 92841
Phone: 714-799-3899
Fax: 714-379-6290
Hours: 8AM to 6PM Pacific Time
Texas:
PTI
10849 Kinghurst Suite # 120
Houston, TX 77099
(281) 530-4100
(281) 530-4104 fax
Hours: 8AM to 6PM Central Time
For further warranty information, please contact our Customer Service Department
Call our toll-free service number at 1-800-776 8439 for out-of-warranty service rates.
Jun 23, 2008 | Xerox XG-91D 19" LCD Monitor
Monitor is failing to start although power is on
Sounds like you've got some blown capacitors on the internal hardware of the monitor.
Unless you are a seasoned computer hardware expert or electrical engineer I'd recommend you replace the monitor.
The capacitors that are blown are likely controlling the power aspect of your monitor, and aren't totally defective yet.
Most computer shops would not be able to repair your issue, due to lack of skills related to monitor repair. So you're going to find replacement the easiest / cheapest solution.
Of course you can try to ride out the problem as long as you can. But it will get worse over time.
Jan 08, 2008 | Xerox XA7-192i 19" LCD Monitor
19" Xerox flat panel monitor
always try with another monitor,before do nothing else. this reveal if the problem is the monitor. could be a cable problem( cutted inside),could be a backlight problem (it have a flourescent tube and a inverter that makes it "shine" ,or a supply problem what means it don't even work.these tree case are for the repairman.
Jul 09, 2007 | Xerox XG-91D 19" LCD Monitor
Xerox XG-91D 19" LCD Monitor Logo
529 people viewed this question
Top Xerox Computers & Internet Experts
Jack McCann
Jack McCann
Outback Jack
Outback Jack
Steven's...
Steven's...
Are you a Xerox Computer and Internet Expert? Answer questions, earn points and help others
