Question about Nintendo Wii Console
I just bought a new television and I can't seem to hook up my wii console. The TV has 4 HDMI ports, 1 component port, and 1 RF port. Also has one for the computer. How do I hook up my comcast cable box and the wii at the same time with only 1 component port?
  • 1 more comment
  • daaig Aug 20, 2010
    I also would like to connect my dvd player...
    Thanks for the help!
    Very helpfull and fast.....
  • 857 Answers
The first step is to connect the Wii to the LCD TV : You will notice that the Wii comes standard with an AV cable. If you wish to connect the Wii to the LCD TV using this cable, the steps are very straightforward. Simply insert the multi-out plug, which is the flat end with a single connector, into the "AV Multi Out" port on the Wii game console. The other end of the AV cable has three plugs: a yellow video connector; a white left audio connector; and a red right audio connector. Most LCD TVs offer several AV ports, on the back, side or front of the television. Find three AV ports and plug the yellow connector into the yellow port, the white connector into the white port and the red plug into the red port.
Splitters and HDMI Adapters
However, you might only have one set of AV ports on your LCD TV. Perhaps this is already in use by a different game console or another device, such as your DVD player. If you want to leave the existing device connected to the LCD TV but would like to also connect the Wii console, you have a couple of different options. One is to purchase an AV composite video splitter, sometimes called AV distribution amps. This adapter may allow you to connect the Wii along with other devices, even if there is only one set of AV jacks on your LCD TV.
LCD TVs typically have HDMI ports, which are used to connect other high definition devices to the television. While Wii games are not yet high definition, you may be able to use this port to connect the Wii to the LCD TV. This connection would require the use of an HDMI to AV adapter, such as a Component AV to HDMI converter. This device allows you to connect AV sources, such as the Wii to HDMI displays, such as an LCD TV. There are a couple of caveats to consider regarding this solution, though. First, it is important to note that Nintendo does not support this type of connection. While some users have successfully used this type of connection, you might experience poor quality audio or video, or it might not work at all. Second, you should consider the cost. This type of converter sells for around $200. It might be easier and more affordable to unplug another connected device from the LCD TV and plugging the Wii in when you want to play.
Posted on Aug 20, 2010
I'm trying to hook up my wii you to my tv but tv only has one hdmi port that I need for the tv. How can I hook up both wii you and tv if only one hdmi connection on tv?
You can purchase a mult-HDMI box for small amount of money on Amazon. com just type in a search for it. I have one and it works fine, it takes one port and makes 4.
Mar 08, 2015 | Televison & Video
How do I start what dose the tv have to be on tv
Neither HDMI ports. The wii can only be hooked up via AV or Component cables.
Sep 21, 2013 | Nintendo Wii Console
Connecting wii to Sony bravia tv
If you have an old V.C.R that has Red, White and Yellow sockets for AV and it still works then plug it into the RF socket tune the V.C.R to your TV and connect your Wii to the Red,White and Yellow R.C.A connections and you should be playing in no time. I have done this myself on a new Samsung TV it will work. If you have no V.C.R and you have HDMI sockets in your TV you can buy an adapter to convert the existing AV port on the Wii to HDMI then simply connect a HDMI cable (if you have 1 if not they are cheap enough off eBay starting at $6.00+AUD or around $20.00AUD Retail) to the Wii and then the TV ensuring that both the TV and the Wii are powered down prior to connecting any cables at the back. The HDMI Adapter for Wii is available on eBay from $5.00 AUD to $24.95AUD depending on the country you purchase it from. If all else fails a second TV with Red, White and Yellow RCA plugs will work but also the most expensive of the fixes. All fixes suggested will work. Good Luck I hope this helps.
Jan 12, 2013 | Nintendo Wii Video Game Consoles & Games
All hdmi connections not working on a samsung ue40c8000 every thing else seems to be ok. done a factory reset does this sound like a new board costly? regards. Norman
The tv Samsung refurbish main tv Turner signal board will set u back like $120-130 bucks + shipping and handleling and u must have to have some basic mechanicals skills like take things aparts and putting it back togther again to fixed this tv just for the used of those HDMI hubs ports again.My questions to u is?Does ur tv used 100% must require those useages of those HDMI hubs ports.Not just used the Samsung tv as is.My Samsung tv have the same problems.I just work around it by skipping all the useages of all those HDMI ports hubs of the tv altogther.Most poeple just used about like 3 HDMI ports hubs for like a HD cable box or DVR cable box and a PS3,WII games systems or Blu Ray DVD player.All these devices can go through hook up for like a RCA component cables hook up like AV1,AV2 and last one a HD hookup by a RCA component cable just add 2 more components wires like a green and purple connections or just buy a set of RCA components cable that design for a HD output.I did that,must more reliable set up too.Because those RCA components cables set up have more plastics in it connections for insulation holes for little shorts and sparks better than those HDMI ports hubs and HDMI cables barely help and the plastic for insulation is a joke almost non exiten.Those all dam HDMI ports hubs are all link into one path way on the circuit board,one dies or got shorted all dies and get shorted out.
Aug 14, 2011 | Televison & Video
Wii to Philips LCD TV 32"" - sound but no video. Just bought a refurb. Philips LCD TV for our WII. The standard AV cable gave sound, no video. The warning message flashes up in the beginning...
Looks like the AV port in your Philips television is busted. It's the only factor if the Wii is able to function with other tv with the same cable. You can either purchase a new television/get the one you have fixed (these will cost money) or you could just purchase an hdmi cable which doesn't use the same port so it could possibly work with your Philips television.
Jul 07, 2011 | Nintendo Wii Console
I tried to hook my wii to the new hd led flat screen but its black and white I tried doing the yello cable to green but it doesnt work and all the other inputs dont have ac jacks its just hdmi hookups
The yellow cable is RCA component and it sould not be connected to the Green port. Why not get a HDMi cable to make the hook up easier? Component RGB connection requires a RGB cable along with a stereo audio cable where as HDMI requires just one.
Jun 10, 2011 | Nintendo Wii Console
I am unable to find a HDMI port on the above tv. is there one? if not is there anything i can get to connect it?
To get hdmi, you need a dvd/vcr recorder with hdmi. Then a hdmi cable to goto vga or component video and stereo connectors. If your TV has only RF input, then you need a rf converter(channel 3 or 4) from component video and stereo connectors.
Jan 01, 2011 | Televison & Video
Cable TV blinks on and off when connected to my Onkyo receiver.
I have the same problem.  It only occurs with my HD DVR (HDMI cable), not my blue ray (HDMI cable), or my xbox and wii (component video).  Video and audio cutout is random and drives the family nuts.  I am desperate for a solution.
Mar 21, 2010 | Audio Players & Recorders
The video/audio outlet port is busted
okay..... nobody else knew what to do so heres what i did and it works. i bought an rf modulator. i hooked it up to the tv, bypassing the original a/v ports (the modulator has new a/v ports) turned the tv on to the channel i selected on the modulator, and now i have audio and video again.... not sure why my video ports went out in the first place (on 3 tvs-see prior posting by me) but at least we can play games now without buying replacement tvs. good luck!
May 22, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
162 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
