Question about Vacuums
I have been given a Necchi Sewline 20 L sewing machine but have no manual for it. Is it possible to get one or at least a threading diagram/instructions. I would be grateful of any help you could give me. Many thanks Angela
  • 821 Answers
SOURCE: Kenmore YM-40-35 R Sewing Machine
hello,please kindly visit the site below to see the comprehensive instruction with video on how to thread and bobbin your sewing machine.
http://www.wonderhowto.com/how-to-thread-mechanical-singer-sewing-machine-224245/
wish you good luck,
take care.
Posted on Jun 10, 2010
jyackle5
  • 8197 Answers
SOURCE: I need a manual for
You can find all the manuals for many different sewing machines and download them from the following web site.They do require some fee though.
http://www.sewingmanuals.com/Sewing_Machine_Manuals/Necchi.htm
Or you can go to this link to learn how to thread.
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Necchi_Sewing_Machine_Threading/Necchi_534_535_threading_Diagram.htm
Good Luck and please rate 4 thumbs up for the free answer
Posted on Sep 02, 2010
  • 264 Answers
SOURCE: I need a threading diagram
The upper thread flows from the left to right as it goes through metalstems (posts) with holes, along the top of the machine head, and thendrops down and passes over and under the upper gension disk and thetake up spring.  Then, moves back up to the take up arm (which moves upand down like a goose's neck when turning the handwheel) then startsthe trip down to the needle, going through a couple metal loops (calledthread guides) and lastly through the needle thread guide and throughthe needle eye, as I recall from left to right (?), this part is moreobvious when looking at it.
Heres a link to a manual for that machine. hope this helps
http://parts.singerco.com/IPinstManuals/16-133_CLASS_16.pdf
Posted on Jan 13, 2011
HansPP
  • 2510 Answers
SOURCE: I had a toyota rs2000
Try this site:-
ewingonline.co.uk/instructions/toyotars2000
Posted on Jan 28, 2011
  • 1075 Answers
SOURCE: I have a continental electric
on the bottom bobbin if you look you will see a small metal flap this is the bobbin tentioner simply make sure the thread is under this flap ,and the top needle will do the rest.adrian.
Posted on Mar 20, 2011
Royal Series, Necchi, Model # 80331763 bobbin does not take up thread properly. No manual unsure if i am threading it correctly.
You can get Necchi instruction manual from Necchi website: http://www.sewusa.com/Sewing_Machine_Manuals/Necchi_Sewing_Machines.htm". Makesure the needle is in the machine correctly- all the way up into the needlebar, make sure that it is threaded correctly, etc. If this all checks out ok,take the bobbin case out of the machine. There are two ears on either side ofthe bobbin case- turn the left one to the left and the right one to the right.Remove the silver ring, and inspect the piece of metal that the ring came off of(looks like a circle with the top cut off). You have to locate the hook whichis the piece that looks like a half moon inside the big round metal piece.Locate the tip of it, turn the hand wheel toward you until the needle is in thelowest position, at this point the tip of the hook should be flush with top ofthe left side of the cut off circle. Checkwhether underneath thread is looping on the fabric. If so then you've mis-threadedthe top, probably haven't raised the presser foot when threading so you can getthe upper thread into the tension. You need to thread the upper part with thepresser foot up. (You can put it down to thread the needle.)
Not picking up thread can be several issues, like bobbin is miswound, bobbincase isn't snapped in properly, you're using the wrong type bobbin, machine isout of time, needle is bent or burred, machine is dirty and in need of dustbunny eviction and a little oil but most of the time the issue is once againmisthreading: sewing machine needles have a front and a back and they have tobe placed in the needle holder correctly. In that case your manual is needed, take all the thread offthe machine (yes, spool off the spool pin, bobbin out of the bobbin case), pullthe needle plate and clean your machine thoroughly, using brush and vacuum (notcompressed air) and oiling per the instruction manual. Put it all backtogether, putting in a 80/12 needle, correctly oriented. Hang on to theneedle thread when you fetch up the bobbin thread.
Each and every seam you start is going to be done this way:
1) Pull the tail of the top and bobbin thread behind the presser foot
2) Put the work under the needle and use the hand wheel to lower the needleinto the work
3) Drop the presser foot
4) Holding the thread tails behind the foot, take a couple of stitches.
5) Drop the thread tails and sew normally. Hope this will help you. Good Luck.
Sep 12, 2011 | Vacuums
I've lost my user manual for my necchi sub22 sewing machine and can't for the life of me remember how to wind the thread onto a bobbin. Not a big issue, but it's really bugging me, because I...
You could email: spares@aeuk.co.uk and ask for a manual or call (+44)1322 291137 x 2 between 10:00 and 14:30
Or (Thanks to an article 10 months ago from Farmerbear) you could go to allyint.com
They are the sole US importer of the Necchi machines and I believe they stock replacement manuals. Their number is: 1 800 525 9987 ex 20
Jun 30, 2011 | Vacuums
Free owners manual for Necchi 575FA sewing machine
Find the Vintage Necchi page on Facebook. Lots of FREE NECCHI MANUALS there. I will have the 575FA manual posted there in less than a week. These other answers are posted by m0r0ns who are sending you to sites that CHARGE. I guess these stoopid jerks don't know what the words FREE MANUAL mean.
If you go to the Necchi-USA website, they will refer you to a website that sells manuals because they don't want to be bothered by the old machines. Keep that in mind if you consider buying a manual from a company that washes their hands of their products when they decide they can't make enough money from selling parts and keeping free manuals for them.
Mar 22, 2011 | Vacuums
I need a users manual for a necchi 931 sewing machine
Go to the manufacturer website to find out where to obtain a manual or find a local distributor and inquire on how to get one. You probably will have to buy it.
Feb 12, 2011 | Vacuums
I need a manual for a NECCHI Model 535FASerial nember 088549 sewing machine
Sep 02, 2010 | Vacuums
Vacuums Logo
500 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
