Question about Hotpoint Washing Machines
Urgent need for help My hotpoint machine has got a problem. The water can not be drained out at the conclusion of rinse. it seems the vacuum pump for draining fails to work. I cannot open the door, while the clothes have been inside for 2 days.
  • Hotpoint Master
  • 17,130 Answers
You can release the water by opening out the drain hose at the bottom. It will be neccessary to look under and so make an arrangement to have a good access. The release of the door is possible if you can disengage the safety lock.
Now before this is done plug on and see if the votage is present at the drain pump, if present and the pump is not active, switch off and take out the pump from the clamp setttings. You can find dirt locked into and making it ineffecive.clean well test with voltage before you set it back. However if the pump coils do not show continuity the pump needs to be replaced. If power is not present at the pump then the program controller is faulty.
decide with the options available. Helpful?
Posted on Aug 20, 2010
We have hotpoint wma63 on draining and spinning water on floor seems to appear
well I would look for a loose or damages hose fitting while it is working .
Feb 22, 2015 | Hotpoint Washing Machines
Wma over fills on rinse
This is most likely a problem with your drain line. Check to make sure it's not filling with water and that there is a gap around the line in the drain hole to prevent vacuum lock. Give the hose a good shake and see if that dislodges any stuck water.
You could also have something caught in the valve which is preventing it from opening and closing properly.
Feb 28, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Washer over fills on rinse cycle, the cold water does not cut off.
Feb 28, 2011 | Hotpoint WMA40 Front Load Washer
Washing machine seems to be washing ok but when it comes to the final rinse and spin the soapy water is pouring out of the soap dispenser on the front
this is happening because the machine is not draining the water away fast enough when going into the spin cycle. clean out the filter under the machine, this will solve your problem.
pallesappliancerepairs.com
Feb 04, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint wma76 stops and displays ON
Could be rinse water valve ..Faulty Solonoid coil
Nov 10, 2009 | Hotpoint WMA76 Front Load Washer
Hotpoint aquarius 1000 washer/dryer
cleared blockage from end of drain from machine.
Jul 27, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint WD440 1400 Spin
There has been an unbalanced load and the machine could not spin
(see ‘Automatic Features’, Starting and Programmes).
Has the drain hose been installed correctly (see Installation)?
Are the drain hose, standpipe or undersink connections blocked?
Has ‘Rinse Hold’ option been selected? If so press the Rinse Hold button
drain hose make sure there are no kinks and the end is over the top of washer to drain this ensures that there is no back flush with drain pipe
clean the dispenser drawer regularly
Clean and dry the dispenser
drawer, syphons, grate and
fabric conditioner exit channel
(A). Also regularly clean the
outlet pipe area
Never force the machine door: this could damage
the safety lock mechanism designed to prevent
any accidental opening
May 21, 2008 | Hotpoint Aquarius WD640 Front Load...
Maytag Washer Not Completely Rinsing
If your washer has an extra rinse button try pushing it. My Maytag refuses to wash unless that button is pushed, so in your case it may not be completing the rinse cycle correctly.
Just a suggestion.
Jan 03, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WD420 5+5Kg
The water level vacuum switch are not working , check hose might lose.
Dec 31, 2007 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
