My Technics ST-500 tuner has stop working. LCD display is dead, no signal strenght LED. Only LCD display illumination is working. Any advice? Do You have service manual (electronic scheme) for ST-500?
5 Suggested Answers
SOURCE: we like to change the time in a Tuner/sound
On the right side of the front of the sound processor press the "TIMER/CLOCK" button. The massage "CLOCK" will appear on the display. Then press the"SET" button. And by using the "^&V" (UP&DOWN) buttons the day and then the hour and minute will be set. In the end press the "SET" button. And that's all.
Posted on Feb 11, 2010
welcomejee
  • 10594 Answers
SOURCE: How do you adjust the AM bandwidth on a Technics
Check at bottom, there would be little slide switch with settings 10KHz--9KHz marked on bottom.
Posted on Jun 19, 2010
  • 4234 Answers
SOURCE: I am looking for the
I don't believe that these are available electronically without cost. If you can describe the problem you are trying to solve, I may be able to guide you through the repair.
Dan
Posted on May 25, 2011
GeoffW1
  • 3961 Answers
SOURCE: TECHNICS TUNER ST-X301L USER MANUAL
That's a vintage unit ? You will probably have to pay a small amount to download it from somewhere like
http://www.manualzone.com/service-manuals/Technics_STX301L_STX301L/users-owners-manuals/ReWrite-SPFM-LNG1.Dyn.M39317742KYWRDS_Technics_STX301L_STX301L_service_manual_repair_manual_schematic_diagram_owners_manual_users_manual_parts_list.html
Posted on Dec 06, 2011
When I switched on the Piano the LCD screen illuminates but there is no text and nothing works.
TECHNICS Manuals
..technics owner manuals at link above ....some service manuals there too
Jul 03, 2015 | Music
How do I programme my Technics ST-Z400l Tuner please?
CUSTOMER CARE PHONE NUMBER IS: 1-800-211-7262 PRESS 0 AT EACH PROMPT, IGNORING MESSAGES. LET ME IS YOU NEED MORE HELP.
Nov 13, 2014 | Technics Audio Players & Recorders
Sharp AQUOS LC-42D85U tvgos does not work and hasn't worked for several months. What is the problem?
What is ur tv problem?No tv power LED light incation all or power LED light indication an OPC LED lights indication flashing togethers?Tries tv unplug,replug it back like about an hour later,for the tv to do a whole resetting.Tv might work again.Tv still have no pwer all?Yes.The tv power supply board it is dead,that the board where the power a/c cord plug into it.If the tv have both power LED and OPC LEDS lights blinks together.The tv main board Tuner signal board it is the cause and the problems it is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board or a main Tuner signal board for the replacement.
Jul 03, 2011 | Sharp AQUOS LC-42D85U 42 in. LCD TV
Spot of bad weather here, just had a power surge in the house and now our tv (sharp lc-42SB48UT) won't power on. There is no blue or red light on the front and changing outlets/surge protectors doesn't...
90% to 95% ur tv have a dead power supply board only.5% ur tv could have both dead boards the tv power supply board and the main tv Tuner signal board too.The tv power supply board.That the board,where the power a/c cord plug into it.The tv main Tuner signal board,that the board where all the exstented devices and the tv incomming broadcasting signal cable wire plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement first.The tv problems should be fixed.If not than the main tv Tuner signal board is dead too.Must be replaced also.
Apr 24, 2011 | Sharp LC42SB48UT 42 in. LCD TV
The display on my ST-CA10 is out of function
have u solved the display problem?
i have the same problem.
tell me please, if you solved it...what should i do to make it work.
thanks
lin-q@hotmail.com
Jul 30, 2010 | Technics Audio Players & Recorders
I have a sharp 37" lcd tv,model # lc37sb24u. no pix or sound, power lite comes on about 10 seconds then power and opc lites alternate on and off. thanks RON
This problems very common in Sharp LCD tvs.The Tuner signal board have problems,every times the power LED,OPC LED lites up,just push the power button on again,wait see if the LCD backlight lite up and works,not the Power lite and the OPC lite LEDS flashes again.You,just have to push the power button again,sometimes u have to push the power button at least 6 or 7 times to get the Power LED stable,and then LCD backlight,come on than the tv work.Not sure,but if the Power and OPC lites keep flashing,after u pushes the power button at lest 10 or 12 times,and the LCD backlight dosen't come on and the tv don't work.I think,it time to change the Tuner board is completely dead.I have a Sharp LCD tv, I do this everytimes pushing the power button at least 3 or 4 than the power LED stable,and the LCD backlight come on than the tv work.Not a plaw in the power supply like those capacitors in many LCD models tvs,but some included Sharp Tvs is the Tuner signal board is not very good in design,use the tv awhile the Tuner signal board have problems recieving the power to it Tuner board components.
Apr 15, 2010 | Sharp LC37SB24U 37 in. LCD TV
Technics ST-X302L tuner - Unit not powering on
i have the same unit and a similar problem, after a fall of the tuner on the floor while i was cleaning my room, first times the st-x302l was powering fine but after some minuts it quit alone.. now (i dont know why) it remains on but if there is an interruption of electricity it dont turn on anymore, it turn on only by removing the metal chassis and moving random the electronics.. i think it has some electronic contact or circuit break.. i brought it to a specialist in electronics and he told me the reparation would be too expensive so i prefer to try fix it by myself.
Mar 01, 2007 | Technics ST-GT350 Tuner
228 people viewed this question
 Grubhead
Grubhead
