Question about Maytag MDB9600A Jetclean II Built-in Dishwasher
Bottom of machine is not draining - Maytag MDB9600A Jetclean II Built-in Dishwasher
  • Maytag Master
  • 17,129 Answers
The drain valve might be clogged with dirt and results in non opening or partial opening. Use can take the valve out from the output hose fitttings and do a good cleaning , manually power and test the valve for functioning and reset. If however the power is not coming to the valve or is low then the timer program controller is faulty.
Helpful?
Posted on Aug 20, 2010
If the hose on my washing machine is to long and water has to travel up and down will that stop it from working if i pull washing machine out it works thankyou
Most washing machines have a drain pump behind the bottom front panel which is usually held on by small screws at the very bottom of the machine. Unplug it from the wall. Once the bottom panel is removed, there is a large cap that can be removed from the drain pump. When that is removed, you will usually find some debris in the pump that is slowing down the draining process. Look on YouTube and search, "Clean drain pump", for your particular machine.
Oct 06, 2017 | Washing Machines
My washing machine leaks alot of water from the drain trap while it is working or when it has just done a wash.
Thanks for the model number. The leakage is very likely from the drain hoses that are connected to the drain pump. For your model the drain pump is located at the bottom front behind the bottom plate. You will have to remove the screws holding the bottom front plate. Once you get this out you can access the drain pump and hoses. Either one of the two hoses (inlet from drum or outlet to laundry drain hose) could have burst or lost hose clamp. Need to fix this. Also check the laundry tub drains are clear and there is no back water into washing machine.
May 01, 2014 | Washing Machines
I have a Whirlpool Ultimate Care II washer Model#LSB6300LW0 that would not completely dry the clothes on the spin cycle. I'm not sure if the unit was spinning fast enough. I replaced the lid switch and...
It sounds like your Drain pump has either become clogged, or has burned out.
  1. First, disconnect the power to the machine.
  2. The drain pump is located at the bottom of the machine. You will have to remove the panel to access the drain pump, or you can access the drain pump from the bottom of the machine after you have removed the water from inside the machine.
  3. The drain pump has 2 hoses connected to it, and a wiring harness.
  4. Disconnect the hoses and wiring harness and remove the drain pump.
  5. Check the impeller inside the drain pump for coins, socks, etc. and clean it out if you can. Make sure it turns with ease, and isn't worn out, or rocking back in forth. If it is worn out, replace the drain pump.
  6. If after clearing the drain pump and reassembling, and the machine still fails to drain, replace the drain pump.
Jun 07, 2011 | Whirlpool Washing Machines
Washer is flashing f2
F2 on a Whirlpool Duet means their is a problem with the Drain Pump or Drain Pump Filter. The Drain Pump and Filter are located at the bottom of the Washing machine. You must remove the front, bottom panel to gain access to the Drain Pump and Filter. Disconnect the Filter and Drain Hoses and clear them out. If they are clear, you may need to replace your Drain Pump.
Feb 28, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Water gets drain cannot remain in the tub for wash ...type of my washing machine is LG WP 9031 top loading semi automatic..
The drain is pull the knob which will pull up the drain valve. So if this is not working then the connecting bowden is broken and is not connecting the link to the bottom drain valve.
Look at the bottom and connect. Clean the drain valve, if choked.
Sep 14, 2010 | Washing Machines
I have to drain my washing machine through a front hole drain opening in the bottom corner of machine. Water comes out, it has been left in machine. I drain my machine every six loads. WHY did Bosch design...
you have a blockage some where in the drain hose.most likely in the hose the comes form the bottom of the tub to the pump.you attach a wet dry shop vac to the end of the drain hose and remove the water this way while the vaccum is working look at the hose that comes form the tub to the pump and if it colapses then there is something restricting the water flow.also make sure to check in side the drain pump cover for any thing that is obstructing the pump
Feb 23, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Water is draining out the bottom as soon as it
A HOSE CAME OFF--THE DRAIN HOSE HAS A CRACK IN IT-- THE OUTER TUB IS PLASTIC SO IT COULD HAVE A HOLE IN IT---THE DRAIN PUMP IS LOCATED FRONT BOTTOM OF YOUR MACHINE IT COULD HAVE WORN A HOLE IN IT (PLASTIC ALSO)
Oct 28, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Water still in bottom of tub after drain/spin cycle
I removed the drain hose from the bottom left rear corner of the washer & cleaned a large amount of gooey sludge from the bottom of the drain inside the washing machine.
Feb 14, 2009 | Kenmore 12502 Top Load Washer
Leaks water out of the bottom of the machine.
check the pipe the drain hose goes into. if this is blocked the water will overflow out of it. or there could be a split in your drain hose
Jan 27, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag MDB9600A Jetclean II Built-in Dishwasher Logo
67 people viewed this question
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
