Question about HP OfficeJet Pro K8600 Printer
My hp printer officejet k 8600 does not print from pdf on A3 size paper
Hp pro k8600 does not print a3 scale
Posted on Jan 17, 2011
  • 2 more comments
  • BearLeeAlive Apr 21, 2011
    I have had this same problem too, trying to print on 11x17 and found this solution. Works perfect.
    Go to Printers
    Double Click on the K8600
    Double Click on Customize your printer
    Click on Advanced tab
    Click on the Print Processor button
    Set Print processor to winprint, and Default data type to RAW
  • guess_pd
    guess_pd Aug 01, 2012
    hi thanks it works
  • faizansha
    faizansha Dec 18, 2012
    Thanks a lot ... you were the only one to give this solution :)
  • caoleanhnguy
    caoleanhnguy Jan 08, 2013
    Thank you so so much, you were the only one to give the right solution <3 Thank you again
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 80 Answers
How to Fix HP Officejet Pro 8600 Error code 346, when trying to fax a document?
The HP Officejet Pro 8600 Error code 346 usually occurs, when you are trying to fax a document. This error depending on your HP printer, a fax system might fail to work with the 8600. Most likely the issue is with the individual location which you are attempting to fax. It could happen due to Remote machine (the person you are faxing) failed to respond.
The reason of the remote machine failed to respond to a fax command from the local machine because the connection was interrupted. So, these errors can happen various reasons includes, if the phone lines in the area to be faxed are old, line condition, line traffic, power outages, and other power-related problems. Then don't worry about anything, we are here for your help. Our blog will help you to provide various methods on how to fix HP Officejet Pro 8600 Error code 346.
Steps to Fix HP Officejet Pro 8600 Error code 346:-
Step1: Retry the Fax Reception
You should retry the fax reception at a different time when the telephone line conditions have improved. Then call the telephone provider to solve the line problem.
Step2: Disable ECM.
Try to disable ECM. Might be error still occur, and may result in a degraded image quality on the received page. Therefore, the ability to send the entire document will be improved.
Step3: Sending at a lower transmission speed
Have the sender send at a lower resolution. If not, then you should try sending at a lower transmission speed.
Follow these steps to Lowering Fax Speed on an 8600:-
    ·Go to the home screen and then press the 'Right Arrow'.
    ·Then pick up the 'Setup' menu.
    ·Choose the 'Fax submenu'.
    ·Then, scroll down and then choose 'Advanced Fax Setup'.
    ·Now scroll down again to Fax Speed, and set the speed to slow like 9600. Step 4: Resend Document
    Make sure, if your document is large, and then ask the remote user to re-send the document, as divided into two or more smaller documents.
    For further any problems related to HP Printer errors, do call us at our HP Customer Support section for instant solution & service.
Epson Printer Support Phone Number 1 800 213 8289 Tech Support
Posted on Jun 02, 2017
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 79 Answers
Yes, it doesn't, look it up over here - Hp Officejet Pro K8600 Manual
Posted on Feb 28, 2013
How to print labels
Use Avery Label sheet.
Set correct paper size on Word and the Operating system.
Use label from Sheet feed tray only.
According to the printer specifications for the Officejet 8600 Pro Plus, the following label sheet sizes are supported;
HP Officejet Pro 8600 All in One Printer series N911 Manuals
Mar 15, 2016 | HP Officejet Pro 8600 Plus e-All-in-One -...
Hp 7000 won't print A3 paper size
mau nanya gan,printer ane hp k7000 gak mau print a3 tlng beri info gan ?
Feb 24, 2012 | HP Officejet 7000 Wide Format Printer...
I have problem printing A3 size paper in HP DJ1280
dear use hp 1220c driver instead of 1280
the problem will be sorted-out
Mar 07, 2009 | HP DeskJet 1280 InkJet Printer
Hp deskjet 1280 unknown a3 paper
Uninstall the HP 1280 driver and install HP 1220 driver. it will print on A3 size.
Ajay
Aug 29, 2008 | HP DeskJet 1280 InkJet Printer
Canon Imagerunner 210S - A3 error
A3 is a metric size paper. The document you are trying to print must have been formated for metric size paper. When you print select "Fit to printer margins" De-select "Choose paper source by PDF page size" and select the proper page size and source.
Jun 09, 2008 | Canon imageRUNNER 210S Copier
Paper size
The problem is with the printer side. there is option in the printer, Set manualy paper size from the printer paper tray. I think this will help you.Goodluck.
Mar 10, 2008 | HP LaserJet 5550DN/EN Printer
Help...hp k850 cannot print A3 size paper
download the new driver from HP site. And that is it
Aug 22, 2007 | HP Officejet Pro K850 InkJet Printer
Printing from different trays
this can normaly be solved by going into the printer preferences and then setting the trays manualy in the software. otherwise the printer will automaticaly select the main tray first then move onto the mp tray. sorry if it sounds a bit vague but these options change from printer to printer and have not seen a k850 for a while Hope thyis helps Cops Pete@wedotoners.com
Aug 16, 2007 | HP Officejet Pro K850 InkJet Printer
HP OfficeJet Pro K8600 Printer Logo
3,013 people viewed this question
Seeker5211
Seeker5211
