Hi. Have a washing machine Miele Novotronic (W5040, but guess it's the same control system as for other Novotronic models), where the water protection system is actiwated. How do I reset this system after the failure is fixed?
  • Magnus Aug 20, 2010
    Solution worked ok.
  • 12,061 Answers
Here is a solid bottom to this machine below the drum. On it is a float unit, I would imagine water from machine has leaked in there and activated said float.
You will need to remove this water and thus allow float to return to normal position.
Try tipping the machine on it's side to clear the water and it should reset OK .
If not then you have some other problem, and you need to call a serviceman.
Posted on Aug 20, 2010
Miele Novotronic 500, 10 years old, noisy filling, no error light, inlet filters clean. Any suggestions please?
Hi dear,
As I know it's a indication on inlet valves going to fail. I hope that helps. Thanks.
Jan 21, 2016 | Miele Washing Machines
Miele Novotronic w963 motor does not turn after water filling
Hello, my question is, I have washing machine MIELE NOVOTRONIC W 963, is broken, Which Miele model HAVE SIMILAR MOTOR ,thank you . William
Jan 03, 2013 | Miele Novotronic W1918A Front Load Washer
Unable to find an english operating manual for a miele w822 washing m/c
Hi Dear. I assume this machine made for Nederlands - Dutch market. You can not obtain English manual for it. You may contact your local Miele center. They may able to supply you translated copy of user manual. Thanks.
Note: What I can understand from control panel, buttons from left to right : Door Button - On/Off - Pre -wash - Water Plus (adds more water)- Gentle wash and Short wash then Final spin speed selector.
Right hand side Program & wash temperature selector (Clock wise): Cottons - Minimum Iron - Delicate - Wool - Starch - Spin only - Pump only & Mini Program (Quick Wash)
Mar 07, 2012 | Miele Washing Machines
Hi, I have a W526 Novotronic Miele
rinse light flashing is an indication the is a problem within the motor circuit. Brushes,motor or electronic.
Dec 24, 2010 | Miele Novotronic Premier 500 Front Load...
I haven't used the miele novotronic washing machine in our other house for a year and noticed when i tried today the water was only dribbling into soap tray-thereis enough pressure in water feed so feel...
hi,
More than likely the problem is actually the inlet valve which only partly allows water to flow into the unit. you would need to remove the lid and replace the inlet valve which is on the left hand back corner of the unit. Valves are available from Miele
Jun 07, 2010 | Miele Novotronic Premier 500 Front Load...
Miele W916 front-loading washing machine filling very slowly
Hi
There are two variant of this model one with normal fill hose and triple valve and one with waterproof system and triple valve. If you have change water proof hose (one with grey box on end) then it only leaves the triple valve.if waterproof hose is fitted be sure to order 110volt triple valve
Mar 05, 2010 | Miele Novotronic W1918A Front Load Washer
How do I use the washing machine, a miele novotronic w 969
The I is the pre-wash and the III is the main wash where you put the soap powder. the # star looking symbol is the fabric conditioner.
If you don't have a manual you can download this from the miele website.
Jan 10, 2010 | Miele Novotronic W1918A Front Load Washer
My miele machine tends to bleach my clothes.
I would run a few cycles with just water added to the bleach dispenser, clean it out, and see if that helps.
Nov 06, 2009 | Miele Novotronic Premier 500 Front Load...
Hello, our miele w5040 is about 6 years old and we
if you mostly use lower temperature washes a bacterial mould builds up inside the machine. it can be seen as a black residue in the soap dispenser drawer and in the folds of the rubber door seal. a grey sludge also builds up on the inside of the wash drum and the drain filter. doing at least one hot wash ( above 60 C ) a week can stop this happening.
Aug 26, 2009 | Washing Machines
Washing Machines Logo
291 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
