Question about Steinberg Cubase SX3
Good morning I have Cubase SX version 1.01. lately when I record vocals to a track. Im noticing that the Vocals are not in sync with the music. one is playing slower than the other track.. the slower is my vocals... I need help is there a setting to balance this out?
  • 3 Answers
Sounds like it's an issue with Latency try downloading ASIO4All, that may help.
Posted on Dec 16, 2010
    Problem Solver:
  • 23 Answers
I don't 100% understand why Cubase does this. I'm assuming it's a memory (RAM) problem. If you record loud and clear anough you can just drag the tracks to where they're meant to be afterwards because you can see where they go relative to the other tracks
Posted on Sep 16, 2010
No vocals on recorded disc
You need to check your setup's recording volume and interface. You did not mention if you are trying to record from RCA or digital inputs.
It sounds like your recording level is not set up to catch all of the music. I'd love to buy a unit which cuts all of the whiney vocals from good trance music it is very hard to do with all of the layers of recording.
Feb 07, 2014 | Tascam Cd-rw900sl Cd Recorder/player
Weak lead vocals
This is often caused when an earth wire touches a channel wire, check all your connections, especially those to the cartridge.
Jan 26, 2014 | Crosley CR249TA Turntable
Hallo i have cubase sx3 I can get my backing music onto track one via importing it from docs - no problem - how do i increase the volume on record as the tracks from vocals dont come out loud at all ,...
You must adjust the record level from the input device - i.e. mixer or soundcard. There is no input level control within Cubase. It is often the case, however that the problem lies with the backing track being too loud.
May 28, 2011 | Steinberg Cubase SX3 (502010600) for PC,...
How do i get levels from my g track mic im using cubase le 5 i only get one side level how do i fix this issue?
The mic is only on the Left channel, and instrument input is on the Right channel. So in Cubase you need to select only the Left channel in your first track, and then only the Right channel in your second track, and then you can record Vocals and Instrument at the same time on 2 different tracks.
May 02, 2011 | Samson G-TRACK USB RECORDING MICROPHONE...
All my vocals are recording late oner my tracks how do i fix that?
you need to make sure that you are using the M-Audio sync and not your sound card to sync voice. I guess you could use your sound card but make sure your instruments are using that sync too. most sound cards don't do well at recording audio in an environment that includes instruments being recorded at the same time.. If you mic has line in or instrument in, use it instead of sound card to record your instrument.
If what you are doing is singing along to a sound track then use the same sync for both.
Mar 17, 2011 | M-Audio Producer USB Microphone with...
Using a Tascam US 122 with Cubase SX, when recording vocals red light (clipping) on the Tascam and in the Cubase mixer, I need to know how to set levels on Tascam, so there will be no clipping on vocal...
Make sure the switch is set to "mic/line" and not "guitar"
Your input level will be set by the "input L" or "input R" knob, depending on which side you are using. Start with them all the way down and then sing into the mic, turning them up until you get a signal about halfway up the bar in Cubase. That should give you plenty of headroom for clean vocals.
It may be difficult to get a good sound if you have one of those cheap mics that has a "1/4" jack instead of a 3-pin XLR jack. You might want to go to your local music/pro audio store and invest in a "condenser" microphone, which is good for vocals in the studio.
Feb 26, 2011 | Tascam US122 Audio/MIDI Interface with...
I am trying to record in multi track mode-want to know how to record for example vocals on track one then without erasing the vocals add for example harmony or guitar so i get two things on one track. At...
How multitrack recording works is assigning each recording to a different track. A way around this is to record the vocals to track one, then your harmony to track two. Save that as a single recording, or mixdown, then open that saved mixdown to track one. You may need to be connected to a computer to do this.
I use the same technique when using Cool Edit Pro (outdated, yes, but I've been using it for 4 years, and I know most of the ins and outs), especially on the guitar tracks, where for studio sound, you've gotta use 4 total tracks. Putting two tracks together frees up your processor, and uses less in the way of effects, as well.
Hope that helps!
Feb 07, 2011 | Samson Technology Zoom H4n Handy Recorder
Recording vocals while the music tack is playing simultaniously
it's not supported on that or any earlier sony software that I know of. have you tried running the program twice (simultaniously) and playing on one while recording on the other then mixing the tracks together after??
Apr 26, 2009 | Sony Sound Forge Audio Studio 9
Tascam Us144 and Sonar3 problem!!!!
Try this experiment:  Record a click track on track #1.  Record track #2 of the output of a monitor speaker playing track #1.
Now you have two click tracks which will probably not be cooincident (like they should be).
Measure the offset of the two tracks!  You now know your latency exactly, and can compensate by adjusting settings or moving the vocal track back manually that many milliseconds!
Apr 06, 2008 | Tascam US-144 Sound Card
Playback is faster than recorded
close that windows
now click on it again (left click) and choose mixer
Does your mic show up there ?
Jan 11, 2008 | Creative Labs Sound Blaster Audigy LS...
Open Questions:
See all Steinberg Cubase SX3 Questions
Computers & Internet Logo
120 people viewed this question
Top Steinberg Computers & Internet Experts
Raghavendra Nagaraj
Raghavendra Nagaraj
Donald Currie III
Level 1 Expert
 Grubhead
Grubhead
Are you a Steinberg Computer and Internet Expert? Answer questions, earn points and help others
