Question about Cell Phones
Wheneve i want to master reset my k750i i am prompted to enter phone code but i haven't got it. i've 1 attempt left.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 5 Answers
U just call your network provider ask them about your pin code or if you have entered it then ask them about PUK they will ask about the ownership of your sim and if it will be correct they will give you the PUK enter it in your phone and then it will be working properly THANKS D:
Posted on Aug 20, 2010
Phone reset
Here is how you perform a Master Reset on the Motorola VE-538:
1. Open your phone up and go to "Settings"
2. Next go to the selection for "Initial Setup"
3. Next go to the selection for "Master Clear"
4. Then select to confirm the option.
5. Now enter the security code which should be "000000"
6. Finally press select or ok and the phone will reset itself to the factory condition
Jan 09, 2014 | Motorola Mobility VE538 Cell Phone
I have forgotten my nokia 2690 security code and now i want to reset it how can i do so plz help me pzl.my nokia IMEI NUMBER is 352705045912316
hi there!
Let me give you the steps on how to restore the factory setting
of your phone.
Before you start, ill be advising you to please backup all the
information that is stored on your phone because a hard reset
will delete all the files from your cellphone.Remove the memory
card, if necessary, and write down any phone numbers or
contacts that you want to save.
After that, please dial *#7380# on your phone.After that
please select "Yes" at the subsequent prompt to indicate that
you approve of the operation. Enter the master code, if required
by your model. If you haven't set the master code, use the
default code "12345." Wait for the phone to conduct the reset.
It may turn off during this process. When completely finished,
the phone will return to its normal non-call screen.After doing
this, kindly insert your memory card if the phone.
Thanks!
Apr 20, 2011 | Nokia 2630 Cell Phone (Unlocked) - Black
2600 restore key and allkeys
hi there!
of your phone.
Thanks!
Apr 20, 2011 | Nokia 2626 Mobile Phone
I forget my master reset code plz help me
Hi shah,
you may wanna try this:
How To Unlock Nokia N79
1. Type #PW+
2. Enter your unlock code (Entering more then 3 incorrect unlock codes may permanently lock your phone!)
3. Now type +1#
4. Your Nokia N79 should say "SIM Restriction Off"
Apr 17, 2011 | Nokia N79 Cellular Phone
How can i perform a master reset on a Samsung B3410
To perform a master reset, you will need the security code to be able to perform this operation.
First you go to your phones menu, then you select security, then you select reset, you will see 2 options, 1. Reset settings 2. Master reset. Select master reset, it sometimes prompts you to enter the phones security code or does not ask you for any code at all depending on the initial settings, Then you select yes when it shows the information that all saved files on phone will be erased. That way your phone will reset.
That is how you master reset your phone.
Take care and good luck
Dec 29, 2010 | Samsung B3410 Cell Phone
How to reset sony ericsson k750i security code
Please find steps to reset sony ericsson k750i.
To Reset Code Memo:
1. From the standby screen Press Menu to enter into main menu and scroll to Organizer.
2. > More > Reset.
3. Reset Code Memo? Appears. > Yes.
4. The Code Memo gets reset. The earlier entries are cleaned.
5. Begin by opening the Code Memo for the first time when you enter the Code Memo again.
Thanks,
S
Nov 21, 2009 | Sony Ericsson K750i Cellular Phone
The keypad 3, 6 and 9 of my sonyericcson k750i are not functioning....
If you feel confident and competent enough, try taking your phone apart and giving the internals a good clean, take the white keypad PCB out and clean both it's contacts and the contacts on the phone's mainboard, and clear out any dust. Put the phone back together and see if that's solved the problem. It could also simply be that the keypad connector has worked loose
Key Pressed : Key presses phone appears to see
3 : 3 then left soft key
6 : 6 then right soft key
9 : 9 then back
c : c then #
left soft key : 3 then left soft key
right soft key : 6 then right soft key
(All the other keys worked correctly)
As I didn’t know what was causing this I attempted to move all data stored on the phone to the memorystick so I could master reset and possibly reflash, although after this I returned to the homescreen to find all keys had started functioning correctly again,
9 : 9 then back
c : c then #
Jun 25, 2009 | Sony Ericsson K750i Cellular Phone
Forgotten phone lock code for handset k750i
Hi Friend,
I Kindly let me know ur IMEI of your mobile.I can be found by typing *#60#.U will be receving a serial no kinly provide me i will provide the solution
Regards,
Ayyasam
May 29, 2009 | Sony Ericsson K750i Cellular Phone
yes. this is a master reset code for samsung, and will wipe all your data. the code is
*2767*3855#
May 26, 2009 | Sony Ericsson K750i Cellular Phone
Erasing all phone numbers and user information on A650
FROM THE MANUAL
ERASE MEMORY
Erase memory erases your Phonebook and Voice Dial recordings. This feature is useful if you want to give your phone to a friend or family member.
1. In standby mode, press the left soft key (Menu), then press 9 (Setup), 4 (Security). You're prompted to enter the lock code.
2. Enter the lock code (try the last 4 digits of your phone number unless you set a different one), then press 6 for Erase Memory. A confirmation prompt appears in the display.
3. Use the navigation key to highlight Yes or No, then press OK. A confirmation message appears in the display while your messages are being erased. Your phone then returns to the Security menu.
RESET PHONE
Reset Phone returns all setup options to their factory default.
1. In standby mode, press the left soft key (Menu) then press 9 (Setup), 4 (Security). You're prompted to enter your lock code.
2. Enter the lock code, then press 7 for Reset Phone. A prompt appears in the display asking if you wish to restore default settings (except for the Phonebook and Voice Dial).
Feb 05, 2008 | Samsung SCH-a650
Cell Phones Logo
62 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
