Hello! This is a tough one. I've seen this recently and had to just press and hold the power button to shut down. Not good!
I'm assuming you're using Windows of some sort since it shows "Stage 3 of 3" when it does updates during shut down.
What has happened is you downloaded some sort of "fix" from Microsoft
and it's getting stuck while trying to install. I've had this happen
and have never found a good solution for it.
1. Turn you computer off. 2. Turn your computer on 3. As soon as the power comes on, start pressing F8 repeatedly. 4. When you get a black and white menu, use your arrow keys to move up and down, select "Last Known Good Configuration" and press enter.
What the solution I've provided does is revert your computers software to a point in the past, hopefully just before you received the screwy update.
When you turn the laptop on hit f8 until the menu comes up, try use the last good known configuration. If that does not work tap f8 goto safe mode and then to system restore and restore it to an earlier time. Let me know if it works.
This is generally caused by bad blocks in the Master Boot Record(Table). The drive itself is probably not salvagable. You'll need a reputable reapir person to slave your drive to another system to get the data off.
This sounds like a bad battery. If the battery has a short within it, it will cause the power system to shut down. Replace the battery and see if that works.
Maybe you could try the last known good configuration. When the laptop is starting up, wait until the acer screen disappears and then tap F8 on the keyboard before the windows screen comes up. You should get a black screen with some options that say safe mode. The fourth or so option on the list will be "Last Known Good Configuration". The computer should try and load windows. Hopefully that will restore the machine before the update.
If it works it would be a good idea to go to http://windowsupdate.microsoft.com/ and fully update your laptop. This will download the update manually instead of doing it with automatic updates.
If it is windows xp OS plz do the following these step.
start the pc in safe mode and select the administrator login then
go to start programme go to acssories select the system tool- selcet the restore option, turn on windows in previous back day and resloved the porblem,.
