Question about Symbol PDT 3100
Status 0020 or status 0040. What does it mean? Thanks
Hi i carnt print of my computer the printer reads status :toner low
This means there are cartridge[s] that you need to replace.
Check the status of the printers cartridges.
Thanks!
Oct 01, 2011 | Office Equipment & Supplies
No battery status in the screen of Garmin 255. I just bought a new Garmin 255, before charging, it can not on, meaning, the battrey is empty, that is fine. Pluging the car charger, the unit can turn...
The battery status only shows up when the satnav is disconnected from the charger. Your first charge should be a continuous charge until the battery is full. This can be done by connecting it to your computer for 8 hours approximately or 4 hours to your car cigarette lighter socket or 4 hours to an, optional extra, mains charger.
May 20, 2011 | Garmin Nuvi 255 GPS Receiver
Have second hand lexmark e260dn and status light
Blinking status light means the printer is busy. If it's not doing anything else, disconnect the printer from the computer. Restart the printer and then print a menu settings page. Clear the print queue on your computer before re-attaching the printer. Thanks.
Jul 16, 2010 | Lexmark E260dn Laser Printer
What does the status light mean,it's green
When it's green that just means that you're phone has service. When it blinks red that means you have a text message, virgin alert, missed call, or sometimes a voicemail message. You can turn of the status indicator light by going to Menu > Settings > Display > Status Light and select "Off".
May 10, 2010 | LG Flare Cellular Phone
What does the red status light mean.
Unplug the Printer and again Turn it back ON after few minutes. A Solid Red Light Status means that, more than often it is for Paper Jam.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 04, 2009 | Brother HL-5240 Laser Printer
This message is displayed on the printer's status
Hi
Thanks for using FixYa. It means that more than one printer is being used through LAN or WAN and printer has not been shared with both the computers. You'll need to share the printers being used and the issue will be resolved.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Oct 09, 2009 | Sharp Office Equipment & Supplies
Internal back up battery status: NONE
Burn it...
Smack oN the Floor..
It gonna be Oc...
Nov 05, 2008 | O2 Xda IIs Pocket PC
Ws55513 blinking light
If it's the lamp indicator, yellow means lamp near end of life, red means failed lamp. Status light (red) means major failure, yellow means filter cover loose. Parts can be found on ebay or internet.
Apr 03, 2008 | Mitsubishi WS-55513 55" Rear Projection...
DST Short Status Test (Error detected)
DST stands for Drive Self Test, it means your drive is failing.
I would get a new hard drive and USB enclosure, install new drive in laptop and install windows, then take the old drive and install it in the USB enclosure so you can connect to your laptop when windows is running and restore your files, assuming the drive is not completely dead.
thanks for rating
Jan 10, 2008 | Dell Inspiron 6000 Notebook
Projector turns off after about 30 minutes. What's wrong?
your projector status means the protection circuit is working or the lamp is in an abnormal condition.
--wait until status indicator goes out and press power button.
---if the above solution is not working change the lamp.
Nov 19, 2006 | Mitsubishi HC900U Multimedia Projector
Symbol PDT 3100 Logo
265 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
