Question about Sony 4GB Memory Stick PRO Duo Memory Card
My memory stick is write protective and i can`t solve it. how can i solve.
  • 6,831 Answers
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Aug 20, 2010
How to remove write protection from sony memory stick pro duo
There should be a small plastic catch on the side of the card which allows you to write protect the memory stick pro duo. It should have an image of a lock or say locked next to it, if it is locked you won't be able to write to it. Slide it to the unlocked position using a fingernail or a paperclip.
Apr 29, 2015 | Sony Electronics - Others
Camera keeps telling me to reinsert the memory card. I've tried to new cards. When I put the memory card I was replacing because it is full, it goes back into the camera just fine.
As a last resort you could copy the full card to a computer and then delete the pictures on the card and use that again.
Here is the error list from the camera manual.
This is all I can suggest from here.
"Reinsert the Memory Stick Error"
Insert the "Memory Stick Duo" correctly.
The inserted "Memory Stick Duo"cannot be used in your camera
(See below).
The "Memory Stick Duo" is damaged.
The terminal section of the "Memory Stick Duo" is dirty
Compatible cards.
Memory Stick Duo (without MagicGate)
Memory Stick Duo (with MagicGate) *1 *2
MagicGate Memory Stick Duo *1
Memory Stick PRO Duo *1 *2
NOT compatible
Memory Stick (without MagicGate)
Memory Stick (with MagicGate)
Memory Stick PRO
Some Memory Stick Duo have a write protect switch on the back.
You cannot record, edit or delete images if you
slide the write-protect switch to LOCK with a
fine-tipped object
*1
"Memory Stick Duo", "MagicGate Memory
Stick Duo" and "Memory Stick PRO Duo" are
equipped with MagicGate functions.
MagicGate is copyright protection technology
that uses encryption technology. Data
recording/playback th
at requires MagicGate
functions cannot be performed with this
camera.
*2
Supports high-speed data transfer using a
parallel interface.
Oct 12, 2014 | Sony Cybershot S650 Digital Camera
The disk is write protected
You only can use Memory Stick Duo. There is a write protection switch on the memory card, you only can switch with a sharp point. Ball point or something like that. Have a close look on the card.
"Memory Stick Duo", "MagicGate Memory Stick Duo" and "Memory Stick PRO Duo" are equipped with MagicGate functions.
MagicGate is copyright protection technology that uses encryption technology. Data recording/playback that requires MagicGate
functions cannot be performed with this camera.
So if you have a MagicGate one it does not work and could give this error.
Nov 06, 2013 | Sony Cyber-shot DSC-W50 Digital Camera
My memory stick is write protected...i cant add/delete files.
CHECK if it is not physically protected, a small button/switch might be on the stick!
THEN, try any other flash drive or memmory stick to locate the target problem (memorry stick, or usb port mulfunction or even security/driver issue).
PLUS, there are some programes that might protect flash drives, check if u have any, and uninstall them, and make sure u have deleted ther HIDDEN system files located on the stick!
gd luck.
Jan 01, 2010 | Electronics - Others
How I remove the writw-protection to the memory card
Hi!
In order to remove write-protection from the memory stick, connect it to the device in which write-protection was implemented on it then use the feature of the device to remove write-protection off the memory stick.
Should you require any clarification, you may write back.
Give a try!!!!!
Sep 16, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How to remove usb write protection with notebook
Are you having trouble writing to a USB memory stick and you get a message that the USB memory stick is write protected?
Some memory sticks have a small slide switch which you can select to write protect the data on the USB memory stick.
Jun 18, 2009 | Acer Aspire 4720 Notebook
Write protection on a Memory stick
mm? did you copy pasted or something in the right map of your stick, or did you delete something from ure stick accidentally?
Mar 21, 2009 | Sony 2GB Memory Stick PRO Duo Memory Card
PSP Sony memory stick has write protection how do I remove this
You should have a small notch on the memory chip itself you just need to switch that off. look closely cos this might be very small.
Feb 22, 2009 | Sony Memory Stick PRO Duo (2GB) for PSP
128mb Sony Memory Stick Duo
            This is a common problem and its quite easy to resolve.
I had a very similar problem with a friends nokia 5200 memory stick , it refused access to the card , i got the message disk is write protected I couldnt even access it from a PC card reader or format it .
             Somehow he had accidentally set a security code for the memory stick and the mobile then forgot he had done it , I tried the usual code of 1,2,3,4 and this didnt work.
        When I tried the number 1 on its own , suddenly I could access the memory stick again and format it and didnt get the message (disk is write protected)...Reset your P800 security codes with the master reset function in the main settings menu.This will remove any codes that restrict access to the memory stick...
Sep 03, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Sony 4GB Memory Stick PRO Duo Memory Card Logo
105 people viewed this question
Top Sony Electronics - Others Experts
Sandy Moore
Sandy Moore
 Grubhead
Grubhead
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
