Question about Dishwashers
Why we are getting sulphur smell after crackers like sound while the dishwasher is in running?
  • 414 Answers
Sounds like the suppressor may be shorting, without knowing the model unfortunately I will not be able to tell you where to look. If it is a tecnik (as this is where you have posted the problem) the suppressor is clipped to the terminal block of the mains cable. It will look scorched with carbon dust if faulty.
Hope this gives you a place to start looking.
Posted on Aug 20, 2010
  • vvissamraju Aug 25, 2010
    This is IFB Dishwasher and the Model is ZEPHYR EX. So by this information we can expect more details.
    Thank you
  • Roni Davey Aug 26, 2010
    There is a possibility that the crackling noise and smell are coming from the control module (behind the control panel, have a sniff around this area to check if this is where the smell is coming from) or from the mains cable suppressor, this is connected to the mains cable coming into the d/w but on the inside of the unit. To check this you will need to remove the lid and the side panel (usually the right panel when looking at the d/w from the front). If you have no technical expertise at all, I suggest you get it looked at by an expert service technician. Your original post was in the Tecnik d/w section, I do not have any access to manuals for IFB and therefore I am only offering this info as a guide, I hope it helps.
How do I use sulphur powder in feed
Sulphur powder and tablets used to feature in many treatments from the past. The brother of one of my schoolfriends was given a course of sulphur tablets to combat rampaging teenage acne and then given carbon tablets to combat the evil smelling gas produced from his digestive system.
The barber I used forty years ago recommended a "spirits and sulphur" treatment for severe dandruff and scaly scalp.
Sulphur is used extensively as a dusting powder in horticulture to ward off all manner of attacks.
If you can find a veterinary surgeon with a long grey beard and a memory to match you have a very good chance of finding the information you seek. Most old vets, like most old doctors were also highly competent apothecaries.
Similarly a pharmacist of the old school was also a competent apothecary., being forced from necessity to manufacture his own remedies from cheap ingredients in working class districts to service the community.
Feb 09, 2015 | Health & Beauty
Sulphur smell : risk of explosion / fire / Meltdown ?
The smell is sulphuric acid boiling in the battery in the unit. It is getting more the the required 14 volts ( probably full line voltage) so I would junk it as it will cost more than it is worth to repair. Do not use it and any fluid that is coming out will be highly corrosive so be carefull
Jun 04, 2013 | APC Back-UPS Pro 650 UPS System
1995 crown vic smells hot and like sulphur, it also
The heading cut off your symptoms, it appears. Catalytic converters that are failing can get hot and smell like rotten eggs. Sometimes they break apart inside and cause blockage. Depending on the severity of the condition, it may cause the engine to run poorly or even stall if bad enough.
This is only a possibility, it would have to be checked. The smell of sulphur and considering the age of the vehicle may indicate the converter should be checked.
Jun 30, 2012 | 1995 Ford Crown Victoria
Engine light flashing, strong sulphur smell, can feel engine missing as it runs. Assume bad plugs or wires?
If your engine light is flashing and sulphur smell engine power loss your probably looking at a catalytic converter.However you will need to have a engine scan completed to see what else is wrong as well.
Jan 03, 2011 | 2001 Oldsmobile Intrigue
Engine jerks, then smooths out, runs rough, misses, smells like sulfur, loss of power
sounds like a restricted catalytic converter. you must, however find out why it got restricted, or it will happen again, from the sulphur smell, i suspect engine is running rich. you need a pro to help you with this problem.
Dec 22, 2010 | Ford Expedition Cars & Trucks
My dishwasher smells like rotten eggs. Help!
Had a similar problem and started looking around inside the door. I tried to figure out how to remove the plastic air vent cover on the inside of the door (left side). I couldn't figure out how to remove it. So, we purchased a dishwasher cleaner at Lowe's ($4) and tired running it through the machine to see if it would correct the odor problem. It didn't. Somehow the "little lady" did manage to remove it (used a damn table knife of all things) twisted and popped the plastic air vent off. When it was removed she found the obvious problem, black foul smelling mold was growing under the plastic air vent that was radiating its terrible smell into the kitchen through the dishwasher door kitchen side vent . She cleaned the inside vent and the odor problem has left. I guess I'll never live this down, but I must admit that my wife solved the problem. Try this solution and see if it solves your problem. Let us know how you make out!
Humble Steve
Jun 27, 2010 | Whirlpool 24 in. ADP5966 Free-standing...
Buick smells like rotten eggs and will not run
Rotten eggs is usually a good sign your catylic converter has gone bad or is severely clogged. It will smell bad at first and then you will loose power over time.
May 06, 2009 | 1997 Buick Riviera
Burning smell
The sulphur smell is the result of the emmisions control system. I have an 06 Expedition with the exact same engine and emmisions system as yours. When the engine is cold, you don't smell that sulphur smell, but as soon as the engine gets to operating temperature, the exhaust gasses smell sulphury. Nothing wrong with your ride - they all do that. The dealership sometimes spray the underbody with some type of rubber to protect the vehicle against rust. This rubber stuff sometimes get sprayd on the exhaust as well and then you will smell "burning tires" after driving the vehicle. This will go away after a few thousend miles though.
May 15, 2008 | 2008 Ford Expedition El
SHU43 Bosch Built-in dishwasher
Try running citric acid (3 tablespoons) through.
You can get it from a drug store.
Or, run 1/2 cup vinegar through.
Do this in both the dish washer and the disposal.
After doing this try running some water into the disposal and then see if the next time you run the dishwasher if it still smells.
You could be having a problem with water not staying in the drain trap under your sink that is why if you run water and fill the trap, then you will find out if it was the dry trap that caused the smell from sewer gases backing up into the house trough the garbage disposal.
Apr 30, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
83 people viewed this question
Top Dishwashers Experts
