Question about Vcomm Recovery Commander (804526023624)
I want to delete RECOVERY COMMANDER because it arrives unrequested, freezes my PC and refuses to be cancelled. The only way of stopping it is to reboot. Help please.
    Sergeant:
  • 201 Answers
Hi type cnet in your search engine /type uninstaller in cnet search.
to the left choore option "free" then download revo uninstaller/instal
and use. this is an exy... program use it my self .hope this helps.
Posted on Aug 20, 2010
My laptop says that one of my disks need to be checked for consistency and then stops on 2 of 3 checks with 62% checked. then reads an unexpected error has occured on one of the disks and freezes. I also...
This is not an easy issue to solve using this method (posting text or email) but I will give it a try!
There are many things that can cause the problem you described. Your memory cards could be loose inside the pc. You can try removing & reseating them to see if this solves the problem. Your partician could be damaged. Your hard drive may need replacement. If your pc came with recovery software, you might try turning on the pc & putting the system recovery disk inside the drive & then restart the pc and try booting from that drive to start the recovery process. If your pc came with recovery software installed on a second drive located in your computer, then you need to follow the instructions on how to access system recovery which are listed in your manual and also flash briefly on the screen when the pc is loading windows (you should see something like press F2 to enter recovery briefly on the left side of the pc when it is first starting up. It only displays this command briefly. Try restarting a few times if you do not see it) . Once in recovery, follow the prompts to start the process to see if the pc can recover and start windows normally.
If you choose cancel disk check, and the screen your describing in your post is a blinking cursor where you can enter commands - try typing "help" and press enter to see if it will give you a list of choices to execute. If it is a command prompt and gives you this list, try scrolling with your arrow keys to find disk check or check disk. Windows has options to repair bad areas of particians, but I am unsure if they would go any farther then the test that is currently running and unable to get passed 62%.
If you have an operating system disk (Windows Xp, Win 7, Win Vista - full versions - not upgrade software) that matches what you are running on your computer you can try restoring or replacing the opearting system to see if that solves your problem. Try putting the disk inside the pc and restart to get it to boot from the disk drive. Then replace your operating system with a new version (warning - this will erase all files that were on the pc) to see if that solves the issue. you can also try installing recovery and/or repair files from the operating system disk. Just put the disk in and restart the pc and read the options that come up - then follow the prompts to repair the system.
If you have questions please use the reply or comment link next to your question on Fixya and I will try and continue troubleshooting until this issue is resolved.
Sep 12, 2011 | Computers & Internet
Recovery commander runs too frequently! When I am beginning to access several programs that I consider very trustworthy this #*%@ recovery begins it's 5-51 check points and takes up to 10 minutes. I...
For you to Stop it you need to stop the services running for it. Follow the steps below.
Click on Start and then Click on run. Type msconfig. In the System Configuration utility screen click on services tab (Its on the Top). Once you are on that screen check the option Hide all Microsoft services. Then look for Recovery Commander. Uncheck that. Uncheck the Hide all Microsoft applications again. Click on apply. Then click on OK. Reboot the computer. You will System Configuration utility screen. Check the Option Don't show this message again and then click on OK.
Note: DO NOT uncheck any Microsoft Services.
If you want to delete it or remove it from the computer then install Revo Uninstaller (Freeware).
Oct 20, 2010 | Vcomm Recovery Commander (804526023624)
How do I disable Recovery Commander on Windows 7? It's so annoying that every time I launch a MS Office application the Recovery Commander is launched.
Sep 21, 2010 | Vcomm Recovery Commander (804526023624)
Recovery Commander (804526023624): recovery commander pops up whenever i try to do an...
May 17, 2010 | Vcomm Recovery Commander (804526023624)
Recovery Commander
Revo Uninstaller is a very very good uninstaller for removing unwanted programs simply point the program to the file you want to uninstall and it will remove all traces of the program. you can get a free 30 day trial which can be used to uninstall Recovery Comander thanks
Steven
http://www.revouninstaller.com/
Apr 24, 2010 | Vcomm Recovery Commander (804526023624)
Hp Laserjet P1007 taking too much time to cancel print command
Boss their three things can be possible for this
First the operating system,
second your printer driver and third your printer or your pc is old and need to be serviced.
So step one: delete the driver(whatever your model no.)of your printer, turn off your pc and reboot then install this again, I hope this will solve your problem.
Step two: connect your printer with any other pc(turn off your pc connect power cord into wall socket and connect U.S.B. cable with pc, Now turn on pc and the printer) which have the spesific printer driver installed.
thanks
TTYAGI
Jun 26, 2009 | HP LASERJET P1005 Printer
Having problems deleting pending documents
Assuming you have a modern windows pc, You will need to manually stop the print service. Do this by running the command "net stop spooler" from the "run" line. Then go to "C:\WINDOWS\System32\spool\PRINTERS" and delete all the files from there. After these files are gone, start the spooler service again by running "net start spooler". You should be all set after that.
Jun 09, 2009 | Office Equipment & Supplies
Printer stopped working
Turn printer on and off if that doesnt work then ust restart, sometimes things get stuck in the queue.
Apr 24, 2009 | Lexmark X1150 All-In-One InkJet Printer
Removing the program
I have the same problem but have tied mine down to Fix It Utilities which were downloaded. If you have Fix It the solution appears to be run Fix it, at the top select 'settings' then on the left 'recovery', then 'recovery commander' on lower top toolbar. Uncheck 'Detect when a set up program is launched....' and that should cure it.
Aug 11, 2008 | Vcomm Recovery Commander (804526023624)
Vcomm Recovery Commander (804526023624) Logo
51 people viewed this question
Top Vcomm Computers & Internet Experts
David Payne
David Payne
Are you a Vcomm Computer and Internet Expert? Answer questions, earn points and help others
