Question about Omron Model HEM 432C Manual Inflation Blood Pressure Monitor
I keep getting errorr on the omron monitor. Seems like the cuff is almost always too loose or too tight so I can't get readings. What can I do?
r321567499
  • 74 Answers
SOURCE: In omron HEM 712c BP Monitor , i feel it always shows low bp.
Here is a link I think will be helpful.
http://www.omronhealthcare.com/product/s1-1120-186-automatic-monitor
Posted on Dec 25, 2008
evwood
  • 50 Answers
SOURCE: WITH AUTOMATIC CUFF BLOOD PRESSURE MONITOR GETTING ERROR
Try different locations. The sensor must be over a vain to pick up the pulse. Locate the point on the cuff where the sensor is, and place this over the elbow. That should work. Good luck.
Posted on Feb 09, 2009
Max J
  • 22 Answers
E might represents insufficient inflation for your mom. For automatic inflation monitors usually there is a mechanism to keep inflating the cuff to higher pressures for people with higher BP. Check how is done. In some auto monitors,while cuff is inflated you keep pressing on START button until pressure reaches to some 15 to 20 mmHg higher than the pressure that auto usually stops and displays E.
Posted on Sep 08, 2009
DrRonJupiter
  • 10 Answers
SOURCE: mabis automaic blood pressure cuff, pressure monitor
Dear Edward: Likely, either cuff not tight enough or not in correct location on your arm or not holding device at correct height. Make sure you use Lithium Ion batteries. Try it on someone else. Dr Ron Grassi,Jupiter,Florida.USA. www.DrGrassi.com 30ad4e8.jpg
Posted on Oct 13, 2009
SEGlover
SOURCE: Omron hem-704C blood pressure monitor show down
If your HEM 704C fell hard, it is probably the pressure transducer that is faulty, broken. To my experience it is cheaper to buy a new one then to have it repaired by a technician
Posted on Jan 19, 2010
Testimonial: "Sound advice."
Have HEm-780 and the cuff is too big. how does that effect my readings. Can I order smaller cuff?
  1. You can buy a smaller cuff. Pressure may be wrong also. Most local stores have them.
Feb 10, 2015 | Omron HEM 780 Automatic Blood Pressure...
My wrist cuff monitor seems to be reading low. Is there a way to get it checked or calibrated?
The next time you go to your doctor, take the wrist cuff monitor with you. As they always do, the nurse or doctor will check you vital signs. After they do that and they've told you what your blood pressure and pulse readings are, correctly place the cuff monitor on your wrist and check you BP and Pulse with it. Compare the reading from the cuff monitor to what your doctor got. If it's within a few points, it's no big deal. If it's way off, than there's a problem with the cuff.
Remember, whenever using a cuff monitor, always keep your wrist at heart level for the most accurate reading. Once it's activated, remain completely still and don't move your wrist, until it has finished cycling.
Feb 23, 2011 | Walgreens Automatic Wrist Blood Pressure...
My Omron 711 seems to register readings that are too high when compared to doctor's office or monitors in drug stores, etc. Is there a way to check accuracy of the monitor?
Take the cuff to your doctors office and have the nurse check with yours and the office BP cuff. If your cuff is too small, you will get a false high reading.
Nov 30, 2010 | Omron HEM-711 IntelliSense Automatic Blood...
It keep giving me a ee reading every time i try to use it
Hi. One of the most common error symbol that appears on this display panel is a EE with a down arrow and two numerals. The reason for the EE Error Indicator is usually caused because the cuff has been wrapped too loose. The cuff was under-inflated during the measurement. This error will also display if the cuff is worn and needs to be replaced. The EE symbol with a down arrow indicates the cuff is over-inflated. In most instances the cuff has been wrapped too tight or you are using the incorrect cuff size. Turn the monitor off. Read the instructions to correctly apply the cuff. Wait five to ten minutes then take another measurement. This should correct the issue.
Aug 19, 2010 | Omron Model HEM 432C Manual Inflation...
Hello; My Omron HEM 712C shows message: EE Can
'EE' means cuff is underinflating. Re wrap cuff with varying amounts of pressure and restart [wait 2 minutes between readings].
Dec 15, 2009 | Omron Hem 712CLCN2 Cuff Blood Pressure...
Inaccurate reading
Dear al13622: How do you know?. Compare to other arm. Try on someone else. Check cuff tightness and
placement. Use Lithiun Ion batteries. Dr Ron Grassi,DC.,MS. Jupiter,Florida.USA. www.DrGrassi.com e16d4f8.jpg
Sep 26, 2009 | Omron Automatic Blood Pressure Monitor w/...
Why wont my Omron Blood Pressure Monitor work?
I contacted the manufacturer here is the response with information to contact them yourself if this does not help.
I am sorry to hear that you are having this issue with your readings and would be happy to assist you in determining where the problem lies.
Initially, I would like to provide you with some basic user information on factors that could impact the quality of your readings enough to cause the E error message you have been receiving. I will follow that with some critical steps that you must take in order to obtain a reading on your Omron unit.
User technique is important for reliable measurement results. Listed below are the common causes why you may get an erroneous reading:
Cuff Size - Measure the circumference of your wrist. If the incorrect cuff is used, you may get an inaccurate reading or error messages, if not at the first reading, then after a short period of use because the cuff bladder will be damaged. To determine your wrist size, measure your wrist approximately ½” above your wrist bone using a cloth tape measure. Wrap the tape measure evenly around your wrist. Do not pull the tape tight.
*The cuff that came with your unit is appropriate for wrist circumferences of 5 ¼ to 8 ½ inches. If your wrist circumference is not within that range, your readings will be inaccurate or you may receive error messages.
Cuff Application - Make sure you are wrapping the cuff around your wrist in the correct position. The cuff should be wrapped snugly around your wrist. If your wrist monitor can be used on either the left or right wrist, make sure you have set the monitor to the wrist you are using.
*If the cuff is wrapped too tightly or too loosely, your readings will be inaccurate or you could receive an error message.
Before Taking a Measurement - Avoid eating, drinking alcohol, smoking, exercising, and bathing for 30 minutes and rest for 15 before starting the measurement. Avoid taking a measurement during stressful times. Take the measurement in a quiet place.
Body Position - Sit in a chair with your feet flat on the floor. If you do not have your wrist at heart level, your reading will be affected. Holding your arms or shoulders tensely may affect the reading. Remain quiet while taking the measurement.
The E error message is telling us that the unit is recognizing some type of interference while taking the reading. This could be as simple as speaking or moving, having a computer, cell phone or medic alert device too close to the phone, a loud television/radio in the same room or more complicated, such as a rapid or weak arterial pulse.
Reading Timing - Because Omron units read your blood pressure by 'listening' to the blood as it vibrates through the artery, the artery must be fully opened for an accurate reading. It is critical to wait a full 5-10 minutes between readings to allow the brachial artery to 'bounce back' from the initial constriction.
Refer to the Instruction Manual provided with the unit for the complete operating instructions.
If after reviewing the information above your unit is still not functioning properly, in order to best serve you, please call our Consumer Support team, toll-free at 800-634-4350. Our trained representatives are available Monday through Friday, 830a to 430p CST to assist you over the phone and try to resolve your issue without sending your unit in for repair. If repair is necessary, they can set up your file to start the process or provide valuable options to your particular situation.
Please have the following information available in order to expedite your call:
1. Model number (from the front of the unit)
2. Serial number (from the sticker on the side of the unit)
3. Proof of purchase information - from the receipt or online verification.
4. The wrist circumferences of all users of your unit.
They will be happy to assist you with your options regarding service.
We appreciate your interest in Omron products and want to ensure your satisfaction.
Please let me know if I may be of further assistance and have a wonderful day!
Jon McGillicuddy
Customer Service Representative
Consumer Support
Omron Healthcare, Inc.
Mar 03, 2009 | Omron Healthcare Blood Pressure Monitor...
When the pressure comes up on the monitor the top number was reading EE. It did it three times. I can't find the instructions. The machine is an Omron model: 741CREL. Thanks.
EE=Cuff under-inflated=not inflated enough. While cuff is inflated, keep pressing START button until pressure reaches 15-20 mmHg higher than the pressure when it stops and displays EE. Make sure at least 5 min allowed between readings.
Feb 21, 2009 | Omron Automatic Blood Pressure Monitor...
Feb 07, 2009 | Omron Automatic Blood Pressure Monitor...
Omron Model HEM 432C Manual Inflation Blood Pressure Monitor Logo
52 people viewed this question
Top Omron Health & Beauty Experts
Md Fazlurrahman
Md Fazlurrahman
Level 1 Expert
jay kaye
jay kaye
Are you an Omron Health and Beauty Expert? Answer questions, earn points and help others
