Question about Nintendo DS Lite Console
Hello my sister has a black nintendo ds lite it will not powerup at all when charger is in orange light is on no powerup when chager is out no light on no powerup i have checked the battey in my ds it works
  • 277 Answers
Hi,Nintendo DS lite console system will not power up
their are fuses inside the consul one of them my have blown.You need a special screw driver you can get the fuses and screw driver on ebay.Try Youtube for a video on how to do this.
Is the power not working on your Nintendo Wii? This can be a frustrating occurrence, especially if your Nintendo Wii was working properly before. While there are a number of reasons why this might occur, there are two common ones -- the use of a non-licensed or genuine AC adapter, or a failed AC Adapter on your Nintendo Wii. On very rare occasions, the power supply adapter on your Nintendo Wii may requiring the entire Nintendo Wii unit may need to be replaced.
However, before get too worried about that -- let's try a few basic troubleshooting procedures to try and diagnose the issue. Nintendo guide on this problem is fairly comprehensive and has some good content, so I have included that below. In addition, you will want to check that following common issues before moving forward.
1. Check and make sure your cables are properly plugged in. This may sound silly, but sometimes they can become loosened causing bad power connections. Best to check before you spend much time troubleshooting.
2. Does the power strip or wall outlet that your are plugging the Nintendo Wii into have power? Make sure you can plug in other devices into that same outlet to verify there is not an issue with either the power strip or the wall outlet.
3. Make sure there is adequate ventilation. Although it is covered below, it is best to make sure there is several inches of free space at the back of the Nintendo Wii to provide good air circulation to the Wii so it does not overheat.
Here is the Nintendo information on trying to troubleshoot power problems on a Nintendo Wii:
1. Make sure that the word "Wii" and the model number "RVL-002 (USA)" molded into the AC adapter. Unlicensed products are not fully compatible and may not work
correctly.
2. Avoid the use of unlicensed products such as memory cards, controllers, and cheat devices. Some of these products are poorly manufactured and may result in damage to your system. If one of these products is attached to your system, remove it and try resetting the AC Adapter (see below).
3. Check all accessories, licensed or not, for physical damage. Physical damage, such as frayed wiring or a cracked housing can cause the system to shut down. Remove any damaged products and try resetting the AC Adapter (see below).
4. Make sure the Wii has good ventilation. Avoid operating the Wii while it's on carpeting or inside an enclosed space. If you have the Wii placed in a vertical position, make sure the vent on the bottom is lined up properly with the hole in the plastic stand and no foreign material is obstructing that hole.
5. Check the vents on the back and side of the Wii for dust build up. The system will shut down if it cannot vent properly to prevent overheating. If there is a build-up, remove it using a vaccum cleaner with a soft brush attachment.
6. Make sure that your wall outlet works. To check it, try plugging a lamp into the same outlet where your system was plugged in. Turn the lamp on the verify the outlet works. Also, make sure you are not using an outlet that is operated from a wall switch. If you do, make sure the wall switch is in the ON position.
7. Make sure the AC adapter is attached properly. Firmly plug your AC adapter into the back of the Wii (the port is labeled 12V IN) and into a working wall outlet.
8. Once plugged in, check the power light on the Power button to see if the system is receiving power.
If this fails, try resetting the AC adapter.
1. Unplug/remove all accessories from the system (including game discs, SD Cards, memory cards, Nintendo Game Cube controllers, hookup cables, the AC Adapter, and Sensor Bar) from the outlet and Wii.
2. Let the system rest for about 90 seconds. While you're waiting, check to see that controller cords, AC Adapter, and Stereo AV cables/Component Video cables are not frayed or have exposed wires (this can cause the system to shut off); if so, you should replace those parts.
3. After the 90 seconds, Plug the AC Adapter into the system and wall outlet. Check to see if the power light on the Power button comes on.
4. If the system works, plug ONE accessory into your system starting with the Sensor Bar, then turn the system on to see if it still works. Repeat this process with ONE accessory at a time. If your system doesn't work once you put a particular accessory in (Sensor Bar, Game Disc, Nintendo Game Cube controller, Memory Card, SD Card, etc.), there may be something defective with that accessory.
5. If the power does not come on, a repair will be necessary. Because it is not possible to determine which item (Wii console or A/C Adapter) needs repair, please call our Consumer Service Department at 1-800-255-3700 to discuss available options.
6. If the power is still continually shutting off regularly, please call our Consumer Service Department at 1-800-255-3700 to discuss available options
Goodluck.
Posted on Aug 20, 2010
My ds lite won't charge.. the orange light appeared blinked
We had this problem with a brand new DS Lite...turns out it was a bad charger. If you have access to another charger, try that first. Good luck!
Apr 03, 2010 | Nintendo DS Lite Console
Orange light briefly comes on and DS does not charge
is the charger socket ok as i understand they snap internaly also could be worth checking the battery.
Jun 27, 2009 | Nintendo DS Lite Console
I plug in my ds light to charge and the orange
If your DS is 2.5 to 3 years old, the battery may be bad. Lithium Ion batteries expire 3 years after their date of factory production, so they need to be replaced occasionally.
Also, if there is a kink or break in the electrical cord, it could cause problems. The only real solution, aside from tearing the cord apart and resoldering or taping the severed ends, is to purchase a new charging cord.
If the battery is already 100% charged, it may not display a charging light.
Jun 23, 2009 | Nintendo DS Lite Console
Nintendo DS Adapter
You'll need an adapter that works in your country. If once you have that it still does not work then you probably need a new battery. Without a working battery you won't be able to play the DS even if the charger is plugged in. The charging light will flash and go out if the battery is bad.
Mar 26, 2008 | Nintendo DS Lite Console
Ds lite ac wall charger
When you first get the DS it will have a bit if charge on it but only a few hours worth. When the DS charges it usally comes up with a orange/red ish light then that goes out about a few hours later when its charged. ad if you want to chek if it is charging correcly turn the DS on whilst it is charging and the little battery simble in the top right corner should show the battery carging.
Nov 30, 2007 | Nintendo DS Lite Console
Not charging
Quite honestly...
I know that this is probably not the answer you guys want to hear about this issue...
You're going to have to contact Nintendo and make good on your warranty on this one. Just tell them that the unit is no longer charging and that you 'don't know why'. They should have no real problem replacing it for you.
This is most likely an internal electronics issue that no expert here is going to be able to advise on.
Unfortunately the internet still isn't good enough that we can do solder jobs over our internet connections. :P
=THIS IS NOT A PROPOSED FIX. DO NOT RATE ME FOR IT=
Otherwise, if you wish to persist in trying to fix your problem, the only thing that I can tell you is to either try using someone else's charger adapter, buy a new adapter OR use an adapter that works and hold it at different positions in the DS Lite to see if any position will charge it. If you are succesful at charging it in this manner then the port you plug the charger into may be loosened.
===DO NOT RATE ME FOR THIS POST. IF YOU GIVE ME A POOR RATING FOR THIS POST I WILL DISPUTE IT WITH THE FIXYA STAFF AND ASK THAT IT BE REMOVED. I AM NOT ATTEMPTING TO SOLVE YOUR PROBLEM BUT AM GIVING YOU ADVICE ON WHAT YOUR BEST BET IS. I WILL however accept a GOOD rating if it is given - naturally. LOL===
Regards,
Cyryl
Nov 03, 2007 | Nintendo DS Lite Console
DS Lite does not power up
If the console has overcharged or has been used for long periods of time or could just be fluke, chances are the fuses are blown on the main motherboard try this link, this guy fixed my ds and i had the exact same problems as you guys have
Sep 10, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
254 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
