Question about HP Color LaserJet 2600n Printer
When I try to print on HP Color LaserJet 2600n. black color doesn't appear. I changed the cartridge but the problem still. I test the cartridge on another printer and it's ok.
  • 225 Answers
The cartridge is missing contact from the drum to the ground. When this contact is missing, the charge from the the laser exposed areas on the drum cannot disappear and the result is lack of image.
Remove the cartridges and compare the connecting pins of the nest for the black with other nests. One may be bend and loosing it's contact.
Posted on Aug 21, 2010
HP LaserJet 2600N All colors are empty, but Black is brand new. It still says Replace Supplies and the light keeps flashing. Oh, and it won't print anything. So even if I want just B&W, do...
None of the cartridges can be empty if you want to print.
Even if you only want to print black, just black you need to
replace the other three cartridges.
Yes color laser printing is expensive.
Jul 14, 2011 | HP Color LaserJet 2600n Printer
Printer print only black while all cartridges are
Check your printer configuration and make sure you haven't mistakenly set it to monochrome (black and white).
Nov 27, 2009 | HP Color LaserJet 2600n Printer
Hp color laserjet 2600 n it will not let me print
There is an override sequence and it works well. Press the select button (checkmark) to indicate Main menu. Press right-arrow (RA) to select System Setup. Press Select , then RA to Print Quality, Hit select. RA to Replace supplies and hit Select. Now, RA to Override Out and Select. Confirm with Select again. Your 2600n will now run even with an empty toner cartridge.
Jul 08, 2009 | HP Color LaserJet 2600n Printer
Black blocked by magenta
One ovbious option would be to have a friend print it out.
I assume that is not an option.
Some printers just won't let you print if a single color is out. Yes, stupid. Try printing a blank page. If it fails, there is no other option but to replace the cartridge or print elsewhere.
If the blank page test works, this next option/test is worth a try...
Depending on the app you are using, you can specify the color breakdown of the colors you are using. In your case, it is possible that the text is set to a rich black (4-color) rather than just black.
If that is the case, to test this most quickly, make a new file, and create a new black (black2), set to 100 black, 0% other colors.
Type a wor and set it to print in that color and try to print it.
If that works, apply the same technique to your real document.
Hope it works. I've been stuck in the same situation, and some printers will just not let you print if a single color is out.
Good luck.
DigiChick
Jun 09, 2008 | HP Color LaserJet 2600n Printer
TRY TO REMOVE ALL THE CARTRIDGES FROM THE PRINTER . CARTRIDGES WHICH ARE NOT WORKING SLOWLY SHAKE THEM UP AND DOWN WITH YOUR HAND TAKE CARE IT DOES NOT GET BANGED SOME WHERE AND REINSERT THE CARTRIDGES SLOWLY ONE BY ONE THEN TRY PRINTING IF STILL DOES NOT PRINT, YOUR CARTRIDGES MUST HAVE GOT OVER SO CHANGE THEM IT WILL START PRINTING.WISH U GOOD LUCK.
Jun 03, 2008 | HP Color LaserJet 2600n Printer
In printing a black shed all the paper
May 18, 2008 | HP Color LaserJet 2600n Printer
you probably needt o change the transfer belt which is the "black roller film". you can try wipping it off with a dry lint free cloth.
May 16, 2008 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n - Thin White Line on Print Out
Which color is this line? Try changing respective cartridge..
Sep 09, 2007 | HP Color LaserJet 2600n Printer
HP color Laserjet 2600n
The demos are probably all in colour so it can get along without the black. Try printing a word processing file that is in black. USB ports are very good ports - better than the older parallel port.
Aug 15, 2007 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
154 people viewed this question
Seeker5211
Seeker5211
