How do you remove the cover from a Olivetti Summa Prima 20. It also has a leaver on the left of the cancell leaver with WN marked on the head of it. what dose it do. Thank you Barry
2 Suggested Answers
DeBruce
  • 145 Answers
SOURCE: How to remove brown scorch mark on stainless steel cooktop cover
Use DeBruce Polish, we use DeBruce Polish on all of our stainless steel. DeBruce Polish also works on glass cook tops. We get DeBruce Polish at debrucepolish.com.
Posted on Apr 29, 2010
How to remove a cylinder head from a 20T2N Land Rover engine
Remove battery cable ,remove hoses to drain coolant remove rocker cover rockers, push rods remove both manifolds, air cleaner distributor cap and wires unbolt the head and leaver off if it's V8 you take off 2 heads
Jul 20, 2015 | 2001 Land Rover Freelander - All...
MY LIPI PB2 PASSBOOK READY LED CONTINUOUSLY BLIKS WHEN I SWITCH ON MY PASS BOOK PRINTER
Olivetti Printer Is Required Calibration
1 Open Your Cover Of Printer
2 Than Move Head Left Side
3 Than Push three Key Than Printer Power On
4 Just Some Beep Is Comeing
5 Close Cover Of Printer
6 Press Station 1 Two Time
7 Than Insert Blank Paper
8 Press Station 2
9 Printer Removed The Paper Automatically
10 Than Again Insert Paper
11 Printer Some Printing
12 Than Printer On/Off
13 Than Printer On
Your Problem Is Solved
Regards
yogendra Sharma
Jul 08, 2012 | Office Equipment & Supplies
Need timing gear marks for 2004 Kia Sadona 3.5L engine
Removal & Installation
3.5L Engine
  1. Before servicing the vehicle, refer to the precautions at the beginning of this section.
  2. Record the radio anti theft code data.
  3. Remove or disconnect the following:
    Negative battery cable Engine cover Accessory drive belts Idler pulley Crankshaft pulley Power steering pump pulley Belt tensioner pulley Upper and lower timing belt covers
  4. Support the engine with a floor jack and remove the engine mount.
  5. Rotate the engine to align the camshaft sprocket timing marks with the cylinder head cover timing marks.
    Fig. Timing belt routing and timing marks-3.5L Engine
  6. Remove or disconnect the following:
    Auto tensioner Timing belt
    Fig. Timing belt and related components-3.5L Engine
To install:
  1. Ensure that the engine is set to Top Dead Center (TDC).
  2. Prepare the auto tensioner for installation by compressing it in a vise and installing a retaining pin.
  3. Install the timing belt in the following order:
    1. Crankshaft sprocket
    2. Idler pulley
    3. Left bank exhaust camshaft sprocket
    4. Left bank intake camshaft sprocket
    5. Water pump pulley
    6. Right bank intake camshaft sprocket
    7. Right bank exhaust camshaft sprocket
    8. Tensioner pulley
  4. Install the auto tensioner. Do not remove the retaining pin at this time.
  5. Check that the crankshaft and camshaft timing marks are aligned correctly.
  6. Rotate the crankshaft 1 / 4 turn Counterclockwise .
  7. Rotate the crankshaft 1 / 4 turn Clockwise to return the engine to TDC.
  8. Loosen the tensioner pulley center bolt.
  9. Apply 44 inch lbs. (5 Nm) torque to the tensioner pulley as shown and tighten the center bolt to 32-41 ft. lbs. (43-55 Nm).
    Fig. Adjusting the tensioner pulley-3.5L Engine
  10. Remove the auto tensioner retaining pin.
  11. Rotate the crankshaft 2 revolutions Clockwise , then wait 5 minutes for the auto tensioner to adjust.
  12. Measure the auto tensioner rod as shown. If the measurement is not 3.8-4.5 mm, then repeat the belt tensioning procedure.
    Fig. Measuring the auto tensioner rod-3.5L Engine
  13. When the auto tensioner measurement is correct, install or connect the following:
    Engine mount Upper and lower timing belt covers Belt tensioner pulley Power steering pump pulley Crankshaft pulley Idler pulley Accessory drive belts Engine cover Negative battery cable
  14. Reprogram the radio anti theft codes.
    Kia_Sedona_2002-2006
    Timing Chain, Sprockets, Front Cover & Seal
    Print
    3.8L Engine
    3. Remove the engine from the vehicle.
    4. Remove the drive belt. Remove the power steering pump. Remove the air conditioning compressor.
    5. Remove the alternator. Remove the drive belt idler. Remove the drive belt tensioner. Remove the water pump pulley. Remove the intake manifold.
    6. Remove the connector bracket from the left cylinder head cover. Disconnect the right ignition coil connector, condenser connector and remove the bracket.
    7. Remove the left cylinder head cover retaining bolts. Remove the cylinder head cover from the engine.
    8. Remove the right cylinder head cover retaining bolts. Remove the cylinder head cover from the engine.
    9. Set the No. 1 cylinder to TDC on the compression stroke. Turn the crankshaft pulley and align its groove with the timing mark T of the lower timing chain cover.
    10. Check that the mark of the camshaft timing sprockets are in straight line positioning on the cylinder head surface. If not rotate the crankshaft 360 degrees. Do not rotate the engine counterclockwise.
    11. Remove the oil pan. Remove the crankshaft damper pulley. Remove the timing chain cover.
      NOTE Be careful not to damage the contact surfaces of the cylinder block, cylinder head and timing chain cover. Before removing the timing chain, mark the right and left timing chains with an identification mark based on the location of the sprocket because the identification mark on the chain for TDC can be erased.
    12. After compressing the timing chain tensioner, install a set pin. Remove the right cam to cam guide. Remove the right timing chain auto tensioner and timing chain tensioner arm.
    13. Remove the oil pump chain cover. Remove the oil pump chain tensioner assembly. Remove the oil pump chain guide. Remove the right timing chain.
    14. Remove the right timing chain guide. Remove the oil pump chain sprocket and oil pump chain. Remove the crankshaft sprocket, oil pump and camshaft drive gear.
    15. Remove the left cam to cam guide. Remove the left timing chain auto tensioner and timing chain tensioner arm. Remove the left timing chain.
    16. Remove the left timing chain guide. Remove the crankshaft sprocket and left camshaft drive. Remove the tensioner adapter assembly.
      Fig. Timing chain and related components-3.8L Engine
    To install:
    1. Check the camshaft and crankshaft sprockets for wear and damage, replace as required.
    2. Inspect the tensioner arm and chain guide for wear and damage, replace as required.
    3. Check that the tensioner pin moves smoothly when the ratchet pawl is released with a thin rod.
    4. The key of the crankshaft should be aligned with the timing mark of the timing chain cover. This indicates that the piston is at TDC on the compression stroke.
    5. Install the tensioner adapter assembly. Install the crankshaft sprocket and left camshaft drive.
    6. Install the left timing chain guide and torque the retaining bolts 14-18 ft. lbs.
    7. Install the left timing chain. Be sure to install the chain with no slack between the camshaft and the crankshaft (crankshaft sprocket, timing chain guide, exhaust camshaft sprocket, intake camshaft sprocket). The timing mark of each sprocket should be matched with the timing mark (color ink) of the timing chain at installation of the timing chain.
      Fig. Left timing chain markings and installation: (D) exhaust camshaft sprocket (C) intake camshaft sprocket-3.8L Engine
    8. Install the left timing chain tensioner arm and torque the retaining bolts 14-16 ft. lbs.
    9. Install the left timing chain tensioner and torque the retaining bolts 7-9 ft. lbs.
    10. Install the left cam to cam guide and torque the retaining bolts 7-9 ft. lbs.
    11. Install the crankshaft sprocket, oil pump and right camshaft drive.
    12. Install the oil pump chain and oil pump sprocket. Torque the retaining bolt to 14-16 ft. lbs.
    13. Install the right timing chain guide. Torque the retaining bolts to 14-18 ft. lbs.
    14. Install the right timing chain. Be sure to install the chain with no slack between the camshaft and the crankshaft (crankshaft sprocket, intake camshaft sprocket, exhaust camshaft sprocket). The timing mark of each sprocket should be matched with the timing mark (color ink) of the timing chain at installation of the timing chain.
      Fig. Right timing chain markings and installation: (C) exhaust camshaft sprocket (B) intake camshaft sprocket-3.8L Engine
    15. Install the right timing chain tensioner arm. Torque the retaining bolts to 14-17 ft. lbs.
    16. Install the right timing chain auto tensioner. Torque the retaining bolts to 7-9 ft. lbs.
    17. Install the right cam to cam guide and torque the retaining bolts to 7-9 ft. lbs.
    18. Install the oil pump chain guide. Torque the retaining bolts to 7-9 ft. lbs.
    19. Install the oil pump tensioner assembly. Torque the retaining bolts to 7-9 ft. lbs.
    20. Pull out the pins on both the left and right hydraulic tensioners. Install the oil pump chain cover.
    21. Rotate the crankshaft two revolutions in the clockwise direction. Confirm the timing mark. Be sure to rotate the crankshaft in the clockwise direction.
    22. Apply sealant on the chain cover and on the cylinder head, cylinder block, and lower oil pan. Be sure these parts are free of engine oil and dirt.
      NOTE Before assembling the timing chain cover, the liquid sealant TB1217H should be applied on the gap between the cylinder head and block. The part must be assembled with five minutes after the sealant is applied.
      Fig. Sealant application (1 inch bead width)-3.8L Engine
    23. Apply sealant on the chain cover.
      NOTE The liquid sealant TB1217H should be applied on the gap between the cylinder head and block. The part must be assembled with five minutes after the sealant is applied.
      Fig. Timing cover sealant application-3.8L Engine
    24. Install a new gasket to the timing case cover.
      NOTE It is important that the dowel pins on the cylinder block and holes on the timing chain cover should be used as a reference in order to assemble the timing chain cover in the correct position.
      Fig. Timing cover gasket installation (A) gaskets-3.8L Engine
    25. Install the timing chain cover. Torque the retaining bolts in the proper sequence and to specification. The engine should not be started for at least thirty minutes after timing chain cover assembly.
      Fig. Timing cover bolt torque sequence and specification-3.8L Engine
    26. Install the timing case cover oil seal.
    27. Continue the installation in the reverse order of the removal procedure.
May 19, 2012 | 2004 Kia Sedona
Where are the timing marks on a 2002 xr70r
Remove your left crankcase cover and reveal the stator's rotor.Also remove the camshaft's cover on the left of the cylinder's head.On the stator's rotor there is a T mark next to a carved straight line. You rotate the flywheel until that line faces straight forward (there should be a mark on the crankcase there to align with)Then insert the camshaft to the cylinder head with it's lobes facing the crankshaft and they don't press against the rocker arms.Then fit the camshaft's sprocket on to the camshaft so that a dot mark that it has, faces towards the front wheel (again there is a mark casted on the cylinder head). At that point you should rotate the camshaft a bit not too much) so that the bolt holes of it matchs those on the sprocket.
Feb 07, 2012 | Honda Motorcycles
Where are the timing marks on a 1970 cb 350
On the left side of your engine, you will see a round cover. If you remove this round cover you will see a fly wheel with a big bolt head, if you spin this bolt head with the engine in neutral. You will see marks on the fly wheel, these marks are your timing marks.
Jan 18, 2011 | 1972 Honda CB 350 F0
How do you undo the seat to get to the battery?
The battery is on the left side. Remove the Phillips head screw in the side cover.
The seat is a tricky thing also on the left rear you will see a key hole and a helmet holder. Behind this is a separate lever. Insert and turn the key and then pull down on the rear leaver behind or at the bottom of the helmet holder
Nov 14, 2010 | 2005 Honda CBF 250
I cant locate the position of the ink catridge on the printer. Olivetti any_way wifi
Turn the printer on.
Lift the lid that covers the print-head mechanism.
Wait 10 seconds, and the ink-cartridges should "slide"
to the position from where you can see (and remove/replace) them.
Oct 16, 2010 | Olivetti wireless All-In-One InkJet...
How do you remove timing chain and re-time eng
If you need to remove the cylinder head, here's how. To remove the cam chain, you've got to also remove the left crankcase cover and flywheel.
First, you need to turn the engine over until the piston is at top dead center (TDC) of the compression stroke. Begin by removing the two round covers from the left side of the crankcase cover. Also remove the four tappet hole covers from the cylinder head cover. Turn the engine (in the normal direction of rotation) and watch the intake valves open - and close, then see that the exhaust valves open, then close. Now align the 'T' on the flywheel with the notch in the inspection hole. With all of the valves closed, the engine is at TDC of the compression stroke. Do not begin removal of the cylinder head cover until this is done - to avoid damage to the cover.
With the cylinder head cover removed, you will find two bolts attaching the cam chain sprocket to the camshaft. Turn the engine until you can get a 10mm socet onto the heads of the bolts and remove them. The sprocket will come loose and slide down onto the camshaft, enabling you to remove it an the camshaft.
Upon reassembly, set the cam timing by first setting the engine at TDC. Then, align the two marks on the cam sprocket with the gasket surface on the cylinder head. With the engine at TDC and the marks lined up, the cam timing is properly set.
Oct 24, 2009 | 1985 Honda XR 250 R
93 people viewed this question
jasbo
jasbo
