Question about Car Audio & Video
Suzuki vitara 1988
Hi guys,im wondering if anyone knows what sort of oil to put in the gearbox of a suzuki vitara 1988,any help would be appreciated,thank you,
YOYOHORSE
  • yoyohorse Jun 21, 2008
    hey thanks for the answer
Castrol vmx m
Posted on Mar 30, 2009
  • 26 Answers
Manual trans would take 80 w.
Posted on May 09, 2008
Gear box oil refill suzuki grand vitara
what tranny? 5sp manual.
only the 5speed uses, real GL4 gear oil. so. must be.
under car, look up. see box. on right side is the fill hole.
seen here.
here is my filling mine before , new engine install. can be done
with engine, using free gravity and hot lube.http://www.fixkick.com/tranny/GL4-easyway.JPG
under car view.
http://www.fixkick.com/tranny/custom-oil-filler1w.JPG
its also in the glove box, operators guide.
and online at all majors, for that, alldata dot com covers it best.
http://www.fixkick.com/IGN_timing/tune-ups.html#Gear_Lube
Mar 07, 2013 | 1999 Suzuki Grand Vitara
Changing manual transmission oil in 2003 grand vitara?
it has a drain plug and a filler plug but you should never need to change the oil ,but the oil to use is EP90 hypoid oil as gearbox has helical cut gears which need exteme pressure oil .a top up yes maybe but change the oil in a manual box is not something anyone does ,yes i know its in the 100.000 mile service check list but no one ever does it in a garage .because by this time the vehicle needs a new clutch and you have to drain the oil to do the clutch
Nov 06, 2010 | 2003 Suzuki Grand Vitara
Where do refill oil for gearbox 1997 vitara suzuki
Remove the oil guage and pour oil through the openining. You may need a small funnel to do this. Good luck.
Jan 26, 2010 | Suzuki Swift Cars & Trucks
Gearbox noise Suzuki Vitara V6
change oil at first and check if the old oil free of frictions and small parts
Sep 13, 2009 | 1999 Suzuki Vitara
Oil level for Suzuki TS 185 (1989)
Drain the oil and put 750ml back into the gearbox. If your bike doesn't have a dipstick and you have good, clean oil in it, drain it into a plastic bowl then put it right back into the engine but measure it before you pour it back in. When you get 750ml in the box then look at the level in the box. That is the level to maintain.
Pleas rate this solution. Thanks!
Mar 29, 2009 | 1981 Suzuki TS 185
How to replace the struts of suzuki grand vitara 2004
You need a spring compressing tool tool to unload the spring from the strut. Very dangerous, would suggest a shop to do this.
Mar 26, 2009 | 2004 Suzuki Grand Vitara
Gear box oil change vitara
the filler plug is ususlly 1/2 way up the side of the gear box as the box should be 1/2 full
Mar 25, 2009 | 1999 Suzuki Vitara
Gi6b
No Problem! It should Bolt straight up as far as I Remember.
Jan 22, 2009 | 1988 Suzuki Samurai
Were do i find oil filler plug to check gear oil level on my 2004
They dont have a dip stick but do have a bolt that is removed Diff/transfer case and gearbox the bolt you take out is at the height/level that the fluid should be at and its where you fill the diff/gearbox.Its in the side of the gearbox about half way up.
Nov 24, 2008 | 2000 Suzuki Vitara
Suzuki vitara 1989
to find tdc pull the number 1 plug get a long screw driver put in down the spark plug hole and turn the crank till the screw driver reaches the highest point
Jun 21, 2008 | 1995 Suzuki Samurai
Car Audio & Video Logo
125 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
