Question about ASUS VW192S Monitor
What should i do to my monitor?
Pleasant day
sir i got my problem to my pc monitor which is rhine product, it turns on but it not make any display. i already try my pc to connect with the other monitor and yes it's turn ok. so pls till me what should i do to my monitor? i already clean the monitor using a fan blower but still not displying... pls help me
"thanks and god bless you"
I already answer this in other post, but ill try too help..I got the same problem, and th only way i make it work is too remove the power cable and plug it back on..it works..at least for me..but today im taking it to the assistance..
regards
Posted on Jan 31, 2009
If i select source to pc display will become blank and power indicator blinking.
• You can check if the product is working properly using the Self-Diagnosis function.
• If a blank screen is displayed and the Power LED blinks even if the product and the PC are properly connected, perform
the self-diagnosis function according to the procedures below.
1. Turn the product and the PC off.
2. Separate the signal cable from the product .
3. Turn the product on.
4. If the product is working properly, the message appears.
In this case, if a blank screen is displayed again, make sure that there is no problem with the PC and the connection. The
product is working properly.
Is a blank screen displayed and does the power LED blink at
a 1 second interval?
1. This occurs when the power saving function is running.
If you click the mouse or press any key, the screen will be
turned on.
2. This occurs when two monitors are connected,
is and Magictune is running. In this
case, characters on the Magictune OSD may appear
corrupted. To run the Magictune, the must
be set to . Please restart your PC, set the
to and run the Magictune.
Jul 07, 2011 | Samsung BX2231 21 inch Monitor
Need a BIOS update for a Sony VAIO PCV-RZ49 (T99861234) PC Desktop Sony provides nothing.
Why do you need to update your BIOS? There may not be an update for your product, as not every BIOS has updates, that depends on the manufacturer. I hope this helped. Good lusk and have a pleasant day.
Jun 25, 2011 | Sony VAIO PCV-RZ49 (T99861234) PC Desktop
I have a HP Pavilion a6430f PC and I'm trying to add a second monitor. After a software update my computer will not recognize the second monitor. Do I need to purchase an upgrade to my current NVIDIA...
go to control Panel and look in the Display settings, you should be able to see your video card in number one monitor as well as in number 2. I hope this helped. Good luck and have a pleasant day!!!
Jun 19, 2011 | HP Pavilion A6430F Desktop PC
My e152fb dell monitor was not working..
Dude your problem was so similar to the problem that i have encounter yesterday with my client.
Problem: when she turn on the system unit it is OK. but the monitor displays only the orange LED below the monitor but no hardware information display on it. Solution: The problem is on your system unit peripherals upon over heat due to use of the pc.
Apr 09, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
Hello Sir, I am using DELL E173FP LCD monitor. My CPU absolutely fine I see initially booting thing on my monitor display then it gets black. I can hear starting sound of Windows XP, that too is fine. When...
You might need to change the screen refresh rate. Go do Control Panel> Display> Setting> Advance, choose 60 Hz. In order to make your Monitor able to display, restart the PC, press F8 on the keyboard frequently upon splashing ( 1 or 2 seconds after PC restarts). Select enable VGA mode by pressing up arrow of the keyboard> press enter. The display should look bigger, then you can start adjusting the screen refresh rate to 60 Hz
Apr 09, 2010 | Dell E173FP 17" LCD Monitor
Why our HP L1740 17" LCD monitor has no display at all but had power
Good Day sir/maam, lets try to make sure that the LCD is the problem and not the CPU,
  1. Swap your LCD to a good CPU, to check if the LCD is good (visit a friend who has a PC).
  2. Or as you boot your PC, did you hear a single beep? and
  3. Does your PC hard disk led blinks.
If you insist that the LCD is the problem, you may need to check first your dealer for advice.
Oct 20, 2009 | HP L1740 17" LCD Monitor
When I start my computer up my Philips Monitor
Good day sir/maam, hi, the problem may not be your monitor but your PC, they produce the same symptoms if your PC has no video to display. does your monitor led/lamp lights up as turn on your computer? If you want to test your monitor, go bring it to a friend who has a computer, test it there. if it works, your pc has a problem, so try the following first.
  1. Open you PC side cover, locate the memory module, remove the momory by releasing the side clamps. clean the contacts using an eraser (pencil) then put it back, you will clicks as you put it back on, test again. Do it several times if the first try fails.
  2. Check your Power supply, does it gives out hot air exhaust?
  3. Did you hear one beep, (good) or several beeps(bad).
  4. As you power on the pc check your keyboard light, first set of lights (Num lock+Caps Lock+ Scroll lock) then second set of light (Numlock only). At this point your pc is good.
Hope this helps, let me know your progress.
Oct 08, 2009 | Computers & Internet
Delay time when My monitor is turned on...
It seems me that ur monitor is too old thats why..
Dec 01, 2008 | Computers & Internet
ASUS VW192S Monitor Logo
73 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
