I have an old and reliable pair of AR8 speakers but have to get a new amplifier. As I do not know the wattage of my speakers I cannot safely buy an amp for fear of blowing the speakers. Does anyone know what the wattage is?
2 Suggested Answers
SOURCE: Max. wattage for speakers w/ Technics Receiver SA-GX100?
I too have a Technics SA-GX100 and it's rated at 2 x 40W @ 8 Ohms. I have the Technics SB-2840 floor model speakers hooked to it, which are rated at 200W Music Input - 8 ohms. It sounds very nice just to be a 40W receiver.
Posted on Jun 12, 2009
I have 4 speakers one pair of speakers are 150w and the other pair of speakers are 120w could someone tell me what speakers are louder because I don't know ?? my amp is 100w?
There are too many factors and variables to consider when it comes to speakers. Yet, the general rule is the lower wattage speakers will be louder than the higher wattage speakers because they require less power to drive them.
Then the other things to consider is the actual construction of the speaker and if they are mounted just on a surface in a car or whether they are mounted in an enclosure.
Then I don't have enough information about the amp. Is it set up as a four channel amp, or are you going to run the speakers in series or parallel front to back? Personally I would add a second amp so there is an amp for each pair of speakers. You can purchase all sorts of extras at car audio stores such as faders between the two amps, or a crossover device with performance controls such as bass, midrange, and treble.
Yet, if you are determined to stick with what you have, and your amp is only two channel, then run your speakers in parallel going first to the high watt speakers.
Apr 16, 2016 | Car Audio & Video
Can u tell me what amp I need to run my 2 x 400w EV sb122 bass speakers and 2 x 300w EV sx300w top speakers
The wattage listed on the speakers is the peak wattage the speakers are rated to handle. You need amplifiers that do not exceed that maximum. A 50 watt amp would drive them fairly well but you would do better with a 100 to 200 watt amplifier. Note: the speaker rating is peak power handling. Amplifiers these days are usually rated at peak output too but sometimes (old or very high quality) amplifiers are rated at sustained power (RMS). If you are working with one of these amplifiers you will need an amplifier with a lower rating. Also make sure the amplifier is designed to run the same load as the speakers. This is usually either 8 ohm or 4 ohm. Make sure the speakers and amplifier are rated the same.
Apr 17, 2013 | Audio Players & Recorders
Bose 321 power woofer buzzes but produces no audio sound
I assume the other two speakers are working fine. Contact Bose and ask them. Could be a simple fuse. Sounds like a fried speaker driver, but do this first. Take the back off and check the power amplifier for a blown fuse. If none, disconnect the power amplifier. Reconnect the speaker cabinet w/o the built-in power amplifier to a known good amplifier to see if the speaker works. If it works then you know its the built-in power amp that's fried. Contact Bose for a replacement or better yet buy a another one with a higher RMS watt capacity. Wattage ratings in other than RMS are worthless. JBL and Cerwin Vega produce high wattage units. You need to keep the volume lower to avoid the problem in the future.
Aug 27, 2012 | Bose Audio Players & Recorders
I have amplifier 4ohms .i want to match a spaekers to build up onkyo amplifier
The 4 ohms impedance can be matched depending on waht WATTAGE is required by you.
Also the type of speakers that you desire is also important. You can buy 4 ohms speakers or use two 8 ohms speakers in parallel . But the important factor is the choice of your music and the wattage. If there is a use of passive crossover network or active crossover network we need to consider to buy the matching speakers.
Aug 01, 2011 | Kitchen Ranges
I have five pairs of 8 ohms speakers which i want to connect in serries. what wattage will you advice ?
Why? Amps are designed for specific loads, typically 8-ohms. I'm sure you could arrange several speakers in such a way as to present as close to, say, 8-ohms as possible.
Feb 15, 2011 | Behringer EUROPOWER EP2500 Amplifier
I have just bought a used Sony Integrated amplifier TA- F210 and it didn't come with the owner's manual so I don't know the RMS wattage to enable me connect speakers with the appropriate wattage. Could...
Hi, I brought a Sony TA-F-210 new back in 1990 $ 650 NZ , and has been a very .. very good amp. Earthquake ruined it !! I still have the owners manuel and it says for UK and other countrys DIN, 1 kHz, 8 ohms . 70w + 70w . or . 20Hz-20kHz THD 0.05%, 8 ohms . 50w + 50w Hope this helps. Have been running big old 3 way 8 ohm 50w speakers for all its life and it grunts.. or did !! Nobody belived me I was running only 50w speakers !! I dont know what I will replace it with.. You will enjoy. Might look for another one ! Wayne.. NZ CHCH
Nov 26, 2010 | Audio Players & Recorders
I bought a mixer with this model "Behringer XENYX 1204USB 12 Ch USB Mixer". And i'm planning to have a set-up of 2 electric-acoustic guitars and 3 microphone vocals. What would be the best wattage of...
Hello Sir, Hi, the amplifier best suited for it would be a Behringer also, the EP2500 would be a match, and the eurolive B815neo speakers, but this cost a lot, any amplifier and a corresponding speaker will do. for your electric guitars or acoustics the GTX30. If you will use your 15" speakers, match it with a right amplifier, you did not mention its watts rating, If your speakers are 250 watts, then buy an amplifier slightly higher that 250 watt,
Aug 19, 2010 | Behringer EUROPOWER EP2500 Amplifier
Is my 1200 pioneer amp a good match for my 1200 watt pioneer sub
this is too close, your speaker wattage is alway's higher than your amplifier's wattage alway's to be safe because the hard pounding will make the speaker work harder, and this will cause your speaker burn out easily, though you can adjust your amplifier anyway's
May 08, 2010 | Pioneer TS-W307D2 12" 1200 Watt Champion...
Which speakers can I use?
You can use any wattage speakers as long as they are not less than the watts from your amp. However you can still use lower wattage speakers as long as you don't turn up the volume full or two loud! Otherwise your damage the speaker.
HOWEVER you must get the ohms matched up right. You must never connect any speaker with a low Ohm to a high rated amp. Or you will blow the output stage transistors or IC.
Most Amps are 8 ohms, so you could connect an 8 or 16 etc, but not a 4 ohm.
Dec 10, 2008 | Audio Players & Recorders
Installation a new speaker in stock sound system
One thing you should know when you install the new speaker it is going to pull most of the power away frrom the factory speaker. In order to get the true sound of the speaker, remove the factory one..I know that the door panel might give you trouble, but it will be worth the trouble..If you tell me what kind of car you are working with, I can help you remove the panel easy.
Dec 21, 2007 | Dynaudio MW 160 Car Mid-Range
 Grubhead
Grubhead
