Question about Hotpoint WMA11 Front Load Washer
One of the three plastic rungs has snapped off of the outside of my washing machine drum. It should clip onto the metal of the drum and without it, the sharp metal edges of the drum where it should clip on are tearing my clothes. Can I replace this plastic part? Five of the six clips have worn away so it does not look as if it can be repaired. If this is a replaceable part, what is it called and where would I buy one?
5 Suggested Answers
SOURCE: One of my drum paddles
i had the same problem and sourced the parts from ebay - 3 for £9.99
Posted on Jan 04, 2009
  • 10 Answers
SOURCE: Hotpoint FEW12 washing machine chews up clothes
If you check the door sal and there is any play in it then it needs replacing. Mine had two saggy indent bits and needed changing..no more ripped clothes
Posted on Jun 07, 2009
pride applia
  • 232 Answers
SOURCE: the plastic separater in the tub has snapped off
need complete model # off the machine
Posted on Dec 09, 2009
barkencoa
  • 3463 Answers
SOURCE: hotpoint wf320 inside of drum their are 3 plastic
They are are referred to as drum lifters or drum paddles. they are replaceable.
Go to the following site to obtain replacements.
WWW.HOTPOINTSERVICE.CO.UK
Click on Spare parts and accessories. and follow the instructions.
Posted on Dec 19, 2010
The machine stops mid way through the wash and stays full of water. I have to drain it at least three times to get rid of all the water and then spin, cloths are still very wet even after spin. It will not...
Sounds like the filter is clogged. The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. Drain out all the water. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. Inside is a white molded cone and a big white ball which floats. You will find a lot of junk here, clean out thoroughly. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip. Check out the pump too before reconnecting.
Dec 11, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Washing machine - DWS-800WPS Error LE showing
LE indicates a fault with the motor on the appliance.
LG suggest you switch off, wait for a minute, unplug the appliance.
Wait 15 minutes then plug it back in again.
Try the machine again.
If it's still faulty, you can try changing the Hall Sensor in the motor, this can sometimes cure the problem.
Unplug the machine and remove the rear cover. There are 4 Philips head screws. Take them out and remove the rear cover.
You should now see the rear of the motor, which is mounted to the back of the drum.
In the middle is a large bolt which holds the stator cover.
You'll need a 17mm socket and a ratchet to remove this bolt.
Remove the stator cover and place aside.
Toward the bottom-left, you will see a couple of wire bunches held to the motor by three screws. One holds a metal bracket, one actually holds a ground wire, and the last is through a plastic bracket toward the bottom. Remove these three screws and don't lose them.
Through the motor there are 6 bolts holding it onto the back of the drum assembly.
You'll need a 10mm socket and ratchet to remove them.
You will now have the motor off the back of the drum.
Disconnect the two wire harnesses from the motor.
Looking at the surface of this motor that was facing the DRUM (not the outside), you'll see two small pieces clipped onto it, toward the bottom.
The sensor you are looking to replace is the one that looks like a kitchen magnet.
It is attached by small clips. You'll see how it goes on. It's easy to remove.
Go to google and search for part number 6501KW2002A.
This will bring up an LG sensor assembly.
Double check with the supplier that this is the sensor for your appliance.
When you receive the sensor, simply reverse steps 1 through 5.
Once re assembled, try the machine again.
If still the same after this you'll need to replace the motor and/or control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Nov 05, 2010 | Washing Machines
My washer has LE, is there something I can do myself?
Sep 26, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
What does LE in my wachine machine WM2277HS mean? Machine is full of water and won't spin.
Sep 11, 2010 | LG WM2277HSW XL Front Load Stackable...
How do i fit the drive belt on a hotpoint wma74 washing machine
Hook the belt over the motor shaft and feed it onto the drum pulley as far as it will go,hold it in place on the pulley with the aid of cable tie clips, then rotate the inner drum anti clock wise by holding the inside of the inner drum. This will draw the belt onto the pulley and the cable ties will snap as the drum rotates.
Mar 04, 2010 | Hotpoint WMA74 Front Load Washer
LG Tromm washer WM1812 CW showing error code LE, what do I do?
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!
Dec 31, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG Direct Drive 7.0 WD-12126RD Error Code LE
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!!
Jun 27, 2009 | LG WM-2277HW Front Load Washer
I have a model WM2077CW LG washer. The LE error
Jun 22, 2009 | LG WM2077CW XL Front Load Stackable Washer...
Le error code
May 01, 2009 | Washing Machines
Hotpoint WMA11 Front Load Washer Logo
108 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
