Question about Dell Latitude C640 Notebook
C640 sVideo problem
I have hooked up a s-video cable from the computer to a regular TV and the c640 delivers no video to the TV, the s-video port is not working on my Dell c640. I have upgraded the computer to XP pro from win2000 and in the device driver under ports I do not see it listed there. Only Com1 & LTP1 are listed. Do I need a driver for this s-video port to work? What can I do to make it work?
Thanks in advance for any info
Noel Roberts
    Novelist:
    Champion:
  • 236 Answers
You definitely need to get the drivedr for the svideo option. it wil actually not show you in the device manager the svideo, but the graphics card details only. to find out if you have a secondary display (svideo) you have to go to your display properties then and see if you have dual display. try to bott also your dell with the svideo-tv already connected and see if you get a post display on your tv. now... i need to know only if your svideo is active, drivers will still be need to get the windows work there.
Posted on May 03, 2008
How do i hook up a laptop to my gemstar big screen thru the usb port?
I have never heard of that. You will have to hook it up through the SVideo or DMI or HDMI or whatever Video extension you have on your laptop. Get the correct cables to connect to the same ports on our TV you should see computer on your TV screen "desktop" You will also have to switch screens either one of the FN keys will switch you over or you can do it from the video source in the control panel. Audio can be done with a y split audio stereo jack to the headphone jack and the the Y will be the RCA White and Red jacks these will go to the Red and White jacks for audio on the TV from the laptop.
John
Apr 19, 2012 | Computers & Internet
Please describe your how to hook up and compaq nc6220 to a tv. I have tried an adaptor with the three prong yellow/white/red to a video adaptor but no luck.
The easiest way to hook up any laptop to a tv is with either an HDMI cord, or an Svideo cord. It looks like your laptop supports Svideo, but make sure your TV supports it as well. The connection should look similar to this: snowyrat_0.jpg
If your TV does have the port, go to a nearby electronics store, and buy an Svideo cord. An employee there should be able to help you find one for a fairly decent price. If your TV doesn't have an Svideo slot, you should be able to get an Svideo to AV converter cord along with your Svideo cord. You can connect the Svideo to your laptop and the Svideo slot in the converter, then plug the AV cords into your TV. Hope this helps!
Mar 28, 2011 | HP Compaq nc6220 Notebook
Can a computer be hooked up to this tv, if so how?
A computer can't be connected directly. You will need a video converter of some sort to go from VGA to Component Video. If your computer's video card has TV-out functionality, you just need a VGA to component video cable. Otherwise, you will need a set-top box converter, such as http://www.svideo.com/hiwire.html .
I wish I could be of more help.
Jul 11, 2010 | Akai PT4250A 42" HDTV
I HAVE A ZENITH TELEVISION AND I CANNOT HOOK MY DVD/VCR COMBO TO IT. THERE IS NO PLACE TO PUT THE CABLE. MY TELEVISION HAS THE ANTENNA/CABLE PLUG AND THE YELLOW,WHITE,AND RED OUTLETS ON.
your TV has composit video in but your DVD/VCR only has Component video and Svideo outputs ..those are not compatable with your tv .. if you look more closely you might find an SVideo input on your tv .. its flat and not as easy to see as the normal jacks .. if your tv does have SVideo then all you need is an SVideo cable (plus the two sound cables) ... i could check on what you have if you give the TV model number .. othwise you have to have something to convert your SVideo to composit video .. there is a cable that does that .. you can check with radio shack .. if they do have such a cable then one end would plug into the svideo of the dvd/vcr . the other end would plug into the yellow jack on your tv .. hook up sound and it should work ok ..
here is such a cable on the internet ..
http://www.cablestogo.com/product.asp?cat_id=2012&sku=27964#tab=review
or google "svideo to composite" to see lots of options
Nov 22, 2009 | Sylvania DV220SL8 DVD Player/VCR
I am trying to connect my acer 5720z to my television. i have had it hooked up for about a year with no problems though the s-video port. just recently my apartment got struck by lighting and the svideo...
Lightning has damaged the S-video port on the TV and or the laptop. Take it to a repair shop, this is a hardware problem.
I would suggest getting a power board with a surge protection for the computer and for the TV.
Jul 16, 2009 | Acer Aspire 5720-6661 Notebook PC
Trying to hook up a TV to my Dell inspiron 1420 PC using s-video to composite and there is no output on the TV. I borrowed an expensive converter which works perfectly so the computer IS set up properly...
that actually isnt a true svideo port. it does output video, but it needs a converter that dell sells for about 30 bucks (ebay is cheaper). it plugs directly into the "s-video" port on the computer and splits it off into both an svideo connection and an rca connection.
Jun 10, 2009 | Dell Computers & Internet
No video signal from dvd player to tv.
Double check the way you've got the cables connected.  Audio but no video generally means that the yellow video cable isn't hooked up correctly.
Check to make sure the video cable (yellow) is hooked up to the same input on your television that your audio (red and white) cables are.
Mar 19, 2009 | Sharper Image GI300 System
Hooking up my hp laptop to a sony trinitron tv
Let me explain on how to connect the TV to HP notebook.
There are two ways to connect the TV to the notebook. One is with the S-Video cable and another one is HDMI cable. (If you computer had HDMI port)
Connecting notebook and TV with S-video cable:
You need to get the Svideo cable and connect it to the notebook Svideo port to TV Svideo port and press Fn+ F4 to get the notebook display on the TV.
For the first time pressing the Fn+F4 keys, you will get the display on the TV and there will be no display on the Notebook.
If you press the Fn+F4 for second time, you will get display back to the notebook and Tv screen becomes blank.
By pressing the same keys again will show the display on both the screen.
Samething connecting with the HDMI cable, if your computer had HDMI port.
If you won't get the display on the external screen even after following the correct process, then once you need to reinstall the display driver.
If the issue persists, then you have to check with another cable.
Note: No need to install any software on the notebook to connect the TV to the notebook.
Aug 01, 2008 | HP Pavilion dv6000z Notebook
Dell laptop c640 s-video port usage
Normally you have to use Fn(function key) on your keyboard + F4 key (F4 or maybe some other key you have to see and icon on your F4,F10 key..it should look like a a monitor icon) try it.
Press Fn first and hold it and press F4....
The first time it should output only to your S-video,second pressing it should output both s-video and your monitor.
goodluck,takecare.
May 03, 2008 | Dell Latitude C640 Notebook
Avermedia Tech AVerMedia QuickPlay
Unfortunately the Avermedia Quickplay doesn't support audio. If you want the matching audio too, you'll have to either use your computer's native audio (if it's in the same room), or hook it up to your TV with a separate cable.
Nov 30, 2007 | Avermedia QUICKPLAY (pquickplay)
Dell Latitude C640 Notebook Logo
138 people viewed this question
Alun Cox
