Question about Broderbund PrintMaster Gold 16 for PC
I have PrintMaster Gold Deluxe for Windows95 & Windows 3.1. I bought a new computer with Windows 7, what can I do to download the disks? I didn't have any trouble downloading PrintMaster Silver 10 for Windows 95/98/2000/Windows Nt 4 on my new computer.
  • 187 Answers
SOURCE: Just got Windows 7 and trying to install
Windows 7 has a compatibility wizard that you can use to help install it. Go to start, control panel, and then type in troubleshooter in the search box. Under programs, click "run programs for other versions of windows." Follow those instructions. If you need to browse to the setup file on the disc, do so. If that does not work, you can go to Broderbund's web site. They have a compatibility update for Gold 17 on their website. Unfortunately it is for Vista, but it still might help you with the compatibility issue
encore .
Posted on Nov 18, 2009
SOURCE: cant save to pdf in printmaster gold 17
found the fix for printmaster 18 broderbund pdf saving problems...
1-close all open programs and return to desktop.
2-click START and choose CONTROL PANEL
3-click PRINTER
4-right click on BRODERBUND PDF CREATER, then select PROPERTIES (the broderbund PDF creater properties window will open)
5-click the PORTS tab, then select ADD PORT button. (the printer ports window will open)
6-click NEW PORT, then enter PMPDF in the ENTER A PORT NAME window, then click OK
7-click CLOSE at the PRINTER PORTS window. you will now be looking at the broderbund PDF creater properties window
8-a check mark will be located next to the new PMPDF printer port. click APPLY. the broderbund pdf creator will now be located next to the new port. click OK.
9-exit all windows and restart the computer. once the computer restarts, you can save your project as a pdf file.
Posted on Feb 01, 2009
viff27
  • 6 Answers
SOURCE: uninstalling printmaster silver 12
u can't remove ur print master? i had encounterd this prob before
so try to install again ur print master to overwrite all files. coz u unistall it improper thats why u can.t remove it..
try to install again and after that u can now remove it into add/remove progam thx for posting!!
Posted on Jun 27, 2009
  • 1584 Answers
SOURCE: I can't seem to uninstall my old version of
Try to install, if OK it will if not it may offer to un-instal / overlay.
Posted on Mar 11, 2010
I cannot install PrintMaster Platinum 2011 on my Windows 7 computer. Is there a way to do it? It says it is compatible with windows 7.
Administrator privileges are required to properly install the program on Windows® XP, Windows Vista®, Windows® 7 and Mac OS X for PrintMaster Platinum 2011 .
Using mouse, right click on the "setup" and Run as "Administrator"
Hope it helps.
Apr 28, 2011 | Encore PrintMaster 17 Gold for PC
Our business has been using Printmaster 15 for a few years now. We recently bought a new computer with windows 7. Printmaster 15 is obviously not compatible with Windows 7. I bought printmaster 2011...
You can try version 15 in compatibility mode:
Troubleshoot Compatibility
This can help with some (but not all) programs/drivers:
1) Uninstall the program if it's already installed. Then when you install/reinstall it instead of double clicking on the install file right click it and select "Troubleshoot Compatibility"
2) Then click "Try Recommended Settings" and in the next window click "Start the Program" to install it.
3) After it installs see if it works correctly. Please note - some programs may not be able to run in Windows 7.
More details about how to make older programs run in this version of Windows:
http://windows.microsoft.com/en-us/windows7/Make-older-programs-run-in-this-version-of-Windows
Jul 19, 2017 | Broderbund PrintMaster Platinum 16
I have the print master gold deluxe software and I'm not able to use it with window 7. please help
All you need to do is download & install Windows XP Mode for Windows 7
http://www.microsoft.com/windows/virtual-pc/download.aspx
Once installed you will be able to run all your favorite old programs , if you run into any compatibility issues , right click on the .exe file & select "properties" , compatibility mode , & select the settings your program is known to work with .
After all this if you still can't run the program , try using " virtualbox " or " vmware virtual machine " & install a copy of windows xp as a virtual machine .
Apr 16, 2011 | Broderbund PrintMaster Gold 16 for PC
My wife has been using Printmaster for years and has created thousands of projects. Her latest version is 18. We got a new computer with Windows 7 and it said that version 18 is not compatible. So we...
Installing PrintMaster 18 on any computer requires .NET Framework 1.1 to be installed on the hard drive. If NET Framework 1.1 is not installed, it will be installed from thePrintMaster 18 install disk before PrintMaster 18 is installed. If possible download .NET framework 1.1 If .NET Framework 1.1 is not already installed on the computer, the "Program Compatibility Assistant" in Windows 7 will display this message.To continue with the installation, select "Run Program".
Feb 18, 2011 | Broderbund PrintMaster Platinum Version 18
Can printmaster gold 18 be run on windows 7
Broderbund PrintMaster Gold Version 18 is not compatible with Win 7.
The Printmaster Platinum 18.1 is compatible.
Dec 19, 2010 | Broderbund PrintMaster Gold Version 18
My printmaster 2011 gold won't install. what should I do
Installing printmaster 2011 gold on PC.
System Requirements:
Windows XP (Home & Pro) SP3/Windows Vista SP2/Windows 7*
Pentium IV 1.6 GHz or better (2 GHz recommended) or comparable AMD Processor
1 GB RAM available (2 GB RAM or more recommended, 2 GB required for Windows Vista and Windows 7 users)
Available Hard Disk Space: Installation disc requires approximately 2.7 GB; downloadable content can require up to 36 GB of hard drive space
Internet connection required to access content 16 MB Video RAM (64 MB video RAM recommended)
DVD-ROM drive, keyboard and mouse
Monitor resolution:1024 x 768 or higher (1152 x 864 or higher recommended)
QuickTime version 7.5.0 or higher is recommended (Available at www.quicktime.com)
Java version 6 or higher required (available at www.java.com)
Recommended Additional Equipment:
Printer, Digital Camera
Macintosh OS X 10.4.8 or greater* (with the latest Java update)
PowerPC G4 500 MHz or faster (G5, PowerPC or Intel Mac--1 GHz processor or better recommended)
Available Hard Disk Space: Install disc requires approximately 3.0 GB; downloadable content can require up to 36 GB of hard drive space
1 GB RAM (2 GB RAM or more recommended)
8 MB Video RAM (64 MB video RAM recommended)
22 GB (hard disc space)
Monitor resolution 1024 x 768 or higher (1152 x 864 or higher recommended)
QuickTime version 7.5.0 or higher is recommended (available at www.quicktime.com)
*Administrator privileges are required to properly install the program on Windows XP, Windows Vista, Windows 7 and Mac OS X
Do your system meets the above requirement?
Nov 15, 2010 | Broderbund PrintMaster Platinum for PC
I have Printmaster Gold version 3. I have had it installed on windows xp I now have a new computer with windows 7 and would like to install printmaster gold. What do I have to do?
Is your PMG 3.0 on the software compatibility listing for W/7? Did you check it? Pleae check it here: http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx
If your software is Windows 7 compatible, the list will tell you ... it should run with no hitches. If PMG 3.0 is not listed, you can appeal to the Printmaster Company for a upgrade path.
There is a compatibility test you can run from within the above link that will tell you what on your 'old' computer will migrate to your new computer ...
Even thogh this response was probably not within your expectation, it is a viable response and I hope it assist you in solving your delima.
Thank you for your interest in FixYa.com
Jul 01, 2010 | Computers & Internet
Window xp;and printmaster gold 16; printmaster will not download fully, when i click on the printmaster icon it has pop up that has windows has configures with windows ask for the install disk, then after...
Was this download from a P2P site? Sounds very suspicious
This is a Commercial program and is usually not freeware as I can gather.
If you downloaded it from a non-reputable source, you more than likely have received some form of malware.
I would recommend deleting it and running a full system security check.
It's only about $7.00 from a secure provider.
Regards
Dec 06, 2009 | Microsoft Windows XP Home Edition
Broderbund PrintMaster Gold 16 for PC Logo
708 people viewed this question
Top Broderbund Computers & Internet Experts
Martin Murray
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
