Question about Cobra microTALK LI6000-2 (14 Channels) 2-Way Radio
The problem of my cobra microtalk LI6000 cannot receive a call when i'm pressing the push to talk even the other pair do you have a repairing outlet here in philippines?
    Problem Solver:
  • 12 Answers
WALANG REPAIR SA PINAS. SUPOT ANG COBRA SERVICE DITO. MASKI GAWA PA DITO SA ATIN, WALANG SAYSAY
Posted on Apr 11, 2014
  • benoit c
    benoit c May 19, 2014
    Push 'call' on radio A while radio B is on 'scan' mode. Your two radios will probably wors on two different channels. For instance, my radio A is on channel 20 and my radio B is on channel 5.
  • 14 Answers
SOURCE: Constant RX mode on cobra microtalk PR3850WX
Sounds like the radio was subjected to electrostatic discharge. If you have your manual, and it describes a way to do a "master reset" on the radio, follow the instructions. This usually involves pushing down on one key while turning the radio on. Otherwise you have to find a licensed dealer for factory service, as there is no way to repair the radio yourself. The use of surface mount technology still confuses many Techs unless they have been to a company's two or three week seminars.
Posted on Jul 24, 2009
zeusfaber
  • 247 Answers
SOURCE: Brand New Cobra microtalk won't work!
Double check against all the instructions - in particular, make sure the batteries are charged according to "before first use" spec, that the volume is turned up, and that the squelch (if fitted and not automatic) is adjusted properly. If it still doesn't work, take it back to Wal-Mart. If the product doesn't work, there's no need for the packaging to be in good condition - it's not as if they'll be needing it to resell the goods to anybody else. A.
Posted on Apr 08, 2007
Gavin93
  • 66 Answers
SOURCE: Cobra microTALK PR 3500-2 DX VP 2-Way
The Cobra microTALK PR-3500-2 DX VP Radios are supposed to be equipped with acoustic noise filters that are built in the microphone. This problem could have been caused from the radios getting wet, damaged, or the microphone going bad, the microphone can be replaced if you still have the warranty, but if you want to save money you may wan to get a new set of 2-ways. I suggest the Uniden GMR325-2, these models are inexpensive and have an approximate 5 mile range in good conditions.
Good Luck!
Posted on Jul 05, 2008
Agent Ken
  • 250 Answers
SOURCE: Constant RX mode on Cobra Microtalk Walke Talke
Hello CleanRightCo,
Many two-way radios have a Monitor function that disables the squelch control. The squelch is what keeps the radios quiet when they are not receiving an incoming signal. However the squelch feature can also cause weak signals to cut out and not be understood, so the Monitor function provides a way to disable the squelch in those circumstances. It sounds like you have the Monitor enabled / squelch disabled on the units that you hear constant static.
For the Cobra MicroTalk 4100 it appears that you enable the monitor by holding down the Light/Max Range button for 5 seconds until the radio beeps twice. You may have activated this function inadvertently. To disable the monitor and re-enable squelch simply press the Light/Max Range button again or change channels.
If this doesn't fix the problem there may be a problem with the auto squelch function on the radios. Or the channel you are operating on may have a noise level that is above the radio's squelch level. You can try changing channels. Or another possible solution would be to activate the CTCSS (Continuous Tone Coded Squelch System) on all the radios. This function will mute the radio's receiver unless a signal is received from another unit using he same CTCSS code. This should keep the units quiet regardless of the noise level on the channel. However all the radios MUST be set to the same CTCSS code or they will not be able to communicate with each other.
Best Regard
Ken
"Go Ahead. Use Us."
Posted on Jul 07, 2008
kditterline
  • 127 Answers
SOURCE: I too need a charger for the Cobra microtalk Walkie Talkie
u can use a phone charger as long as the jack is the same as your jack, walmart has about any kind they make.
Posted on Jul 16, 2009
Cobra microtalk
Please mesure the battery voltage first...then get the service manual and check if there is an smd fuse right next to power pushbutton....please inform me for any progress...thnx..
Feb 24, 2014 | Radio Communications
One of my Cobra Microtalk radios is stuck on RX. Everything else seems to work. What could be the problem?
Hi!
Almost always, the problem here is that the micro switch for the Push-to-Talk (PTT) button has failed. Your radio should have a warranty, but even if the warranty has run out, it isn't horribly spendy to fix. I'd get in touch with Cobra Electronics, I have heard they're extremely helpful. Try this link and good luck!
https://www.cobra.com/help/
Jul 05, 2011 | Cobra Electronics microTALK® PR 3850 WX ...
I have the Cobra micro Talk LI6000-2 (14 Channels) 2-Way Radios and one turns on and charges and the other will not turn on for anything. They will not charge unless turned on and on the charger; so one is...
  • The fact that these turn on while on the charger is an indicator that the batteries are just that far gone. Depending on how much you like these radios vrs the cost of a new set is something to think about.
  • This link is where you can get a reliable battery replacement.
http://www.batteries.com/battery/cobra/103-0001-1-battery_R-414884-205946.html
  • I use a newer Midland talk around for camping, hiking etc. The thing I always look for in a talk around radio is if the manufacturer battery goes bad or runs dry can I use some batteries at home with it? I like the fact I can put 4AA batteries of the shelf in my radio in an emergency. And when the stock battery gores kaput, I can use some AA rechargeable batteries I already have at home and save on replacing the battery or radio. Something to think about should you decide to get a different radio set.
Regards, Tony
Apr 27, 2011 | Cobra microTALK LI6000-2 (14 Channels)...
How to get it off vibrate, i lost manual
Press the Mode button until the Call Setting icon flashes on the screen. The current setting ("01"
vibrate + ring, "02" vibrate only or "03" ring only) will be displayed. Press the Channel Up or
Channel Down button to change the call setting.
More programming details (with pics) are available in the user's manual which can be downloaded HERE
Nov 20, 2010 | Cobra microTALK LI6000-2 (14 Channels)...
Need Batteries for Cobra LI6000-2xz
most use rechargable battereys from the shops
May 08, 2009 | Cobra microTALK LI6000-2 (14 Channels)...
I cannot get one of the radios to turn on. I've tried a good battery to no avail
Your fuse is blown, not sure if you can replace it.
Some of our radios you have to take quite a bit apart to get at the fuse and replace it.
Apr 20, 2009 | Cobra microTALK LI6000-2 (14 Channels)...
Cobra microtalk2 auto squelch not functioning
Dear sir,
Use maximum range button which is also light button ( keep it pressed for 5 sec ) u will hear a beep , then relase it operate ur radio in High power transmission mode , ( channel 1~7 ) or 16-22 ( ckeck ur country lcense guideline before that ) .
Regards
Raj
Apr 02, 2008 | Cobra microTALK LI6000-2 (14 Channels)...
Cobra microtalk Li16000-2 (14 channels)
Dear sir,
Its important to remove batteries from circuit if u are shutting down the unit for long period . Your battery is in deep discharged mode now , & charging is not so easy , or consider it dead as LI-ion batteries have a specific life .U can find the same in ebay usa website available between 7~12 USD per pair.
Regards
raj
Feb 11, 2008 | Cobra microTALK LI6000-2 (14 Channels)...
Cobra microTALK LI6000-2 (14 Channels) 2-Way Radio Logo
235 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
