Question about Sport & Outdoor - Others
I have just received a roger black silver treadmill which has an error code when it's switched on. It's e00 what does this mean?
Sharp Tech
  • 63 Answers
SOURCE: error code
E1 00
Content
IMC PWB communication trouble
Detail
An abnormality occurs in communication
between the MCU PWB and the IMC PWB.
Cause
IMC PWB-MCU PWB harness abnormality
MCU PWB connector disconnection
IMC PWB ROM defect/data abnormality
Check and remedy
Check connection of the connector and the
harness between the IMC PWB and the MCU
PWB. Check the ROM of the IMC PWB.
Perform the following procedure to enter the simulation mode.
"#" key - Interrupt key - "C" key Interrupt key
14 - Start key - 1 - Start key
Press the C key until copier restarts and code should clear.
Posted on Oct 17, 2009
  • 33 Answers
SOURCE: I have an E1 error showing on my Roger Black Gold
Your problem might be that a speed sensor magnet has fallen off. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Posted on Oct 09, 2010
  • 15 Answers
SOURCE: i need a manual for
You can download the assembly instructions for your treadmill from here:
http://www.fitnessequipmentservices.com/public/manuals/GM41001%20Roger%20Black%20Silver%20Treadmill.zip
That's all I could find, but I hope it is what you need.
Posted on Jun 20, 2011
ercupa190
  • 12223 Answers
SOURCE: instructions for davina mccall treadmill 335-7963
go and download : www.fitness.manualsonline.com or www.iconservice.com
God bless you
Posted on Jun 10, 2012
ercupa190
  • 12223 Answers
SOURCE: lost manual for roger black silver treadmill
see the video and proceed according., God bless you
Posted on Apr 04, 2013
How to fix error code 6 on a roger black treadmill?
1)E00 Safety Key not in the position Re-locate the safety key in the correct position.
2)E01 No signal to Controller from the console
A: Check the Main Controller Wire
B: Replace the PCB Board
3)E02 Motor communication error
A: Check the wire from motor to controller
B: IGBT breakdown, Replace the controller
C: Check the power voltage if 50% lower than rated voltage
D: replace the motor wire or change motor
4)E04 Incline Motor communication error
A: Check the wire from incline motor to controller
B: Replace the incline motor
C: Replace the controller
5)E05 Over current protector
A: Overloading or over resistance,
restart the treadmill
B: Transmission parts seized up, check the parts
C: Replace controller
D: Motor breakdown, change the motor
6)E06 Motor Open Circuit.Connect the Motor link
7)E08 IC Driver Error. Replace the IC driver or change the
IC driver
8)E09 Folding up protect.
A: Do not fold up the running deck when treadmill in is running
B: If the running deck in laying position and show E09, you need to change the controller
9)E10 Motor instantaneous current abnormal
A: Adjust the torsion potentiometer of the Controller to lower
B: Motor Breakdown, change the motor
10)E11 Overvoltage protector Voltage over 270v (for 220v) or 150v (for110v) -- turn off the treadmill and check the power source
11)E13 No signal to console from the controller
B: Change the controller
12)E14 Lower voltage protector Voltage lower than 160v (220v) or 70v (110v) -- turn off the treadmill and check the power source
Oct 26, 2017 | Exercise & Fitness
I have error code E00 on a motorised folding Pro Fitness running machine . Any idea what this relates to and is it fixable ? Any advice very much appreciated . Clare
First of all check the speed sensor.
If you wish to get some details about treadmill error code and troubleshooting ; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Jan 07, 2017 | Exercise & Fitness
For the last couple of days tread belt seemed to be pulling a bit hard and smells a bit of burning when stopped,tonight i switched on bit of a clunk and belt would not turn kicked foot on belt it started...
treadmill belt need always to put a special oil from below, for better sliding. it is a special product you can find it at any service center for treadmill.
Nov 15, 2013 | Exercise & Fitness
Roger black treadmill e00
There is no solution for this problem as when I was stuck here I was also unable to find a valid serial number. There is only one solution that you need to buy it.
Sep 19, 2013 | Yahoo Computers & Internet
Lost manual for roger black silver treadmill
Apr 03, 2013 | Exercise & Fitness
Davina treadmill motorised jx-622w wont start display says e00
E00 Means the red magnetic key (the one on the string) is not inserted.. If it is then the magnetic switch may be faulty.
E01 Is an electrical fault - the wire that runs inside the frame is probably crushed while assembling
E02 Means the motor is not running - either burnt out, stuck or the optic device is not functioning correctly.
This are what I found out by trial and error - hope its useful to someone - I'm looking for a copy of the manual for this thread-mill if anyone could send me a scan or photos of the pages - thanks very much.
Mar 17, 2013 | Exercise & Fitness
Instructions for davina mccall treadmill 335-7963
God bless you
Jun 09, 2012 | Exercise & Fitness
Roger black treadmill.
i can repair or supply any roger black parts that you would need. contact me on 01706 371711
Jan 27, 2008 | Baby Gear
Sport & Outdoor - Others Logo
154 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
