Question about Sony Playstation 3 (PS3) Console
Red screen error on my PS3. - Sony Playstation 3 (PS3) Console
  • 277 Answers
You can also try the steps below. Its from PlayStation Forum:
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System
If the above steps still does not solve the problem, then I think will have to update your Ps3.
Update your PS3 (in the settings menu the 1st option).
Go on the internet browser on the PS3 then go on the menu press triangle then on one of them there are delete cookies and the delete the others as
well as cookies.
You could also try this as well: put the PS3 on then press the eject button (with no disc in) then hold it and switch the PS3 off at the back with
your finger on the eject button still holding it, then put it back on and the fan test should be working this may cool it down. It might be over heating.
But if your problem is not still solved, then maybe you should call sony for further assistance.
Take care.
Posted on Aug 20, 2010
My ps3 will not turn on, it just flashes the red standby light
hey there
you have the red screen of death
When your Experiencing Problems with the PS3 like this you mainly have 2 options to take, I will go through each one now so you know what to do.
Option 1
Send The PS3 to Sony
Almost all problems with the PS3 Sony can fix easily if not they will send you a refurbished model.
Price:
If your in warranty they will not charge you for this repair/replace.
If your out of warranty the Charge will be $150
Waiting Time:
4-6 weeks
Sony Contacts right here
Option 2
The PS3 Repair guide
When your suffering problems with the PS3 its often easy enough to fix it at home with a good ps3 repair guide. There famous for fixing major problems like:
NOW THE PROBLEMS BELOW CAN BE FIXED WITHOUT OPENING YOUR PS3
PS3 Yellow light of death fix
The YLOD - Yellow light of death
The Red light of death
PS3 Freeze up Error
More Technical Problems Below
The Hard disk Corruption error
The Red Screen of death - Serious error
The Disk Read error
PS3 No Signal Error - no display
FIX All error messages
But not everyone knows they can fix simple settings problems like all error messages and the no display error, av and hdmi screen problems and more.
Price: averages between $30 - $40
Wait time: instant download and repair within 2 hours
I really hope I have enlightened you and you do what is needed to fix your problems with the PS3 and get back to gaming soon as possible
Please leave any comments if you need any further assistance
Best Regards
Peter Fix
Feb 18, 2011 | Sony Playstation 3 (PS3) Console
Tip
Fix all your PS3 Problems
Send Your Console to Sony = $150
You need a PS3 Repair Guide = less than $35
THE NUMBER 1 GUIDE IS YLOD REPAIR WIZARD
This guide has proven permanent fixes for the following errors:
In order of the most common:
1.YLOD (Yellow light of death)
2.Green/Red/Blue Flashing errors
3.Disk Read Error/Blue ray Drive Error
4.Hard Disk Corruption
5.No Display Error
6.Red Screen Error
7.Freeze ups
8.Fix All error codes (8001050F)
9.Sync error
10.Blank Screen error
Need More Info On PS3 Repair guides and the YLOD repair wizard
on Aug 25, 2010 | Sony Playstation 3 (PS3) Console
A red scree apears and reads that a serious error has occered
PS3 Red Screen Of Death Fix
If you are getting the PS3 red screen then you need to fix this and you can do so with a good repair guide or send it in.
To actually see how to fix the PS3 Red Screen check out the link below:
Hope this helps?
Dec 06, 2010 | Sony Playstation 3 (PS3) Console
Red screen
The "Red Screen of Death" usually happens in later PS3 Fat models right after you have turned on the PS3. It can happen right after the PS3 logo and wave animation appears. It is a mysterious error that seem to be software related during the checking process (perhaps some corruption in nand flash or harddrive block). When the error occurs, the screen turns red, and you see a message:
A serious error has occurred. Contact technical support for assistance.
Oct 09, 2010 | Sony PlayStation® 3 (80GB) Console
My screen appears red, asking for technical support.
Hi Ernesto,
If you are getting this error it is called the no display error.
Cause:
The reason that it happens is because the GPU which deals with all of your graphics has overheated. You just need to stop the heat build up in order to make it work again.
Solution:
The first way you can fix the No Display Error is by sending it in but bear in mind for this problem there is a $150 charge for the repair which is pretty steep!
Alternative Solution That Is Faster:
If you want to get the problem fixed EVEN FASTER than the option for you is a good PS3 Repair Guide.
NOTE: MAKE SURE You Check Out A Complete Review Of The Top PS3 Repair Guides First!
Oct 08, 2010 | Sony Playstation 3 (PS3) Console
Ps3 had red screen error, replaced hd and updated, still has red screen error. when i try to turn it off it beeps 3 times and the green light blinks constantly doesnt shut off.
These articles could help fix your PS3 again.
<a href="http://ezinearticles.com/?Have-You-Got-Issues-With-the-PS3-Red-Flashing-Light?-Fix-This-Problem-Today&id=3629324">PS3 Red Flashing Light</a>
<a href="http://ezinearticles.com/?PS3-Red-Light-Fix---Quick-Guide&id=3512073">PS3 Red Light Fix</a>
<a href="http://ezinearticles.com/?PS3-Blinking-Red-Light-Problem-Solved---If-You-Have-This-Problem,-You-Really-Need-to-Read-This&id=3512063">PS3 Blinking Red Light Problem</a>
<a href="http://ezinearticles.com/?PS3-Red-Light-of-Death---How-to-Fix-it-Quickly-and-Easily&id=3512067">PS3 Red Light OF Death</a>
<a href="http://ezinearticles.com/?Thinking-About-Buying-a-PlayStation-3-Repair-Guide?-Then-You-Better-Read-This-Before-You-Do!&id=3676847">Playstation 3 Repair Guide</a>
Feb 10, 2010 | Sony Playstation 3 (PS3) Console
Wen i turn my ps3 on i get a red screen say ' serious error'
hardware failur could be many things ring tech support ul probs have to send it off
Aug 31, 2009 | Sony Playstation 3 (PS3) Console
Ps3 show red screen serious error
i just turned on my ps3 today and there was a red screen that said " there was a serious error and i need to call technical support for assistance" in different languages. it wont let me do anything else it just stays in that screen. I cant even go to my menu. Please if anybody has any advice write back!!!!!!!!
Jul 10, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
