Question about JVC Video Cameras
My jvc camcorder GR-DVP7SH is in safegaurd mode how do I unlock it?
    Genius:
  • 1,812 Answers
If you've tried removing and reinstalling the battery and resetting the camera then it will need to be serviced by a qualified repair facility.
Posted on Aug 20, 2010
  • prakash lama Nov 16, 2011
    i didn't use my jve gr-dvp7sh for long time now have problem to on and if on there is display problem so can u help me to repair it tnx
My cam. goes into e03 safegaurd mode please remove bat. and rehookup.when i do it plays again for about 5sec. and does it again
The mechanical section which consists of the tape cartridge and VHS-C tape plain has a timing misalignment. Check the inside for possible obstructions of the tape guides not fully sending the tape to the heads - sometimes it gets stuck. It will likely need to be taken apart to resolve the issue.
Nov 13, 2010 | JVC GR-SXM37U SVHS-C Video Camcorder with...
How to remove safegaurde mode in GR-D239E
I stumbled upon this solution to your question:
"JVC notes that you are also given a malfunction code when the unit is placed into safeguard. If it displays code 01, 02, or 06 you should remove
the battery and powersupply and wait for a while. Code 03 and 04 indicate that you should eject and reinsert the tape.
In neither of these solutions work, your only alternative is to bring it to a shop or send it to JVC for diagnosis or repair. Unfortunately, there is no other way to clear the condition."
I hope that helps.
Jul 07, 2009 | JVC GR-D30U Camcorder
Error 3
An error of 03 or 04 indicates that the unit is in safegaurd mode.
Elect the cassette once then re insert it. If the error is still visible you must contact your nearest dealer.
Here is a link to the user manual and troubleshooting guide.
http://uk.jvc-service.net/webtemp/GR-D250EK.pdf?CFID=1168480&CFTOKEN=98803594
Regards
Marc
Apr 16, 2009 | JVC GR-D250 Mini DV Digital Camcorder
01 error code - unit in safeguard mode
I solved the problem! Open the video cassette door. Look closely at the gear mechanism and see if there is any small debris in the gears. If not, using a magnifying glass and a paper clip(must stretch it out and use the tip) gently move each gear(gently). I had my unit ON. Once I moved the gear it became unstuck and ejected Mini DV cassette. I then re-inserted the cassette and it worked. The dreaded SAFEGAURD MODE message was gone and it is as good as new.
Be Blessed
dennis@privatemtglending.com
Aug 26, 2008 | JVC GR-D250 Mini DV Digital Camcorder
Jvc gr-d270 camcorder
Please inform of error code.E0?
May 23, 2008 | JVC GR-D270 Mini DV Digital Camcorder
Jvc mini dv 16x optical zoom in safe gaurd mode
1. The drum cannot be started or drum rotation is stopped
because tape transport load is too high.
1) Tape tension is extremely high.
2) The tape is damaged or soiled with grease, etc.
2. The DRUM FG signal is not received by the syscon
CPU.
1) Disconnection in the middle of the signal line.
2) Failure of the DRUM FG pulse generator (hall element).
3. No drum control voltage is supplied to the MDA.
4. No power is supplied to the DRUM MDA.
May 13, 2008 | JVC GR-D290 Mini DV Digital Camcorder
CAMCORDER ISSUES
There Should be error code start with.E-
Jan 05, 2008 | JVC GR-D290 Mini DV Digital Camcorder
My jvc camera
u will get manual online try  it
Oct 08, 2007 | JVC GR-D290 Mini DV Digital Camcorder
Safegaurd mode
Unfortunately this is a repair issue. There are several failures that can occur, none of which will be resolved without service, that create this safeguard situation. Often the fpc cable which carries sensor information to the micro has been injured and that requires repair. Good luck, magic seadog
Aug 07, 2007 | JVC GR-D240 Mini DV Digital Camcorder
Jvc-super vhsc-wont do anything
if there are no missing parts ? you will get it back in approximately 10 days . . . the repairs will not exceed $ 50 ( plus shipping to and from puerto rico - zip 00794 )
Aug 03, 2007 | JVC GR-SXM755 Camcorder
Video Cameras Logo
97 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
