Question about Brother Office Equipment & Supplies
Our printer 's black color doesn't work after a long time of not in use. The model is MFC 260S. Is there a service center in alabang or sucat, metro manila? This is so frustrating.
    Genius:
  • 2,785 Answers
Your ink has been dried up so it will be better if you try with a new one
Posted on Aug 20, 2010
Black doesn't print color ok
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Nov 24, 2012 | Brother MFC 490cw Color Inkjet...
I am tired of this mfc 440cn not printing in black only mode if the colors are empty, even one. I want to print and work with the black only cartridge. How can I get it to print in that mode only. ie: ...
Yes! There is a way around the problem. On each ink cartridge there is a narrow section that a sensor in the printer reads to decide when the ink is low. Cover that spot with a piece of black electrical tape to fool the sensor and you can keep printing. This page has good pictures showing what to do.
Sep 11, 2011 | Brother MultiFunction Center MFC-440CN...
Anne klein automatic watch, need to replace its time adjustment knob because it was lost... watch repair mans already checked it but cannot open the watch because its too tight..some service center i went...
Anne klein is handled by LUCERNE/CHRONOS SHOP located at Ayala malls like Trinoma in north edsa, Shangrilla in shaw boulevard EDSA, Alabang Town Center in Alabang, Muntinlupa. where is your location so that I can Give you the exact route of malls that near you. i hope i had been helped you.
Jul 31, 2011 | Anne Klein AK Brown Automatic Sport...
My Brother MFC-240C printer is causing me grief. It prints out in black as though it is out of black ink but the ink is full. The other colors print out ok. Any thougths?
If the colors print OK, you could try cleaning the black nozzles. (Your machine may allow you to clean just the black or the colors, or all the nozzles).
1) Press the <Ink> or <Ink management> key
2) Use <Up> or <Down> arrows to navigate to "Cleaning" and press <OK>
3) Use <Up> or <Down> arrows to navigate to color that needs cleaning, or "All" and press <OK>
4) The display will show "Cleaning" and "Please wait"
5) After completion, the printer should be ready
If the problem persists, brother advises that you may need to repeat the process up to four times. If still no results, contact brother customer service.
Jan 22, 2010 | Brother Multi-Function Center MFC-240C...
Authorized Service center in the Philippines
My camera has no power even if i put new batteries.
Oct 23, 2009 | Polaroid I1037 Digital Camera
Brother mfc-620cn I have replaced all the colors and black and still can't get all the colors to print. I cleaned it about 10 times and all I get on the test is black and cyan color blocks. I am using mfg...
If you haven't been able to get the printer to print correctly after that many cleanings, it will have to be taken to a repair center for corrective maintenance. I service Brother products and you more than likely have an issue with the cleaning assembly. You can find a local authorized repair center at this link http://www.brother-usa.com/service/
Oct 08, 2009 | Brother MFC-620CN multifunction Color...
My Brother Printer (model MFC-290c) and ink
On your printer take a look on the "ink management button"press it then look for cleaning using the arrows up and down then press ok or set or what ever the command the printer will display just try to perform head cleaning.try for several times lets say 4x don't clean too much it might ruin all other color if it has no changes try to bring it to a service center,they can soak it to a chemical solution,the head is clog.
Sep 10, 2009 | Brother MFC-290C Printer
Brother Multifunction center, receiving documents, but not printing, being told that color inks are low, do not use color ink never had, original from purchase, I only print in black and white, what can I...
If it show low or near empty it still print.
If it show empty it not print.
You can use black tape cover at ink catrige on position of sensor.
Many people do like that it work.
If not work send it to service center. it hardward problem.
Dec 09, 2008 | Brother Multi-Function Center MFC-240C...
Re:tv
Hi Redd, You might have better luck posting this under Sharp TVs: http://www.fixya.com/support/sharp/standard_televisions The black lines at the top of the screen are usually an indication of a problem with the vertical output section. It's often bad electrolytic capacitors, the vertical IC, or both. That's apparently not a US model, so it will be hard to find the values but you could contact Sharp Philippines: SHARP (PHILS.) CORPORATION [Philippines] Km.23 West Service Road, South Superhighway, Alabang, Muntinlupa,Metro Manila, Philippines Tel: 63-2-842-1371 Fax: 63-2-842-0530 Service Center Tel: 63-2-807-4991/4992 Fax: 63-2-807-0388 Home Page: http://www.sharp.ph/ Good luck.
Dec 19, 2006 | Sharp R-930AK Convection/Microwave Oven
46 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
