Question about Compaq Presario 5000 PC Desktop
I have a compaq presario SR5219UK. The motherboard has 4 DDR2 memory slots, 2 are filled and I want to put another 2 sticks in. Would the stock power supply that comes with this computer be able to handle another 2 sticks? I know the consequenses of underpowering the computer
  • 487 Answers
Hi, your power supply is OK, but you must install identical memory cards to the ones already installed.
Posted on Aug 20, 2010
Have a COMPAQ PRESARIO SR2020nx want to upgrade the memory it have 512mb how high I can go up on the memory
  • Two 240-pin DDR2 DIMM sockets
  • Supports PC 4200 (533 MHz) and PC2 5300 (667 MHz) DDR2 DIMMs
  • Non-ECC memory only, unbuffered
  • Maximum HP/Compaq approved memory is 2 GB
Feb 28, 2013 | Computers & Internet
What's your problem?bit ix38 quad gt motherboard with 2 gig of ddr2 ram i want to add a 1 gig stick of more ram that ive bought how do i do this? thanks windows seven
Top view of motherboard, scroll down. (Thought you might also like to read the reviews, and Comments)
http://www.bit-tech.net/hardware/motherboards/2007/12/06/abit_ix38_quadgt/2
Motherboard User Manual,
http://www.theraptorpit.com/forum/index.php?/forum/124-abit-motherboard-tech-support-unofficial/
1) On the motherboard the Blue ram memory slot that is closest to the copper heatsink, is ram memory Slot 1.
Also known as DIMM 1.
Ram memory ALWAYS has to be in this ram memory slot.
The Processor reads ram memory Slot 1 first.
2) The Blue ram memory slots are Slot 1 (DIMM 1), and Slot 3.
(DIMM 3)
The Black ram memory slots are Slot 2 (DIMM 2), and Slot 4.
(DIMM 4)
To run Dual Channel ram memory, means there are two LIKE ram memory modules ('Stick'), and they are installed in the SAME channel.
This would mean to alike ram memory modules, in both Blue ram memory slots, or both Black ram memory slots.
Since the ram memory modules need to be alike, they are generally purchased from the same manufacturer, and are the same kind.
Running ram memory in a dual channel configuration, is supposed to increase ram memory 'speed', up to 30 percent.
This is Baloney!
May look good on paper, but in actual use in the field it's cr@p.
Actual performance increase is more like 1 to 2 percent.
This has been proven by Tom's Hardware, and many, many motherboards, ram memory, Processors, etc.
So you have 2GB of DDR2 Sdram, huh?
Is it just one 'stick' of ram memory, or are you referring to two 1GB sticks?
If the above holds true install them in Slot 1 and Slot 3.
If not, and it is a 2GB stick of ram memory, be sure it is installed in Slot 1 (DIMM 1)
Install the 1GB stick in Slot 2.
It isn't the same as the 2GB stick.
It is 1GB.
Does NOT go in a dual channel configuration.
(Catching all this? There is NO dual channel ram memory!
It is ram memory that is -> ALIKE, and used in a -> dual channel configuration.
Used in two separate ram memory slots, that support the dual channel configuration.
Sold with the advertising scheme of 'Dual Channel', but really just means the two ram memory modules, (Or four), are -> alike.
1) Same Voltage used
2) Same Ram Timings
3) Same Chip Configuration
4) Same size in amount
5) Same frequency rate ('Speed')
With ram memory in a dual channel configuration, the ram memory modules team up on the task.)
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 31, 2012 | Computers & Internet
How to add or change DDR2 Memory Compaq Presario SR5110 desktop computer
Just remove the power cord, open the case, turn the computer on it's side and you will see the memory sitting in the slots. Push down on the latches on both ends of the memory slot and then you can pull the memory out.
Be sure to replace it with compatible memory or it will not boot up. Also it you install more than your system will hold, it will not register the excess.
Try 4 All Memory website. It will tell the type, how many slots you have and the maximum amount of memory it can hold.
http://www.4allmemory.com
It looks like your system uses DDR2-PC2-5300 Memory. It has 2 slots and a total capacity of 4GB which means each slot can hold a 2GB chip.
http://www.4allmemory.com/memory/compaq-hp-presario-sr5110nx/
Jun 03, 2012 | Computers & Internet
My pc will not boot up with both ram memslots filled take on ram out either one dosnt matter and it works fine put it bacvk in and locks aftwer boot or not boot at all
Hello
You need to seperate the ram sticks.Im assuming you have 4 slots.Color coded.Say 2 blue 2 white.
So 1 stick goes in white slot and the other goes in blue slot.
Or if you have 2 slots and while using both ram sticks you still can not boot up.This is beacause one of the sticks is different then the other.Read the ifno on the sticks.Something is not the same.
Sep 27, 2011 | HP COMPAQ Presario SR5510F Athlon 64 X2...
I am using this ASUS (asus M2N-MX nvidia mcp61p chipset
According to the manufacturer's web-site:
http://usa.asus.com/product.aspx?P_ID=0pKBwEIE8tqMT4j7
this motherboard has 4 x DIMM sockets,
supporting a maximum of 4 GB
of DDR2 800/667/533/ Non-ECC, Un-buffered Memory
and supports Dual Channel memory architecture.
So, add one 512MB DDR2 533 Mhz RAM into one of the slots,
being sure to leave *ONE* *EMPTY* slot between the two sticks,
in order to enable the high-performance "dual-channel" option.
Try your computer -- it should feel faster.
If you still think that need more RAM, buy two 512MB (or two 1024MB) DDR2 533 Mhz RAM, putting the 2 sticks into the two empty slots.
Dec 26, 2009 | ASUS M2N-MX Motherboard
I replaced a 512mb memory for the pny 2x1GB ddr2 pc2-5300 to improve my system performance but when i turn it on my system shut down a while after i had log in to my account then i removed the memory card...
You may have a bad memory stick. If the two are not exactly the same spec they may not be compatible.
Haev you checked that your motherboard is capable of handling 2gb of memory? And that it is the correct type of memory(size and speed) and that you are placing it in the correct slots(ddr2 only goes in ddr2 slots and ddr only works in ddr)
The power supply makes no real difference to memory, replacing that is not a solution
Jul 26, 2009 | PNY Optima 2-Pack 1GB PC2-5300 DDR2 DIMM...
Only 128MB or 256MB detected Compaq 12XL400 laptop; 3 diff sticks
I think the Smallest and slowest Ram stick needs to be in slot 0
Apr 18, 2009 | HP Compaq Presario SR1110NX PC Desktop
Ram Upgrade
Max speed supported for your mobo is: DDR2-533
You will have to buy (4) 1gb sticks (2gb sticks not supported)
To use all four gigs of ram you need a 64 bit os.32 bit only supports 3gb of ram. Hope this helps!
Here is the specs :
ASUS A8M2N-LA (NODUS-GL8E) (DDR2-533MHz) Memory Maximum Memory 4GB Memory Slots 4 (4 banks of 1) non-removable base memory 0MB Machine name: ASUS A8M2N-LA (Nodus-GL8E) Motherboard
CPU options: Supports AMD Athlon 64, Athlon 64 X2 and Sempron processors.
Chipset: Nvidia GeForce 6150 LE Chipset
HD Bus:
Front Side Bus options:
Memory Speed options: PC2-4200 DDR2-533 240pin SDRAM DIMM
Special notes:
- Motherboard manufacturer's name: ASUS A8M2N-LA
- HP/Compaq name: Nodus-GL8E
NOTE: *Actual available memory may be less w/o 64 bit os
Dec 24, 2008 | Computers & Internet
Memory Upgrade for Compaq Presario 2580US
no 'coz these two memory card differ in size and slot especially when the mainboard doesn't support ddr2
Nov 18, 2008 | Compaq Presario 2580US Notebook
Upgraded Ram Issues
check the voltage on your new ram.
For ddr2 you need both slots filled.(this the memory I would use)
Make sure you put it in the right slots.
make sure that BIOs recognises each stick.
Let me know if these work for you.
Nov 30, 2007 | EliteGroup P4M800PRO-M478 Motherboard
Compaq Presario 5000 PC Desktop Logo
182 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
