Question about Behringer EUROPOWER EP2500 Amplifier
Low output on LH channel and destorted. Clip light on on LH channel. There's no component on the board burned or poped
  • 4,234 Answers
This sounds like the output section has failed Open rather thans Shorted. You are essentially driving the speakers with the "driver" section rather than the final output stage. This unit will require benchtime to trace the problem and fix it. This is not a problem that can be completely diagnosed remotely. Where are you located?
Dan
Posted on Aug 20, 2010
Why does my mackie cfx12 mkii have low output across all 8 xlr inputs at unity gain with distortion above that?
Where are you getting the low output? It would be very strange if all channels failed in the same way so it is probably something common to them all. Can you get the clip light to illuminate at all by turning the gain up on a mic channel and shouting into the mic? You are referring to the gain at the top of the strip not the slider aren't you? What happens if you assign a channel to the other sub channel, does the level come up through that? What happens if you take the output from the aux send and you send signal there, is it the same issue?
I may be completely wrong but I suspect if it is only mics that are causing a problem you may have the routing set up wrong or not set a level somewhere else right.
Aug 10, 2014 | Mackie CFX 12 mkII 12 Ch. Compact SR Mixer...
My Samsung ln40a530p screen looks good and normal for a few minutes right when I turn it on. Then it gets real dark and not as clear and I can see images burned in the corner from a channel that was on...
That symptoms have problem in back lights supply.The back lights have drive board that energies the back lights, the drive board have 24v dc from the power supply.So if the 24V dc output of the power supply have faulty because of leak capacitor,the back light drive board is did not oscilate to energies the back light.So the problem is either in power supply the 24v dc output,the drive board or the connector of the back lights in the drive board is loosen.
Aug 31, 2011 | Samsung LN40A530 40 in. LCD TV
Before I ask, I know the risks involved in opening a high power amplifier. I know sending it to an authorized repair shop is the best (and most expensive, possibly more so than buying a new amp) option....
When you heared or noticed any burnout components,most probably from the regulators/rectifiers/IC's/ voltage limiting dides/ etc,it means you're having a problem on your driver up main outputsection in your circuits ,you have to check steps by step,n most cases,like this HIGH POWER AMPLIFEIRs,its using a high wattage transistor/Mosfet particularly,
After replacing some faulty components,,Please,.kindly .do not connect immediately your expenssive speaker's,if you've 8ohms /50-100W dummyload parallel with your( ohmmeter on AC set), to monitor the ac abrupt dumping factor on the main output,
CAUTION;
When you noticed your amplifier is having a problem like poping sound/motorboating sounds/burned components and smell/trembling with low freq sound and etc,
Do not connect your speaker,specially HIGH POWERED OUTDOOR AMPLIFIERS just to avoid any damage or create fire, and extend some components damage on the circuits,
OPTIONS:
In deep repairing and troubleshooting in any electronic equipments, it needs complete diagnostic tools/schematics/techniques,...experience and observation sometimes is required,
IF YOU DONT HAVE IT,ITS BETTER TO BRING YOUR AMPLIFIER IN A SERVICE SHOP,
My friend,thanks and good luck,.
Jun 02, 2011 | Crown XLS 602 2-Channel Amplifier
I have a Pmp5000 889406987784 Eurowpower PMP5000 1200-Watt 20-Channel Mixer and Speaker Output A has no output. What has happened?
Usual problem is the Channel A amplifier has burned and blown the switching transistors. Usually an internal board arc occurs and unless very skilled at board work of clearing the burned area and replacing the components you are better to replace the HCA2400 amplifier module... about $160
Sep 19, 2010 | Behringer Europower Pmp5000 Powered Mixer...
The clip light turn on with low music, what the wrong with that?
it could be you are missing 1 side of the supply which would cause the output to be low but the clip light to come on
May 17, 2010 | Crown CE2000 2-Channel Amplifier
Soon as i turn on my QSC RMX2450 the clip light comes on for Ch 2
Sounds like an output going bad. Try to get some electronic contact cleaner and spraying on the circuit board. If its corroded this will help clean the circuit..
Sep 07, 2009 | QSC RMX-2450 Car Audio Amplifier
I have a sony ccd-fx420 video camcorde. Destorte signal output
Its an old camcorder or 1995 or some thing and got leaky electrolytic capacitors problem on its main board that requires replacement. These capacitors are approx 60 to 70 and very difficult to unsold old and sold new capacitor on main board.
It does not worth to repair.
Thanks.
May 15, 2009 | Sony Video Cameras
Behringer 3282 mixer
any luck with the test. Let me know here Id like to know how you got on.
regards
Graeme
Feb 10, 2008 | Behringer EUROPOWER EP2500 Amplifier
Behringer EP2500 no output on CHANNEL 1
check all op amps for correct voltage swing +-should be equal,test output of op amps no voltage should be present, use chasis gnd as tester neg.check voltage regulation especially 12v or 15v +-.note some amps show unequal led indications when only 1 channel connected to a load.I will try to get some more info on this specific amp because i don't know this circuit well,keep in touch as you update though.
Aug 21, 2007 | Behringer EUROPOWER EP2500 Amplifier
Behringer EUROPOWER EP2500 Amplifier Logo
111 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
