Question about Canon MP610 Photo All-In-One Printer
There is paper jammed but i cannot see it i have opened every cover and stil i cannot find it . it is thick paper, how do i fix it?
    Genius:
  • 2,785 Answers
Your printer has a hardware problem.so kindly take it to servicing centre
Posted on Aug 20, 2010
Red light is constantly blinking and when try to print, there is always a paper jam
Every time there is paper jam, the printer knows the job is not completed and hence tries to re-print after the paper is removed and cover is shut.
Clear the print job from computer.
Power off the printer and Clear the paper jam (if any)
I would try to use different tray. The paper pickup roller in one path may be worn out.
eg Sheet feeder or multipurpose tray.
Load paper in new tray
Set the application to use new tray
Ensure you sue the right thickness (gsm) of the paper. Quality of paper is crucial. Too thin; too thick can affect functioning.
Mar 16, 2016 | Ricoh Aficio Sp 3300DN Laser Printer
Error 51.23 after paper jam
**Yellow laser scanner error, replace scanner assem..For tech guys: Remove scanner assembly, remove cover,check for yellow scanner motor rotation. if its hard or struck, gently remove engine motor,lubricate the shaft fix it back & verify rotation, how ever entire unit opened clean all reflector glasses with ear buds gently, fix the unit back properly.(out of four screws, factory wont fit one or two screws for alignment match, same way fix the screws, don't inter change). check for print if its rectified. process end..or else replace scanner assm..
Dec 21, 2011 | HP LaserJet CM1015 All-In-One Printer
I DONT KNOW WHAT HAPPEN MY PRINTER THE MODEK IS HP LASERJET 3015, THE ERROR MESSAGE WAS, PRINTER JAM CLEAR PAPAER PATH, PLEASE HELP ME TO FIX MY PROBLEM HOW TO SOLVE IT
The laserjet 3015 has a weird issue with the logic board. The paper jam is caused by some sensor issues with the logic board. Some issues may not be fixable. The 2009 series of this printer should be under warranty from HP to get a proper board. On the converse, you could try thicker paper; and set your paper thickness on the printer. If you can open the top cover and then close it; it will reset the sensor.
Jan 29, 2011 | Computers & Internet
I have a paper jam and it says to open the front cover, put the front cover just shows the ink cartridges and there is no visible paper jam. how do i find the jam and remove it? It's a canon image...
The paper jam could be in three places.
First:
Open the cover of fixing section, its above bypass, and check for jamed paper
Second:
Open the transfer cover, these cover has handle and it goes by pulling toward you, and check for jamed paper.
Third:
In hight of first paper cassette, on left sideway of copier, beaneath the bypass are small door, open it and check for paper jams. Be sure that you closed them properly because if they arent closed the check printer cover message will arrise.
Hope that helped
Jul 07, 2010 | Canon ImageRunner 1600 Copier
Printer will not work after paper jam fixed
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jul 09, 2009 | Canon iP4500 Photo Printer
How to fix paper jammed error of canon mp145
Please try this
alternative :
Jun 11, 2009 | Canon PIXMA MP150 All-In-One InkJet...
My canon mx310 keeps showing a paper jam alarm and there is no paper jam. how do I fix it?
give this a try
alternative :
Jun 02, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon PIXMA MP160 showing paper jam, but none
hi
just recently had these problems
symptoms:
LED flashing E3 code and alarm light was solid. But dissapeared when opened the coved and came back on when closed the cover.
Also the when the cover was open the inks did not slide out to the left and stayed to the right side.
There was no paper jam, but error said paper jam.
Solution:
1. I took a thick piece of paper, from like a paper folder ones, thick enough to go in the printer and not curl up when pushed..
2. turned off the printer and turned it back on.
3, while printer was turning on,and makings sound as it does normally when turning on, I pushed through the piece of paper and the rotors stoped for a millisecond.
4.the rotors started again and pushed out the paper by it self with out my force.
5. I let the printer get started. and then turned it off and then on.
6. this solved all of my problems.
this was the first problem ever with this printer in 3 years.,preety good printer.
good luck...
Feb 24, 2008 | Canon PIXMA MP160 All-In-One InkJet...
MF-8170C REC. PAPER JAM and Open Cover
Get a thick piece of paper and feed it in to the printer following the paper path the best you can until you get the piece of paper you can't see out of it.
Oct 16, 2007 | Canon imageCLASS MF8170C All-In-One Laser...
Paper jam
OK, first try resetting th printer. This sometimes works the first time and corrects a lot of issues. Switch it off, take out all paper, check for jams with a torch right down back and open cover and check ther too. Once you are sure there are no paper jams (look really carefully they can be tiny!) unplug all cords and cables. Plug all back in turn it on, and try printing again. Post back if no luck and i will further assist.
Mar 16, 2007 | Canon BubbleJet i560 InkJet Printer
Canon MP610 Photo All-In-One Printer Logo
old marine
old marine
