This has been sitting and only powered up 3 months ago. A lighting strike hit and the TV powers up and I get aduio but no video. Is there a video cirect board I can replace to try to repair? I would hate to have to junk it. No repairs shops in my area (rural). Or maybe some kind of reset that may solve the problem? Any suggestions or ideas would be helpful.
  • tangeloarcad Aug 20, 2010
    Its a Philips 27 inch flat screen TV, Model #27PT543S37A. It was a gift and has been sitting up until 3 months ago and powered up for the first time. It was on a surge device which is still working, I believe the problem came throught the connection with the Direct TV receiver. I just had their repair man out here and he replaced the LBN's and the splitters and a booster power supply.
    I will open up the TV and look as you suggested, if the above info changes anything or suggests other solutions please advise.
    yes, it confirmed what I suspected and offered possible solutions. Well done, Thank You
  • Televison & ... Master
  • 17,130 Answers
Unfortunately you have not told me the make/model of the set.
To go back any lightening strike has a very bad effect specially on a TV since it is too prone to heavy damage due to the cable/antennae input and the power line. So a surge in either line can have a high level of damage. Since you mentioned that Audio is present there is some hope but it would be good to have a LOOK at the main board. Open set after disconnection and check on the board with a good powerful lamp. If you notice different areas of line burns/solder tracks open/components burned, then it would be better to order the boards.If a physical check show only a regulator/line fusible resistor faulty then you are lucky. If not, Call up the nearest service centre after checking the web for the details , ask if the board could be sent up for serrvice and if bad a replacement could be sent back. If so courier your PCB after making notes of the connections so that you can do the job by yourself to fit back.
I sincerely advice you to decide. Good day
Posted on Aug 20, 2010
  • Donald DCruz
    Donald DCruz Aug 20, 2010
    The voltage have come in through the input and could have damaged the Y amp processing section, it can be one component or numerous, as the semiconductor junctions gets punctured in a flash. Hope you get lucky . please give your votes?
Sanyo tv won't turn on after a lightning strike.
Ask friend if broken when given to you. If not I would suspect the power supply is fubar..
Sep 16, 2017 | Sanyo Televison & Video
What's the likelihood of my TV being able to be fixed after a lightning strike killed all electronics on one wall?
Probable power supply fault now. Maybe if you replaced the power board it might work again.
Jun 19, 2017 | Vizio Televison & Video
Turn on unit. Red power light is on. No picture, no sound. Turn unit off, hear a click and a small square flash on the screen. Did the same thing 2 months ago, let it sit for 3 days and then it was...
It seams to be a problem in video and video out put stage some TV set design there is no video signal the sound out put also not working this TV high voltage ( horizontal out ) is working fine that why flash squre visible when the sw off. may be dry joints in the video section or some auxilary power supply cricuit feeding power to video section having a problem
Sep 04, 2010 | Toshiba 27A60 27" TV
Power light just keeps blinking and T V will not turn on
Purchased just a month ago? It should still be covered by the manufacturer's warranty. Unless the seller isn't a legitimate retailer. Try warranty repair before worrying about fixing it yourself.
Nov 19, 2008 | JVC Televison & Video
No Power
you could have gotten hit by a surege hope you had a surge protector, if you did just reset the breaker on it
Jul 25, 2008 | Samsung HLN617W 61" Rear Projection HDTV
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
