In the midle of installation it say error c:\config.msi\19db53.rbf. i click retry and it go on to the end of installation i do the registration and succefull , when i start the autocad it open a grey screen , after few second then close and don't start . pls help me
  • Ronan Reynera
    Ronan Reynera Aug 20, 2010
    What version of Autocad are you installing? What is your computer system information? What operating system is installed in your computer?
  • andredigital Aug 20, 2010
    autocad 2010 and i have 64bit vista home can u help
    President:
  • 1,961 Answers
Two posibilities the cd installer might have scratches cause for not installing properly some files for windows are not installed..seconds your hardisk has a bad sector tyr to scan your disk and fix bad sector..reformat your computer and install again your OS
Posted on Aug 20, 2010
How to Load or Reload"HP Digitalmedia archive" file and 'EZARC.msi to my HP Pavilion a1520n desktop. (XP)
Try this one:
This document pertains to HP and Compaq Desktop PCs with Windows 7, Vista, and XP. An error appears that contains a filename ending with MSI. (MSI refers to the Windows Installer.) This error can appear while Windows is starting up or when a particular software program is opened. This error might appear after using a Registry Cleaner or Registry Fix tool.
See the following error examples. Your error might be slightly different, but it has a filename that refers to or ends with MSI.
The feature you are trying to use is on a network resource that is unavailable. Click OK to try again or enter an alternate path to a folder containing the installation package 'TrayApp.msi' in the box below.
'HPProductAssistant' the feature you are trying to use is on a CD-ROM or other removable disk that is not available.
Figure 1: Example of an MSI error
c01378399.gifUsing Recovery Manager to Restore Software and Drivers in Windows 7 HP Recovery Manager (Windows Vista)
  • HP application recovery process (Windows XP)
  • If errors persist, you can clean up the MSI registry entries by using Microsoft's automated solution. For more information, see Fix problems with programs that can't be installed or uninstalled (in English).
    Preventing MSI errors To prevent these errors from occurring, make sure that registry cleaning and spyware removal utilities do not remove files and registry entries associated with your software. Instead, if you no longer use a particular software title and want to remove all references from the registry, remove the software by using the Add or Remove Programs tool in Control Panel. The software uninstaller will remove the associated entries from the registry.
    Some products available for free on the Internet suggest that the registry needs regular maintenance or cleaning. However, use extreme caution when installing and using a registry cleaner. Many registry cleaners generate other MSI errors because they do not recognize valid registry entries and delete them. This can cause more MSI errors and prevent other programs from working.
    If you do decide to install a registry cleaner, be sure to research the product thoroughly, and then download and install programs only from software publishers that you trust .
    [img src="http://h10025.www1.hp.com/ewfrf-JAVA/Image/common/note.png" alt="" >
    NOTE:One or more of the links above will take you outside the Hewlett-Packard Web site. HP does not control and is not responsible for information outside the HP Web site.
    Jul 12, 2014 | HP Pavilion Computers & Internet
    How to load or to reload "HP Digitalmedia archive" file and 'EZARC.msi to my HP Pavilion a1520n desktop. (XP)
    Jul 12, 2014 | HP Computers & Internet
    Shredder .msi will not install missing file
    ø ShredIt for Windows is distributed as a zipped .msi (Microsoft Installer) file format.Double-click the .zip to de-compress it. Then double-click the .msi to install it.(this is a Microsoft Installer Package) If the installer does not launch or the installer indicates you need to upgrade, go to the appropriate Microsoft web page to download and install the current version of the Microsoft Installer for your version of Windows. For further information, refer to the ShredIt for Windows Read Me (pdf)
    ø Start ShredIt for Windows.The Registration Dialog Box will be displayed on the bottom of the Main Dialog Box.Enter the Registration Key/Serial Number supplied when you paid for ShredIt.
    o If you purchased online, the easiest way to do this is to copy (Ctrl C) and paste (Ctrl V) the information from the email we sent you. If you purchased a CD, the Serial Number/Registration Key is also on the CD jacket.
    o If there is a problem with the registration information, the "Invalid Registration Information" dialog will appear. To correct the problem, refer to the "ShredIt for Windows FAQ".
    ø Put ShredIt in a convenient place by putting a shortcut on the desktop, by the Recycle Bin.To put an alias to ShredIt X on the desktop, follow these steps:
    Select the ShredIt application.
    On the "C" Drive, navigate to the program file you want to make a shortcut for by doing the following:
    From Start-> Click on "My Computer"
    -> Click on "C" Drive
    -> Click on "Program Files"
    -> Click on "ShredIt" Folder
    -> Click on the ShredIt Iconby single-clicking the ShredIt Icon.
    Ensure that you select the ShredIt application, not the entire folder. (The application is called "ShredIt, ShredIt for Windows" and has a shredder icon. The folder is called "ShredItPC", has a folder icon and contains the application, the demo application and the documentation.)
    From the File menu, select Create Shortcut.Drag the "Shortcut to ShredIt" to a convenient place. Most users put it on the desktop, above the Recycle Bin.
    Aug 18, 2011 | Computers & Internet
    Error 1722
    You may encounter the following error on installation:
    Installation ended prematurely because of an error
    when trying to install 32-bit or 64-bit qlikView on Windows 7. With or without UAC (User Access Control), installation fails.
    Suggestions to (re-)install vbscript.dll using regsvr32 vbscript.dll in the c:\windows\system32 (64-bit equivalent) directory didn't help.
    On execution of the installer, c:\program files\common files\wise installation wizard has a new msi added that includes the full installer for the qlikView application.
    Installation worked by opening your command window (Start -> (All Programs) -> Accessories ->Command Prompt (right-click and run as Administrator) by calling the msi, above, with a few switches:
    msiexec /a WISB3[...].msi
    That worked.
    The command-line registry fix as below
    reg delete "HKCU\SOFTWARE\Classes\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f
    didn't do anything...
    Mar 30, 2011 | Microsoft Windows 7 Home Premium 64BIT...
    Error 2350
    THE PROBLEM The Windows Error 2350 occurs when the installed version of the Windows Installer is too old for the MSI to execute. The registration entry for the engine has been damaged and all attempts to execute the MSI installation packages will not be successful.Errors on your system may be caused by invalid registry entries and outdated or corrupt drivers.
    THE SOLUTIONTo fix the registration entry for the Windows Installer, the Installer service should first be registered then unregistered using msiexec /unregister and msiexec /regserver (Type both command in run) or the command line switches. The user will then have to restart Windows.
    Feb 12, 2010 | Microsoft Windows Vista Home Premium with...
    How can i repair error 2350 with no cost?
    To fix the registration entry for the Windows Installer, the Installer service should first be registered then unregistered using msiexec /unregister and msiexec /regserver or the command line switches. The user will then have to restart Windows
    Oct 31, 2009 | Microsoft Windows Vista Home Premium with...
    Cannot uninstall or install HP scanjet G2410
    I tried all the "decent" uninstall solutions like running HP's Level 1-4 Uninstall batch files. HP's installation software still insisted that parts were already installed. Then, with the scanner connected, the installation software got into competition with Windows also trying to install the driver. The reinstallation was no good. Solution Center wouldn't even start, preposterously announcing that it couldn't find the scanner!
    When you have a reliable clone of your c:\ drive you can try daring solutions. Such as this:
    1. Search the c:\ drive for files and folder with "Hewlett" or "HP" in their names. Kill them all.
    2. Search the registry for keys with "Hewlett" visible or buried. Kill them all.
    After 1 & 2, reinstallation worked smoothly. And my computer still works! The only evidence of the violence is an undeletable file 3963d.rbf now in c:\Config.Msi. I will report back if serious computer problems arise.
    The point is that manual uninstall is possible and none of the elements are in hidden places. Someone else can determine whether both file and key deletions are necessary and exactly which ones.
    Apr 08, 2009 | HP Scanjet 4470c Flatbed Scanner
    Error 1935
    Cause: This is a known error seen during the .NET Framework installation. Refer to the following Microsoft article for more information http://support.microsoft.com/default.aspx?scid=kb;en-us;308096
    Resolution: Restart the computer then retry the installation. If the problem persists, install an updated version of MSXML.
    1. Click My Computer then select C: (the local hard drive)
    2. Click Program Files and delete the MSXML 4.0 folder, if it appears.
    3. Next click Start, point to Settings then Control Panel and double click Add/Remove Programs.
    4. Look for Wintool easy Installer and remove it if it appears.
    5. Now, download the latest MSXML to your Desktop from here:
      http://download.microsoft.com/download/9/6/5/9657c01e-107f-409c-baac-7d249561629c/msxml.msi
    6. Double-click the downloaded file msxml, to install it.
    7. Restart the computer when prompted.
    Cheers !!!
    Feb 12, 2008 | Microsoft Windows Vista Ultimate Edition
    Computers & Internet Logo
    David Payne
    David Payne
