Alert failed to detect one or more drives during post. dell optiplex gx-760
5 Suggested Answers
SOURCE: manual dell optiplex gx 260
REQUIRED VGA SOUND DRIVER PLS ALLOW ME TO DOWNLOAD DRIVERS
Posted on Apr 15, 2008
  • 217 Answers
SOURCE: Missing Drives for Dell Optiplex GX260 PC Desktop Problem
if you don't have the cd with the drivers and utilities, then you can download the drivers online with another computer. (you will need a thumb drive or cd to save it on) you will also need to make sure you know what brand of ethernet card your computer came with. once you get that ethernet card working, you can get online and download the remaining drivers, possibly through windows update. be sure to select custom update, not express, so it will search for the hardware drivers for you.
Posted on Jun 27, 2008
3764alan
  • 127 Answers
SOURCE: Alert! previous attempts at booting this system
I'm not sure right off hand what the WRIT means. But other articles online seem to think that you should hit F2 at boot and check the Boot Order. One guy set it to CD and booted a CD (a bootable one) fine. I would make sure it set to the first Hard Drive. He also said something about: went to the "event log" section and cleared the last event (actually the only one showing). I saved the settings, then booted up again and this time it booted up normally.
* Anyway new hardware external or internal would be 1st suspect in this kind of thing. One person had problems after adding a new printer that had a memory card in it. Apparently the Dell tried to boot from the memory card.
Posted on Jul 07, 2009
crok41
  • 621 Answers
SOURCE: Does the Dell Optiplex GX 150 Support boot from
Sorry this is not supported by these machines even with latest bios update
Posted on Nov 02, 2009
Windows 7 has been installed in my optiplex gx 240 pc but this is no drivers for sound , lan drivers to fix the problem
Go to the Dell support site on another computer,and look for drivers for you computer model. Download them on a usb drive or on an SD card and install them on you Optiplex computer.
Sep 22, 2013 | NEC Black Nec/dell Optiplex Gx-150/240 Ide...
Dell Optiplex S280. Alert! Chipset heat sink not detected.
There is no S280 in the Optipex model line, just GX 280 and SX 280.
The problem you are describing is common to the GX 280 model.
Here is a link to the manual:
ftp://ftp.dell.com/Manuals/all-products/esuprt_desktop/esuprt_optiplex_desktop/optiplex-gx280_user%27s%20guide_en-us.pdf
Select "Small Form-Factor Computer" and then select "About Your Computer". Scroll down to "System Board Components".
To the right of the processor is a smaller heat-sink attached to the motherboard via a wire similar to the size of a paper clip bent open. That wire is soldered to the motherboard which may have loosened it's connection and the circuit is open. This heat-sink on the chipset of the motherboard. The wire needs to be re-soldered to the motherboard.
Mar 05, 2013 | Dell OptiPlex Computers & Internet
Optiplex 760 airflow sensor
Sounds like your system does not have proper ventilation. It may be too close to walls or something that is blocking the airflow. Maybe the fans and vents are clogged with dust. If so blow it out with a can of compressed air.
According to your manual:
Alert! Air temperature sensor not detected - For any computer type except the ultra small form-factor computer, ensure that all cables are securely fastened to the I/O panel and to the system board and reboot your computer. If this does not resolve the problem or if you have an ultra small form-factor computer, contact Dell (see Contacting Dell).
See link below for the manual.
http://support.dell.com/support/edocs/systems/Op745/en/UG_en/trouble.htm
Jun 07, 2012 | Dell OptiPlex 760 MT Desktop Computer
Hi, my dell optiplex gx 150 was infected by multiple viruses so i decided to re-install xp booting from cd. after copying all the files from the cd and the pc restarts, its failing to continue installation...
1.You have a corrupted boot sector on your hard drive.
2.you will need to format the drive and then re-install the Operating System.
3. If you are not able to do this then a new hard drive is needed.
4. install a anti virus program after installing the operating system
Feb 08, 2011 | Dell System Board for Optiplex GX 150,...
DELL OPTIPLEX GX 620 PC WONT SATRT ONLY ORANGE LIGHT KEEPS BLINKING
DELL OPTIPLEX GX 620 PC WILL NOT START.
ONLY ORANGE LIGHT.
Aug 31, 2010 | Dell OptiPlex GX620 PC Desktop
Alert chipset heat sink not detected
Turn the computer off.
Disconnect the AC power.
Open the case.
Check that the heat-sink is securely and tightly connected where it should be.
May 07, 2010 | Dell OptiPlex SX270 PC Desktop
I NEED VGA DRIVER FOR OPTIPLEX GX110, WINDOWS 98
you might be able to get a driver on dells website if not try driver detective at www.drivershq.com
good luck
May 20, 2009 | Dell OPTIPLEX GX 110/200 PIII-733MHz 128MB...
Is dell optiplex gx 270 apligable for optiplex 270
i don't see any reason that you can't as long as you use the 260 drivers.
Nov 16, 2008 | Computers & Internet
Computers & Internet Logo
2,309 people viewed this question
David Payne
David Payne
