Question about Philips 37PF7320A 37 in. HD-Ready LCD Television
Hi, Sometimes when i go to the menu screen it gets stuck there and after a minute or so the tv shuts off and then restarts. The same thing happens sometimes when changing channels - it just gets stuck and then after a while reboots itself. Any ideas?
  • 608 Answers
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Posted on Dec 09, 2010
RCA LCD TV gets stuck on one channel
sounds like you have an intermittent defective main board. ebay rca model for replacement board.
Jan 11, 2015 | RCA Televison & Video
Philips 42pf7320a37 Plasma TV. Menu appears without being requested remotely or manually. Must select Menu Remotely (or manually) to regain screen. Screen stays on for a few seconds or up to 20...
Check that this is not caused from a stuck button, or a defective remote recalling the menu.
If it is not the remote, then you will probably need to replace the control board or the button assembly.
Nov 01, 2008 | Philips Televison & Video
RCA P56950 Powers on then 10 mins later powers off, repeats cycle. Then channel display in TV changes by itself
may be some thing is stuct on the controt pannel power button or others check. try this it may work
Jun 04, 2012 | RCA P56950 56" Rear Projection Television
Hi, I have an RCA HDTV SRS WOW Model RCA L32WD12YX5, Serial G482CJ060. It powers on and has sound for about 15 minutes then shuts itself off and restarts with no sound. As an experiment, I used the Menu...
The tv main Tuner signal board have problems and the causes.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
Jun 09, 2011 | RCA L32WD22 32 in. LCD HDTV
I type in my password and my computer tells me that i cant log in
I have had this happen, sometimes things get screwy and it just won't recognize your correct password. You need to restart your computer from the original disk. Put the disk in, shut down, restart by holding down the C key. At the top of the screen there will be an installer menu item, click it and then click Reset Password. Then restart your computer and you should be good to go.
Jul 05, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
It won't turn off
I would say,Yes you should be worry there a lot things can be affecting you laptop try ctrl + alt then delete then appear a windows task manager go to shut down it will appear stand by,turn off ,restart etc.hit on restart and wait what happens if doesn't restart could be your memory or many thing I alredy explain.Good luck
May 23, 2009 | Acer AOA150-1690 Aspire Notebook
Boot up menu restart; will not power
Boot up to the safe mode screen & select last known good configuration.
Jan 15, 2009 | Gateway 4026GZ Notebook
Menu screen stays on. philips model# 32PF7320A/37
If you are talking about a continuing display of features and menus, press the Volume Up and Volume Down buttons at the same time to shut off that display.
If the problem is that the set acts like you are pressing the front panel button and random things happen, there may be bad switches. Sometimes if Windex or other cleaners have been sprayed on to clean the picture tube, they can drip down onto the board and cause corrosion which makes the switches funky. They need to be replaced and the board cleaned of any residue.
Dec 10, 2008 | Philips TV Tuner Video Capture PCI Card -...
Turn off
this happens to my tv as well it simply will just shut off and turn itself back on and then shut itself off every 2 - 3 minutes...can someone help??
May 24, 2007 | Polaroid FLM-2011 Television
Philips 37PF7320A 37 in. HD-Ready LCD Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
